241 - 260 of 366 Posts
· Registered
>>>>>FREE DRAW!!!! <<<<< deadline Jan. 3/14
Hendrik Varju is a well known furniture designer/craftsman who operates "Passion for Wood" near Toronto, Canada. He also offers woodworking courses and seminars and has been widely published in woodworking magazines in Canada, the U.S., the U.K. and Australia. In 2007, Hendrik started producing DVD courses and he has offered to provide some of them as prizes in Lumberjocks' contests. You can see the full list of all of Hendrik's DVD courses here http://passionforwood.com/woodworking/dvds.htm.
This week, the prize is Hendrik's second DVD course called "Revelations on Table Saw Set-up & Safety".
It is nearly 10 hours long and focuses on table saw set-up and fine tuning and how to use the machine safely. It also has a long and detailed bonus section with a step-by-step tutorial on building a crosscut sled. You can read more about this 5-DVD set here: http://passionforwood.com/woodworking/dvds-tablesaw.htm. It is valued at Cdn. $94.95 + taxes and shipping.
To enter this contest, just post a comment giving your answer to this question: "What is the #1 table saw safety tip you would give someone new to woodworking?" Post a comment before Jan. 3/14 and Hendrik will choose his favourite answer. Then we'll let you know how to claim your prize. Hendrik will ship it directly to your home at no cost to you.
Hat Font Wood Flooring Baseball cap
Read the ENTIRE manual before you even unpack the saw from the box. If you do not understand something, there is no shame in asking an expert for help.
· Registered
Always, always know where your hands are in relation to the blade. Unfortunately, I learned that lesson the hard way.
· Registered
The only absolute answer to "How close is too close for my fingers!" is "In the blade!"
· Registered
Make sure that your table saw is turned off and unplugged before changing the blade or making and adjustment. And as Norm Abram always says don't forget these, your safety glasses.
· Registered
Don't let the excitement of a project cloud your vision; ALWAYS wear your safety glasses!
And…
Always remember the fear, keep those fingers in the clear.
And…
Get your shine on with tool illumination, its a brilliant idea!
· Registered
Always always always use a push stick your fingers are to precious not too
· Registered
Discussion Starter · #247 ·
And the winner is…..
lightcs1776
Congratulations and thanks to everyone for sharing their wisdom
· Registered
Never use your mitre and rip fence together. Kickback is dangerous.
· Registered
Keep your eyes on the blade. Pay attention!
· Registered
Discussion Starter · #250 ·
>>>>>FREE DRAW!!!! <<<<< deadline Jan. 17/14
Hendrik Varju is a well known furniture designer/craftsman who operates "Passion for Wood" near Toronto, Canada. He also offers woodworking courses and seminars and has been widely published in woodworking magazines in Canada, the U.S., the U.K. and Australia. In 2007, Hendrik started producing DVD courses and he has offered to provide some of them as prizes in Lumberjocks contests. You can see the full list of all of Hendrik's DVD courses here: http://passionforwood.com/woodworking/dvds.htm .
This week, the prize is Hendrik's third DVD course called "Working with Plywood".
It is almost 11 1/2 hours long and focuses on how to use plywood effectively in your projects. It also has a long and detailed bonus section with a step-by-step tutorial on building a stopped dado router jig, one of the most important jigs Hendrik uses in his workshop for working with plywood. You can read more about this 5-DVD set here: http://passionforwood.com/woodworking/dvds-plywood.htm. It is valued at Cdn. $94.95 + taxes and shipping.
To enter to win this contest, just post a comment giving your answer to this question: "What is the biggest difference, in your mind, between working with plywood and working with solid wood?" Post a comment before January 17th and Hendrik will choose his favourite answer. Then we'll let you know how to claim your prize. Hendrik will ship it directly to your home at no cost to you.
· Registered
I would say plywood is kind of affordable, and very stable if you get a good plywood. However, in my opinion, plywood will never "out-do" a good hardwood. That's my 2-cents.
· Registered
On the plus side, the number one advantage is width - easy, affordable width. Its hard to find wide hardwood boards, and quality glue-ups are hard to achieve. Add to that stability (no bow, cup, warp, twist, etc.) as a close second.
On the minus side, the edges need to be covered and thickness cannot be changed.
· Registered
The biggest difference to me is the accessories for the tools that are used, such as blades, bits, etc.
· Registered
None, I use ply wood as needed on a project. Or I can make the entire project out of it. It's just a different type of wood to me.
Ms. Debbie you were up far to early posting this.
· Registered
The stability and strength afford by the multiple layers of cross grain.
· Registered
Plywood certainly has its uses in many projects, My biggest beef with plywood is the varying thickness for sheet to sheet. When using hardwood I can control the thickness of my workpiece, with plywood you get what you get and must compensate for the variations. Bruce
· Registered
Joinery… no, Movement… no, Joinery… Ahhhhhhhhhhhhhhhhhhhhhh
(Monty Python may have impacted my youth a little more than strictly necessary?)
· Registered
For large projects, sheet goods such as plywood can be a real time-saver. Rather than jointing, planing and gluing traditional stock, plywood provides a quick, stable alternative.
· Registered
With solid wood you have to pay attention to all the details. Were is the project going to be used? How much will the humidity swing? How should I design my joints to allow for expansion and contraction. Plywood is much simpler in that sense. The beauty of plywood is in its ability to be used in creative designs not possible with solid wood.
· Registered
The biggest benefit (for me) to use plywood is stability; no movement due to weather conditions. I often use plywood for veneering projects. A close second is that plywood is much lighter than solid wood which makes larger projects easier to move. The biggest concern I have when using plywood is to not sand through the top veneer layer.
