LJ Challenges
60849 Views 365 Replies 191 Participants Last post by  woodtek
4
Memories of 2011
March 13, 2012
It's challenge time!! And this is an easy one, well, kind of easy. Or maybe it isn't .. well I'll let you decide:
Sleeve Font Bench Logo Illustration
The Challenge
  • Look back through your projects, posted here at LJ in 2011, and select your favourite.
  • edit it to add the tag (in the tag section): challenge-12
  • deadline for this is March 31, 2012
The "Prize"
At the end of the month I will compile the entries in a digital "flipbook"
Each project will get its own page in the book
The digital book will be showcased here and on our LJ's Facebook & Google+ Pages.
Challenge Entries
All projects tagged as challenge-12
Gesture Rectangle Font Wood Advertising
(Note: Since this is our first "flipbook" I may have to edit the process as I start to put things together. Crossing my fingers!)
FYI: not all photos in the book will be the same size. It all depends on the size of the first picture posted for the project.
161 - 180 of 366 Posts
2
LJ event >>>>>FREE DRAW!!!! <<<<< deadline Dec. 20/13
December 14/13
Hendrik Varju is a well known furniture designer/craftsman who operates "Passion for Wood" near Toronto, Canada. He also offers woodworking courses and seminars and has been widely published in woodworking magazines in Canada, the U.S., the U.K. and Australia. In 2007, Hendrik started producing DVD courses and he has offered to provide some of them as prizes in Lumberjocks' contests. You can see the full list of all of Hendrik's DVD courses here http://passionforwood.com/woodworking/dvds.htm.
This week, the prize is Hendrik's first DVD course called "Jointer and Planer Secrets".
It is over 4 1/2 hours long and focuses on how to use your jointer and planer effectively to mill four-square lumber. It also has a long and detailed bonus section on edge gluing solid wood panels. You can read more about this 2-DVD set here: http://passionforwood.com/woodworking/dvds-jointer.htm.
It is valued at Cdn. $64.95 + taxes and shipping.
To enter this contest, just post a comment giving your answer to this question: "In your opinion, what is your biggest secret to successfully milling four-square lumber?" Post a comment before Friday, Dec. 20/13 and Hendrik will choose his favourite answer. Then we'll let you know how to claim your prize. Hendrik will ship it directly to your home at no cost to you.
Sleeve Table Font Wood Hat
Use hand tools to take down localized twist or high spots in otherwise straight boards before using the powered tools. I tried to do it all with powered tools once and ended up with boards too thin for what I wanted to do.
December 14/13
To own a planer and jointer.
December 14/13
Patience, winding stick and perseverance. Take the highs and lows from one side. Once a side is "flat" take it as a reference, flatten an adjacent side. Once 2 sides are squared, reference the 2 remaining sides, plane, check, plane, check, ... and after your "plane workout", you can feel great. The most important thing is to have a properly tune and sharp plane and a good square.
This is my way but there are many other ways. It works for me.
Yes if you have power tools, joint 2 adjacent sides on the jointer and plane it in the power planer.
December 14/13
If I had a secret to successfully milling four-square lumber I would share it with others.
December 14/13
I let the professionals do it for me..
December 14/13
I can't believe that you guys haven't figured it out yet - START with dry wood!
December 14/13
Go for the "rustic" look….
Then you can say the curves & waves are a design element!!! :^)
December 14/13
Step 1) Google 'What is four square lumber'...
Well, I don't have a clue, much less an opinion. That's one reason I'm here on Lumberjocks, to learn. I watched the preview provided in the link and am a little smarter. Thanks for sharing Hendrik Varju.
December 14/13
Still working on it, but I'll let you know if I ever find the answer.
December 14/13
Can't tell you, it's a big secret. LOL
December 14/13
How much wood could a Woodchuck chuck, if a Woodcuck could chuck wood? He'd chuck as much as a Woodchuck could … if he knew how to successfully mill four-square lumber!!!
December 14/13
Successful milling of four-square lumber (all four edges square to each other) is dependent on more than the technique used to feed the piece of wood being milled. My "secret" is to make sure that I take all the time necessary to ensure that the equipment being used is first accurately set up according to its specifications. If the jointer is not correctly set up to produce precise, flat surfaces at 90º to each other, the woodworker's efforts will be wasted. The same level of careful effort has to be spent on the planer in order to produce the required parallel surfaces. Once both machines are properly set, the various techniques of feeding the lumber can be successfully employed to compensate for bow, twist, etc.
By honing the performance of the tools, coupled with the required technique for the piece being milled, the resulting lumber should be exactly what you intended to produce. Then you still have the problems of storage and seasonal changes to deal with.
December 14/13
accurate setup
December 14/13
Ms. Debbie,
I'll be honest, I am very new to woodworking. Therefore, my only "secret" is to reach out to those who not only have experience with woodworking but also those who are willing to share and have patience with those like myself.
December 14/13
For me, I would say jointer technique. If you get two square edges off the jointer, you're home free. Focus on pressure, but not too much, and in the right spots as the wood travels across the cutter.
December 14/13
The secret I use to get four square lumber is a well setup table saw! And of course some jigs for that same table saw.
December 14/13
"With a twist, you must resist"
With a twisted board, I have found you must resist the urge to reset your push paddles. Keep the push paddles in the same place as the board passes over the jointer. In a few passes you will develop a flat, true surface to base your other milling on.
December 14/13
... and the winner is….. ((drum roll))
Marcus!! http://lumberjocks.com/comments/1737685
Congratulations
.. and a BIG THANK-YOU to everyone for sharing their wisdom.
December 14/13
Congratulations Marcus!! Thanks Ms. Debbie and Hendrik!
December 14/13
Woot! Thanks Hendrik and LJs, I look forward to killing an afternoon watching this.
