21 - 40 of 124 Posts
· Registered
Making the body part one.
Low angel shoulder plane
Because it's fun….
Before you start reading I want to tell that I finally managed to make it run!
It was giving me a headache, but once I found out the problem it was right on.
Here is a video showing it in action.
But I will blog a improved version also in this blog serie.
Not so long ago I followed a class here on LJ with Stefang where we build a bucket, part of this project was to make a convex hand plane (Krenov style).
So what have this to do with a low angle shoulder plane that I now build alongside Div's blog
The fact that they are both based on the same technique, where you cut up a block of wood and glue it back together rather than hollow out (to cut is fast and easy), Krenov style traditionally add a cross pin and a wedge, where Div's shoulder plane skips the cross pin and just makes a wedge that fit the hole and let the shaves out sideways, so when you have made one plane it is no sweat to do the next's (trust me on this).
If you want to build a traditional and way too cool shoulder plane, you can use Divs blog to make a bevel down 45 degree bed shoulder plane.
This is a Div shoulder plane, made by Div. (Yes I am really proud to own one).
I choose to be a naughty boy and make my version of the shoulder plane as a low angle bevel up, where Div make it a medium angel (45 degree) bevel down (look at drawings). The reason for this is that I am so lucky to have received one of Div's wonderful planes as a gift from him, so it would be more interesting for me to try new ways to be able to compare after.
This is where we are going now.
As you can see I made a new design just for my pleasure, I am going to play with the circle here, so the opening will be a half circle and then I will shape the plane also from this center.
Ok I start my blog here, sorry I had not thought I would make a blog.
I have already chosen the dimensions of my plane, the width after what I need and the rest just to match my wish for size.
Look here for the basic cuts: http://lumberjocks.com/mafe/blog/23516
When I had these dimensions I cut up a block of wood that matched that, and then 'cut of' the sides in a thickness that will make a strong plane. The smaller the plane the thicker the sides need to be compared to the total width. Here app 1/6 of the width for each side.
So I have now a center piece and two shoulder pieces as you see on the picture.
All rest in the middle of drawing tools and a sketch of my ideas for the plane.
Div's plane is a bed angel of 45 degrees and bevel down plane iron, the one I will make will be a 12 degree bed and a bevel up plane iron, if you make only one then make the 45 degree bevel down, in this you get a relly cool and well functioning plane, where the 12 degree bevel up is a tricky lady to get dancing and might be never really rhe thing, at least if you make a 12 degree then make it bigger size to provide stability.
The difference is as you can see on my illustration how we approach 'attack' the wood.
With the bevel down the angel is fixed once the plane is done (unless you start honing back bevels).
With the bevel down you can change your bevel angle and in this way change your planes approach.
Why should you ever want to do that? Because different types of wood can require different angles for a good result. I do it just for the fun of it, and will make the bevel on mine 22 I think that gives me a total of 34.
IMPORTANT CORRECTION TO THE BLOG
TO HOLD THE BLADE TIGHT ENOUGH YOU NEED TO MAKE A HIGHER WEDGE THEN SHOWN ON THE PHOTOS HERE.
br>
I have been thinking of advantage and disadvantage of each version
The 45 degree version have a more solid bed to place the iron on since it is more solid, and should then make less shatter (the blade wobbling), but then the bed stops at the bevel and this makes the last piece of the iron hang free, so it probably more or less equals it I think.
What I do think can be improved is that it would be better with a higher wedge, this would give more stability and the wedge can be made pointed towards the opening so it will not make the shavings get stocked.
Enough theory let's get to it!
Take the top piece of the three and use this to draw the layout on (I use the center piece here since I already did the other).
Make a point where you want the mouth of the plane to be, I choose a little over center of the sole.
From this point make a line of 12 degrees back.
Like this.
Hold the iron on top and draw the thickness of it on top of the first line.
(If you don't have the iron yet just draw the thickness).
The wedge I design here are after the Div model and is a long slim one.
But you should follow the red change and make a higher wedge, this will support the blade better.
I have no number here but I will say 8-10 degrees.
Now I want to decide app where I want the mouth so I hold up the blade and make a point app at the end of a 22 degree bevel.
And you can see the change line for the wedge.
Now I can draw my half circle and find my 'center' of the layout.
Some 1,5 mm brass rod for pins to hold it together while it's being made and later for beauty.
You can use wood pins also.
I decided that the pins also should be placed in the circular system, so I make a second circle app 1 cm offset from the outer.
And mark 1 cm from the sides where the circle strikes this.
With an awl mark the points so the drill will be controlled.
Clamp the three pieces together and drill a hole in one end.
Now fit a pin in the hole.
And cut off.
Do this in the other end also so it will be fixed, and then you can remove the clamps and do the rest since the pins will hold the three parts in place now.
Time for tobacco.
Ohh yes and look at the mail.
Ironically today I received a vintage brass compass I got of E-bay for a dollar, this must be a sign that my circular design is the way to go now.
Look how funny.
The old beautiful brass compass - the newer mass produced ugly version of this that are less steady. Then a new quality compass for drawing (from I was a student making technical drawings) - and a modern made in China version with no charm and also less steady.
Yes life goes in circles, and in my life I often end back where we call it vintage du to the wonderful quality back then.
Sorry I'm back from dreaming!
Drill a hole somewhere in the area that will be the opening for shavings.
Time to cut out this piece, I'm lucky to have a motorized saw here, but a hand scroll saw will be just as good.
And cut!
But leave some at the area that will be the mouth, so it will be possible to adjust here.
Here we are.
Time to saw out the area that later shall hold the wedge.
I use a brass bar that has traveled all the way from US (thank you Maddie and Rand) to hold my saw at 90 degree. You should try and stay focused here since it is going to be the bed of the iron and we want it to be flat and in angle.
And saw some more (I use here the little inexpensive Zona saw since it has extremely fine teeth and makes absolutely no tear out).
And out it came.
Keep the piece, then you have the angle for the wedge later.
Put the body apart.
And find your favorite glue. I have a soft spot for two component epoxy, probably because of all the knifes I have build with this stuff. It is rock hard and will never fail.
Mix the glue and spend the time doing it good.
I use a 16 hour dry time epoxy here, since I want time to make sure it come together fine. If you are in a hurry you can use a fast version, but don't drink coffee then.
I add glue to two pins and position then in each end then add glue to the one surface of the plane core and then place it in place using the pins as guides.
Now it's the top piece tour.
And time to clamp and clean off glue.
Since this epoxy gets rock hard, it is a good idea to spend a little time now.
And remember to clean the hole for the wedge.
Clamped up.
Ohh yes and two mistakes here!
The picture is not sharp and I made a hole to close to the bed…
So a quick repair (yes I do like to show my mistakes also).
Making a little wood pin from the same wood as the plane.
Dipping in glue.
And hole in one…
Now the plane body has to dry for 16 hours before the clamps can be removed.
So it's time to split the blog here.
Next part will be making the shoulder plane iron (in this version from an 'old' plane blade).
I hope this blog can inspire others to go for a low angel shoulder plane, or any plane at all, the satisfaction by making your own plane is priceless.
Thank you div for playing with me my brother.
Best thoughts,
Mads
Your solution works-its all good. What I was saying - In looking at your drawing above, if the 12 degree angle was raised to 25 degrees for strength, with a blade that was double thickness, beveled down, the blade could come straight out the bottom. This would give you a 25 degree cutting angle, a 20 degree blade angle for the cutting edge and easy blade removal. The reason for the thicker blade is only to reduce the stress on the wood under the blade. The caveat is that the blade edge would be further forward.
What are your thoughts?
· Registered
Discussion Starter · #22 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
David, trust me, I try! Laugh.
Look what I just posted on Div's blog:
Grrrrrrrr,
I work on three different models now, two in real progress, one dumped… My workshop is a mess and I am sure I have wild eyes and look like a mad scientist. Nothing seem to work now!
Wood Hand tool Hardwood Wood stain Tool
But I still try, and I still have a wonderful time as I go after new ideas.
(I might end up throwing the towel and make it bevel down!).
Yes I am a mad man I know, and you are allowed to laugh as long as you do it sweet.
Best thoughts,
Mads
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
I can tell your discombobulated. No pipe in the photo….
· Registered
Discussion Starter · #24 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Do you know the song 'I belive I can fly'?
This is how I feel now!
Wood Beige Bag Khaki Hardwood
The answer was right under my nose.
I did it!!!
It's making wonderful shaves,
Jubiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
MaFe in space!!!
Best thoughts,
Mads
· Registered
Discussion Starter · #25 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Brown Wood Beige Rectangle Cuisine
Now dinner!
· Premium Member
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Hooray! I knew the low angle would be ambitious, but I also knew you'd succeed!
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Darn, now you got me thinking.
· Registered
Discussion Starter · #28 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Wish I could watch the video…impossible with my slow dail up farm connection. Sigh!
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Very nice. Sounds just like a plane should sound. I was a bit dissapointed there was no narrative. : ^ )
· Registered
Discussion Starter · #31 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Div, it is a video showing it in function, and as Wayne say 'Sounds just like a plane should sound'.
Wayne, thank you!
Big smile,
Mads
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Still wish I coud see it….maybe if I leave the computer to download, go make some coffee, drink it, go have a shower, read a little, make more coffee….
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Mads -
You did this as a bevel up plane? What is the angle of the bevel? I made a plane that I think is too low of an angle because it is too aggressive in the cut.
· Registered
Discussion Starter · #34 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Hi David,
I made a 25 degree bevel and a extra 5 micobevel as I remember.
Did you finish your plane?
Mine took a little running, at first it dig in to the wood but it was just until I got the wedge hollowed a little so it made a good preasure on the font of the blade, so it was not due to the angle or blade, but because it was not sitting firmly enough. The key to the lowangle to be working is this.
Best thoughts,
Mads
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
I will address this tonight. Mine is a lot larger - and may get smaller. The hole around the blade may be too large, don't know yet for the wedge to apply the pressure as you indicate. I will make a new wedge and see how that works.
I have a 23 degree edge with no micro bevel so the angle is a lot lower. The space or gap between the blade and the plane was too great and gouged the wood. Chips would not break so I had to cut out more material and glue a filler piece to reduce the gap. This helped a lot but this is still not finish quality shavings.
Forgot to mention, did some tests between bevel up and bevel down at the 23 degree blade. Bevel down did not shave the wood where bevel up did.
Many thanks
· Registered
Discussion Starter · #36 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
David you are between two chairs now…
With the really low angle you can only attac endgrain with sucess, but this takes that you hold the blade really solid.
So yes the wedge needs to be hollow a bit so it touch down in the front and back first when pushed in place.
Thre mouth on mine is app. 1,5 mm from the tip of the blade to the plane body opening and this works fine even it is quite big (I thought it would be a problem).
Best thoughts,
Look forward to follow.
Mads
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
This is where it gets interesting and the learning begins. Kind of fun how 5 degrees can make this amount of difference.
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
This is a picture of the plane. Made a few adjustments and it does work better but it still is slated for the fire wood pile. The next one will have several changes.
Mads - thank you for your help.
DIv - was looking at your plane and in comparing both yours and Mads, found some things that I will change. We'll see if it all works.
Many thanks.
· Registered
Discussion Starter · #39 ·
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Hi David,
I think you made a wonderful little plane there, congratulation you are now a plane maker!
When I see the plane the first I notice is that the wedge is really thin, I think you need a higher wedge to make a more strong hold on the blade.
You can try as a test to make the wedge hole higher and then see if it is enough.
Or if you really want to trash it, then try and put a screw right down the plane so that this will support the blade front, I am planning to make this in a more thought out way on one of my next low angles.
I think your mouth acually looks fine, like as if it was on purpose.
Cool stuff give your self a clap on the shoulder you acually build a shoulder plane!
Best of my thoughts,
Mads
· Registered
Because it's fun….
br>
Like this.
And cut off.
Time for tobacco.
Look how funny.
And cut!
Here we are.
And out it came.
Put the body apart.
Clamped up.
Dipping in glue.
And hole in one…
Best thoughts,
Mads
Thanks Mads,
The main problem is that as soon as it catches the wood, the blade starts to dig deeper. I think this is mostly due to the angle and the strength of the wood. Increasing the bevel to 35 degrees helped a lot but there is too much flex that you would not have with steel. May be the limitation with the wood, don't know but we will see. I will play before I scrap it.
