Part I
"Maybe" because I'm just winging it here, no real decision on what to do with my experiments.
On to the story!
Among the first things I tried with the wife's laser was cutting veneer. I always wanted to try creating something, anything, in the style favored by the venerable EarlS.
I'm no Earl, but I do like experimenting and here was my chance.
Intertubes scoured for some simple design and I found one that was simple enough. Worth a try anyway.
Quick dig through the veneer boxes and I dug up some curly white oak, mahogany, maple and a few other mystery woods. Next time I'll know better
Cutting the oak:
Placed on a glass sheet so it stays flat. When the beam finishes cutting through, it will pass right through the glass and not scorch the underside of the veneer.
The laser work was all done with "LightBurn". Super versatile. I let it leave small "tabs" at several places around the cut so when finished, the parts stay attached until I push them free. Basically just press the "tab" button and it all gets done magically.
The design was drawn in MacDraft, a simple CAD program that can produce DXF files which are easy to export as to LightBurn and individual pieces to work with.
All the various bits for making four panels, set for one panel selected:
I wanted some accent colors so I used TransTint dyes to color some of the maple parts. Left to soak for a few hours hoping to get 100% penetration (didn't quite happen).
These panels will be about 4" x 6" on 1/4" plywood. Back sides veneered with some dark mystery wood for structural balance.
I needed something to lay out on so I used my granite surface plate. Painters tape, sticky side up, keeps everything from moving around. I've since bought some shelf contact liner which should work much better.
The two 6" rulers are placed to act as a squaring jig.
Bit by bit everything is placed into position
Since this was made before my "sunburst" , I had no compensation for the kerf created by the cuts. This left parts with a small gap around their perimeters. I'll deal with that later.
Into (and out of) the vacuum bag.
Since there were the perimeter gaps mentioned before and the oak pores, I used some "Aqua Coat" to fill.
After a quick sand with 220, I see that the dye did not penetrate much. High spots had the dye partially removed, bummer. But hey, I learned something!
The gaps bug, so I used a 1mm Rapidograph pen and India ink to draw lines, I think it also helps separate the parts visually since my wood choice was not all that ideal.
The ink was protected under a layer of sealer then top coated with pre-cat lacquer.
Now what?.
I know, frames!
1/2" thick by 3/4" wide walnut, grooved to cover the panel edges.
My box joint blade is awesome for making smaller dados like these. Feather boards keep everything aligned
Nice fit!
Cut to length and make stub tenons for strength.
Ok, four framed panels done. Let them sit until they tell me what they want to be
Part II
I liked the idea of turning these panels into a tissue box but alas the width dimensions were a tad small.
Either way, Onward!
Make this into the beginnings of some type of box
Ready things for the box miter bit.
I like these bits, strong corners and easy glue ups without the corners sliding around.
I use a guide board so I don't have a knife edge riding against the fence. I DS tape some hardboard of the exact same width to each board before routing
Glue an clamp it up!
I do this on a surface plate so top/bottom are flush.
Still takes a few clamps, but it all stays square.
Worked well
Nice fit too
Decided it needs a bottom, but forgot to cut a rabbet. I used a small top-bearing straight bit and swapped out the bearing for a smaller diameter.
Sharp chisel squares up the corners.
Now I'm thinking that this could hold a small flower vase.
Legs needed (cherry), grafted to the corners.
They are curved top to bottom. Used the laser to make a router template from hardboard. Sure beats trying to be smooth with a rasp, spoke shave, and sandpaper.
I'm at my photo limit so I'll continue elsewhere....
Chapter 2
On to the story!
Cutting the oak:
Now what?.
I know, frames!
Nice fit!
Part II
Either way, Onward!
Worked well
Nice fit too
Chapter 2
