Mario-themed Rock Climbing Wall
3575 Views 9 Replies 4 Participants Last post by  LittleBlackDuck
32
Planning and Construction
My boys and I enjoy playing Mario together, but we do try to limit their screen time. They are also young boys and have enough internal energy to power a small ocean liner. My wife and I are tired from being woken up by them every single morning, and if we don't attend to them, the situation usually degrades into petty arguments, fighting, and crying. So with fall and winter right around the corner we decided we'd do something in one of their bedrooms that would be entertaining yet creative, and also allow the expenditure of some energy. We decided on a rock wall with padding on the bottom. I personally made the decision to make it Super Mario themed to take it to the next level. They love playing Mario and Bowser and saving the princess at the castle. It might not save us any sleep, but the number of smiles on their faces already, even before it's done and usable, has been priceless.
It all started with a sketch:
Handwriting Ring binder Rectangle Font Sketch pad
We decided to get a Nugget as the padding underneath the rock wall. Not only will it serve as a safety device, but on its own it unlocks a world of creativity - our boys have already made this thing into forts, slides, ninja-warrior courses, wrestling mats, climbing structures, and more, not to mention a nice place to read a bedtime story together. Highly recommend! Check them out here: https://nuggetcomfort.com/
It took a while to find one in stock, but eventually ours shipped so I could get started on everything else.
After that I realized the lumber shortage that has stricken the world… The nearest Home Depot with 8ft studs was on the other side of the state! I did a bunch of calling around and eventually found a local lumber yard with a single pallet of 2×4's. I high-tailed it over there and found they only had nicer Number 1 Common boards in, but I didin't mind. I snatched up what I needed and a few more for other projects and the boys were already excited.
Car Land vehicle Vehicle Plant Trunk
Shorts Wood Leisure Floor T-shirt
I also picked up my sheet stock and screws from homedepot - plywood seems to be pretty available around here anyways.
Car Motor vehicle Vehicle Automotive design Trunk
From here, it was mark it up and drill, baby, drill. I referenced I Like to Make Stuff's video on his rock climbing wall here:
Wood Composite material Hardwood Plank Rectangle
Wood Table Flooring Floor Wood stain
I made the holes on an 8" x 8" grid, offset 4" from the edges of the plywood to make sure none were overlapping stud locations. Unfortunately I found a problem between the first and second sheets. The rock holds I bought were these: https://www.amazon.com/gp/product/B07QGRDL38/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
This rock hold kit came with bolts, washers, and T-nuts that I made the boys sort out, haha.
Hairstyle Leg Sharing Couch Flooring
I needed more T-nuts to fill my grid of holes though, so I could move the holds in the future if we ever wanted to re-arrange. So, I went on amazon, read the reviews, and got a bag of 100 3/8" T-nuts. Turns out the tread didn't match and I actually needed M10 T-nuts, and the holes needed to be 12mm, not 3/8. It was BARELY not the right size, so I also had to order a 12mm drill bit for the right size hole. It was surprisingly hard to find. The one I got was a real wood-butcher too and it really made my holes not so nice. But in the end, we got it done - redrilled the one sheet I had done already, and put new holes in the other sheet to match.
Then it was time to hammer in all the T-nuts. The boys had fun pounding away at these.
Wheel Tire Hood Artist Wood
Vehicle registration plate Car Vehicle Plant Tire
Once that was done, out to the yard for a coat of paint.
Wood Plant Grass Tree Wood stain
Wood Grass Flooring Wood stain Rectangle
While that was drying, I made the frame and took it up to the room. Too long, crud.
Wood Floor Door Flooring Comfort
Took it apart, back down to the garage, cut each piece, brought it all back up, reassembled, and it fit! I pre-drilled for some big GRK fasteners - had to "countersink" into the stud a bit, even with a 5-1/2" screw, but they all found a solid connection with the wall and this thing isn't coming down any time soon.
Wood Finger Office ruler Thumb Art
Fixture Wood Flooring Composite material Hardwood
Then I put up the plywood sheathing - I drilled and countersunk 2-1/2" screws every 8" on the frame. These are also not coming down any time soon.
Wood Flooring Floor Shade Fixture
Cabinetry Furniture Comfort Chest of drawers Drawer
Phew, that was more work than I was originally thinking. Now for the tedious part though - painting the mario scene. I have a few extras that I'm really excited to share also, but that's gonna have to wait for the next post. Hope you enjoy following this as much as me and my boys are enjoying making this!
1 - 10 of 10 Posts
36
Painting the scene
Next up was finalizing the scene and finding the right colors. I drew up a more scaled version of what I was looking for - found out later I messed up the hole locations I was basing everything off of, but at least having major objects to scale was really helpful for laying it out on the wall.
Ring binder Handwriting Office supplies Book Publication
Then I had to figure out colors. I found a couple great references. First, I found actual sprite info from the games that I then took into photoshop to get an RGB code for each color I was looking for.
SMW sprites I found here: https://www.spriters-resource.com/snes/smarioworld/
Then I found another great resource that will tell you which color name to order for a specific color in any particular brand of paint. Check it out!
RGB paint color looker-upper: https://www.easyrgb.com/en/match.php#inputFORM
Sadly I couldn't find exact matches for nearly any of these. Also, I figured I'd probably need a quart of each, and the cost was adding up fast. So I got as close as I could and eliminated a couple. In the end, I wish I would have gone with a little less contrast between the two dirt colors. But here's where I ended up. I decided to go with Behr Ultra interior eggshell because Home Depot is right around the corner from me. Turns out they had to ship everything but white anyway… ugh, oh well. Here's where I landed:
Color name: R, G, B - closest Behr Ultra color name
Light green (bush): 0, 248, 0 - Lawn Party
Medium green (grass): 0, 200, 0 - took this one out to save cost
Dark green (dark border on bush): 0, 128, 0 - Luck of the Irish
Dark dirt: 200, 152, 88 - Burnt Pumpkin
Light dirt: 224, 192, 80 - Little Sun Dress
Black
White
So with that all out of the way, it was time to get it on the wall! Started with some drawing on the wall, which the boys loved, obviously. I took some of the sprites from the first link and edited them down in photoshop to make them perfect 8" x 8" tiles. Some of them I just referenced and others I actually cut out for texture patterns and shapes.
Wood Material property Font Art Circle
Hand Gesture Sleeve Thumb Finger
Art Wood Font Rectangle Space
This is where I realized I goofed my hole locations on my scale drawing. I had to re-draw the grass platforms.
Wood Floor Flooring Ceiling Slope
Floor Fixture Flooring Wood Composite material
Then it was time to paint. I knew this going in, but never trust a comment on the paint can like "covers in 1 coat!" It's a lie. A whopper even. Each color needed 2 coats. The dark green needed 3.
Building Paint Art Flooring Wood
Paint Rectangle Art Wood Wall sticker
Building Paint Wood House Art
Art Wall sticker Rectangle Paint Room
Paint Art Wood Ladder Building
For the clouds, we decided to try tape to make the details square like the pixels in the game. It was definitely time consuming, but the result was pretty good.
Font Vehicle registration plate Gas Rectangle Terrestrial plant
Plant Gesture Font Art Terrestrial plant
Lastly I finished up with a black outline over everything. It was also pretty time consuming and difficult. It's not like drawing a straight line with pencil and paper. You need to keep lifting the brush and refilling, and bristles don't always cooperate. The lines ended up a bit imperfect, we'll say, but I actually kind of like it! It adds to the cartoon-like look of everything.
Green Cartoon Art Plant Font
Rectangle Wood Tints and shades Art Grass
Lastly, I added a little mole hole from the game for some giggles.
Art Rectangle Flooring Font Wood
In all, it took probably 20 hours of painting. This was a huge task, particularly because this is in my middle-son's bedroom and he still naps. So I had the time right after he woke up before he got too wild for open paint cans in the room, lunch time when he was out, or on the weekends, right after nap time, again before he got too wild for open paint cans. I couldn't do it before he went to bed because I guarantee he would have smeared anything wet all over the room. So… it took quite some time. But I'm thrilled we got there! Next steps are some decals of mario figures, blocks, and a couple other special extras to top it off. We're getting so close!
Paint Wood Art Flooring Font
Green Building Paint Wall sticker House
Painting the scene
Black
White
My two sons wanted me to ask if you're currently accepting applications for more children. In the event of only one opening being left available, they've resolved to fight to the death for it. On the surface it may seem extreme, but I can't blame the effort they're willing to go to here. Hell, for a climbing wall of that caliber I'd likely toss my hat in the ring as well XD
All jokes aside, it's incredible to see so many amazing fathers and mothers here working so hard to keep life normal for their families. Excellent craftsmanship and creativity on display here. I can literally see all of the love you've poured into this.
Any kid would be lucky to have a dad like you, sir. No doubt your grandchildren will have similarly amazing upbringings due to the time and effort you're willing to put into the ones you're raising. Words don't do justice to the level at which you rock!
Painting the scene
Black
White
Thanks for the incredibly kind words, PlumberMike! Unfortunately our vacancies were filled when we were done at 2 kids and #3 came along! I am the least perfect of the bunch, but all the reasons you listed were motivators for this project. The boys are so excited to be climbing on this thing. At this point I'm not sure I even care if they use it. The number of smiles and pure joy on their faces watching this get put together has all been worth it already!
Painting the scene
Black
White
What a cool theme! VEry nice work.
CtL
Accessories, bringing it to life
Now that the painting was done, it was time to bring it to life. First we added the vinyl decals of the characters. I went with the 70-inch sheet from primedecals.com because the bricks were 7" square. My grid was 8" so this matched the best. I looked long and hard for these and I can attest to their quality. We actually got 2 Mario's in the set. It looks like one of them had some printing issues with some banding and blotching, but unless you're looking really close nobody would be able to tell. So, my other 2 boys who share a room got some more Mario stickers to share the fun. Nice of them to include both the original and reprint! If this is the case, I like their service!
Here's a link to the decals I got. There is a 30% off coupon for new customers if you do a google search. https://www.primedecals.com/Super-Mario-Bros-Wall-Mural-Decal_p_376.html
And here they are helping me pick where they should go. Only one thing was certain - I wanted Mario bumping the question block under the vine. Otherwise they helped steer the direction of which pieces went where.
Cabinetry Sharing Flooring Drawer Fun
Where we ended up:
Art Paint Flooring House Building
Then it was time for the rock holds. These are the ones I used, and I got 2. In the end I had 11 left over, mostly reds.
Rock hold kits: https://www.amazon.com/gp/product/B07QGRDL38/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
The colors were perfect for this. Reds matched Mario's shirt perfectly, the blues worked for the sky and mario's overalls. The green ran sort, wish I had a few more of those, but they went on the grass, hills, bush, and vine. Yellows went on the turtle and worked great for the dirt. I used a couple where I ran short of greens. The dark brown was a perfect match for the brick blocks and goombas! And I used a few browns in the dirt as well.
Wood Textile Table Comfort Outdoor furniture
Automotive design Yellow Material property Rectangle Font
Once again the boys helped lay these out with a little guidance from me. After using it for a bit, we inadvertently made a hard route on the right up to the turtle, an easier one up the vine in the middle, and a medium route on the left up to the blue hold way at the top above the air return vent.
Green Leisure Fun Toddler Child
Green Cartoon Blue Art Font
Art Paint Rectangle Gas Font
We made a bit denser area for my 1-1/2 year old on the bottom right so he could learn on it a bit easier.
Toy Art Recreation Leisure Happy
And the final outcome. It definitely clutters things up a bunch, which IMO is a bit of a bummer, but the whole point is to be a rock wall, and as far as those go, this is still the coolest one I've ever seen :).
Toy Interior design Building sets Wall Art
Before we tested it out, I had to introduce the next surprise: a plush 1-up for an extra life in case you fall.
Green Headgear Aqua Stuffed toy Costume hat
It was a hit.
Shirt Green Organ World Happy
Here's a link to the pillow. There are a bunch of cool ones like it: https://www.amazon.com/gp/product/B07X6VB46H/ref=ppx_yo_dt_b_asin_title_o05_s01?ie=UTF8&psc=1
Obviously we jumped on the wall as fast as everything was fastened.
Green World Toy Leisure Fun
Green World Organism Climbing Adaptation
I even had to give it a try :)
Interior design Comfort Toy Wall Floor
Then, of course, Bowser stole the 1-up and put it atop his castle. Thanks to the Nugget (https://nuggetcomfort.com/products/the-nugget) and a little imagination, we quick made a castle/fort.
Comfort Smile Leisure Fun Child
Then it was time for the final surprise. A question-mark block with a button on the bottom that if you hit it, it lights up and makes a coin "bling!" sound. It was always the intention to put this little piece of magic on top of the vine.
Amber Art Wood Sky Font
At nap time, my oldest helped me make a holder for it to keep it in place. We did it right, I think!
Furniture Table Wood Smile Engineering
Smile Glasses Table Tableware Eyewear
We painted it to match the block and the wall and put it together.
Building Wood House Shelving Toy
Then when everyone was up, we put it on the wall to wrap everything up.
Shelf Art Rectangle Wall Wood
World Wall Gas Happy Font
World Shorts Happy Wall Fun
Art Electricity Gas Space Ceiling
In the end, it's a huge hit. Like I mentioned earlier, I would have been happy even if they never used it just going by the sheer joy it has brought us all putting it together. But they played on it for hours today! It's been a pretty special project indeed.
Smile Photograph World Green Sharing
Furniture Textile Interior design Toy Wall
I have a list of materials with links, quantities, comments, and costs in the google file here: https://docs.google.com/spreadsheets/d/1n_e-vXi3dOUHtWXetfCcmWgYUEp4fcEYVf6ocFY3y1o/edit?usp=sharing
Any questions, just ask away!
Ideas for future additions
Having way too much fun with this. The boys and I have way more ideas to keep building on this. Thought I would share the ideas here to document for possible use later, and see if it sparks any other imaginative ideas!
Furniture Textile Interior design Toy Comfort
Ideas for future consideration:
1. Custom holds! This is an easy one. With all the t-nuts in the wall already, all I need to do is make a bolt hole in basically anything and mount it to the wall. An easy one would be a "shelf" hold, say 2" square cross section with a juice-groove-like indent on the sides to hold onto. Thinking anywhere from 12 to 48" long. This could be a ledge by the clouds or a vertical on the sides of the hills, or heck even mounted to studs off the side of the rock wall. Lots of ideas here to keep things interesting.
2. Kerf-bending plywood mario pipes! Saw this calculator here: https://www.blocklayer.com/kerf-spacingeng.aspx. The boys have 2 laundry hampers next to the wall and I thought why not make them mario pipes! The boys could each pick their favorite color pipe. They might be kind of heavy to haul to the washing machine, so if that's the case I thought they could be permanently mounted as a pass-through horizontally under the wall to double as a step-off point (questionable safety here though if they fall on it), or off to the side for more imaginative play. Something they could fit in like a life size mario pipe would be so awesome.
Saw this painted trash can for the same use, but I think the boys would break these so that's why I was thinking kerf-bent plywood.
Gas Wood Cylinder Smile Art
3. Like I mentioned in post #1, they love pretending to save the princess from bowsers castle and bringing her back to the princesses castle. So, maybe print some decals of a bowser and princess castle and put them on either side of the rock wall for more imaginative play. I thought about painting a simple scene with a path leading up to each. Might be a bit more work than I want though.
4. Green mario vines hanging from the ceiling to swing from. Dye some thick rope green, maybe sew on some leaves. Even one near the corner of the wall would be cool, but maybe multiples would be fun.
5. Eventually I plan to build the boys bunk beds for in here. Most rock holds I have left over are red and yellow, so make it bowser themed and have a lava theme rock wall going up to the top bunk. The bottom bunk could be cave themed.
World Light Lighting Art Font
World Urban design Font Pattern Circle
6. Slide from top bunk, but exits through a mario pipe! Kind of like the wood whisperers bunk idea here: https://thewoodwhisperer.com/videos/bunk-bed-with-slide/
That's what I came up with for now… If YOU have any crazy ideas, let me know!
I think you should build yourself this on the outside of the house… to give your "height" a challenge… why should the kids have all the fun.
Love the whole gambit.
I like the way you think! Lord knows I could use the exercise, haha. Also these kids are going to be teenagers someday and they will definitely outgrow this. So I did think, you know, we have a 2-story foyer leading up to this room…..
Property Wood Interior design Wood stain Flooring
Don't tell the wife. That's a discussion for another day, hahaha.
P.S. this is a joke. ...kind of :)
Don t tell the wife. That s a discussion for another day, hahaha.
- jamsomito
Sure beats walking up stairs!
1 - 10 of 10 Posts
