Hi Jim! Thanks for the comment.Finding shop time in a busy schedule -or- Making slats & cutting pieces
The next step in this project is making the curved slats for the back of the stool. The process is the same as for the curved parts with a couple exceptions. First the pieces for each set of slats are cut from two blocks. These blocks were next to each other when cut from the large stock. Instead of marking with a saw cut as I did last time, I used a permanent marker.
By angling one stripe across both blocks, I am able to keep the strips in order. The total number of stripes tells me which stool this set of strips belong to.
The other difference is the clamping jig.
This jig has two curves and required careful adjustment to create a tight fitting result.
But, this is not what I want to write about for this post. I think it would be nice to share how I find shop time. We all have busy schedules and, at least for me, the woodshop takes a lower priority. I find that I can fit in shop time a little bit at a time.
I start out with a stack of strips to be glued up. This makes a good example of how to find shop time.
My shop is located off the back of my garage. Gluing up a set of 4 strips takes 10 to 15 minutes. If I can find that much time before I leave for work, I have enough time to glue one more set.
As the days go by, I find that the pile slowly shifts from only one done to only a few left to do.
And then the day comes when I have glued the last one up!
Then there are days when I have more time. That is when I can take the rest of the wood and start to cut it into final pieces.
In this case, there is a bit of prep work to make sure that the grain runs from one part to the next wherever possible. There were several 15 to 30 minute sessions where I just focused on marking the pieces.
Once again, cutting the pieces is done a little bit at a time. The longest session was less than 2 hours. Over time, the pile of big parts turns into a pile of smaller parts.
And once again, the day came when the last pieces were cut.
There is likely some extra time in this project that results from working in small sessions. For me the tradeoff is that I get to make progress and spend time in the shop more often.
The project is now to the point where all the pieces have been cut to thickness and width (well almost all … ). Next is cutting to length and then cutting mortises.
Current time log:
Cutting rough stock: 2 hrs
Cutting legs to width and thickness: 4 hrs 20 min
Seat Back and Back Rest
> Cutting thin stock for laminations: 3 hrs 35 min
> Prepping laminations: 8 hrs 40 min
> Glue up Laminations: 3 hr 50 min
> Trim Laminated Parts: 2 hr 25 min
Back Slats
> Cutting thin stock for laminations: 1 hr 55 min
> Prepping laminations: 3 hrs
> Glue up Laminations: 6 hrs 5 min
> Trim Laminated Parts: 10 min
Lower rail parts
>Cut to width and thickness: 10 hrs
Total so far: 44 hrs (7+ hrs per stool)
Six stools does tend to cause things to pile up
