1 - 4 of 4 Posts
Discussion Starter · #1 ·
The Idea
My daughter who is 10 this month, has a ton of Webkinz and a while ago she asked me to make her something that she could put all of them on.
So I was perusing a magazine that had plans for a crown molding shelf(mantel) and it looks really elegant and seemed like it would be fun, quick and easy to make. So I checked around and found I had enough scrap, and only had to buy a heyhole bit for my router(darn :) ).
Discussion Starter · #2 ·
The Plan
Well, being a trusting sort, I started working through the plan as dimensioned.
The first parts went together really well( these being the top, bottom and back). Then the time came for adding the molding around the front and sides. I soon discovered that the pieces were not lining up right as they should according to the diemensions and the pictures. And to top it off the boss was getting angry at me cause I was spending time doing that instead of getting ready for vacation…sigh.
So anyway being handy with sketchup, I started working through the project in there. I should have done this to start with because the dimensions I wound up with are way different from those in the article. Anyway here is the completed sketchup drawing.
Now the only questions I am having is materials. Originally I was using things I had left over inthe shop, I didnt like the way the boards came out, as they were rough and I didnt really sand them down real fine because I was going to paint them anyway, but the grain still was showing through. So now I am thinking for the Top and bottom I will use MDF, I will still use wood in the back for the strength to hang it(dont want screws pulling out of keyholes in MDF), and use regular style 49 crown molding, but make sure all the stock comes from one piece to eliminate any registration errors.
The Plan
Nice project. You may consider using an open back design, it would be much stronger and secure. Mount a ripped 2×4 to the wall studs and slip the mantel over the 2×4 and secure with finish nails or small screws…
Goog luck
Tom
Discussion Starter · #4 ·
The Plan
I had seen where it could be done that way, but it is too permanent a solution for me, I still want the option of moving it easily if I want without worrying about tearing anything up.
1 - 4 of 4 Posts
