Design
I recently took up wood turning as the next step in my wood working addiction, turning has been extremely fun but costly. As I have been turning every log I could get my hand on, I have had a real hard time doing small vases and hollow forms. I have looked into buy some hollow form tools but dont have the funds the buy what I would like (http://www.amazon.com/Robert-Sorby-SOV-22S-ULTM-Medium-Hollowing/dp/B0052MH306/ref=pd_sim_sbs_hi_5). So I have decided to make my own, I have no experience doing so. This will be a learning experience for me. My goal is to make full set of hollowing tools for under $100. After searching google, youtube, LJs and http://thewoodwhisperer.com this is what I have come up with.
Set will consist of three chisels:
Straight, 22 degree bend, 45 degree bend.
Option 1:
Cut 5/8" Cold Rolled Steel to 12" long, drill 3/16" hole 1.5" deep in the head of the of rod. Drill, tap and die holes for set screws into rod and insert 3/16" HSS cutter. The rods will be bent at the 2" mark.
3/16" HSS cutter
http://www.use-enco.com/CGI/INSRIT?PMAKA=383-7005&PMPXNO=2609935&PARTPG=INLMK3
http://www.homedepot.com/h_d1/N-5yc1v/R-100338204/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Set screw
Need to determine size, suggestions?
Concern with this method:
Can I bend the rod using propane torch?
http://www.homedepot...catalogId=10053
Option 2:
Cut 3/8" Square Rod 12" long. Grind recess on end 3/16" deep by 3/8" wide. Drill, tap and die hole for set screw. I would like to make 3, one straight, 22 degree bend and 45 degree bend. This replicates what Eddie Castelin has done ([media]]http://www.youtube.com/watch?v=asbxBgGOhas&feature=feedf[/media]) but with a bend.
I am not sure what size hole I will need to secure cutter to rod.
Carbide Cutter
http://www.woodcraft.com/Product/2080216/28296/Ci0-Easy-Finisher-Replacement-Round-Cutter.aspx
3/8" Square Rod
http://www.homedepot.com/h_d1/N-5yc1v/R-202183570/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Questions, comment and donations are appreciated.
Option 1:
3/16" HSS cutter
Set screw
Option 2:
Carbide Cutter
3/8" Square Rod
