Depends on design? Suggest using both, solid wood and frame/panel.
Wood movement with the grain is negligible. It is the radial and tangential movement that creates issues.
Using 12" walnut sides, I would have no issue with solid wood for sides and shelves.
Normal movement range between 8-12% moisture is only ~1/8" for walnut. Plus the entire cabinet carcass will move same way.
The issue is 48in wide back and doors to cabinet.
Solid wood back needs to be half lap or tongue-groove joinery; with allowance for expansion between each board.
For the front doors, Suggest using frame and panel as best option. A solid panel will be hard to keep flat over time, and it will change 1/2" for same 1/8" change in the 12in sides?
YMMV
YMMV
