LJ Challenges
60849 Views 365 Replies 191 Participants Last post by  woodtek
4
Memories of 2011
March 13, 2012
It's challenge time!! And this is an easy one, well, kind of easy. Or maybe it isn't .. well I'll let you decide:
Sleeve Font Bench Logo Illustration
The Challenge
  • Look back through your projects, posted here at LJ in 2011, and select your favourite.
  • edit it to add the tag (in the tag section): challenge-12
  • deadline for this is March 31, 2012
The "Prize"
At the end of the month I will compile the entries in a digital "flipbook"
Each project will get its own page in the book
The digital book will be showcased here and on our LJ's Facebook & Google+ Pages.
Challenge Entries
All projects tagged as challenge-12
Gesture Rectangle Font Wood Advertising
(Note: Since this is our first "flipbook" I may have to edit the process as I start to put things together. Crossing my fingers!)
FYI: not all photos in the book will be the same size. It all depends on the size of the first picture posted for the project.
181 - 200 of 366 Posts
3
>>>>>FREE DRAW!!!! <<<<< deadline Jan. 3/14
Hendrik Varju is a well known furniture designer/craftsman who operates "Passion for Wood" near Toronto, Canada. He also offers woodworking courses and seminars and has been widely published in woodworking magazines in Canada, the U.S., the U.K. and Australia. In 2007, Hendrik started producing DVD courses and he has offered to provide some of them as prizes in Lumberjocks' contests. You can see the full list of all of Hendrik's DVD courses here http://passionforwood.com/woodworking/dvds.htm.
This week, the prize is Hendrik's second DVD course called "Revelations on Table Saw Set-up & Safety".
It is nearly 10 hours long and focuses on table saw set-up and fine tuning and how to use the machine safely. It also has a long and detailed bonus section with a step-by-step tutorial on building a crosscut sled. You can read more about this 5-DVD set here: http://passionforwood.com/woodworking/dvds-tablesaw.htm. It is valued at Cdn. $94.95 + taxes and shipping.
To enter this contest, just post a comment giving your answer to this question: "What is the #1 table saw safety tip you would give someone new to woodworking?" Post a comment before Jan. 3/14 and Hendrik will choose his favourite answer. Then we'll let you know how to claim your prize. Hendrik will ship it directly to your home at no cost to you.
Hat Font Wood Flooring Baseball cap
Be sure your table saw is tuned up properly. Blade aligned to miter slot and fence lined up to the blade and miter slot.
Don't ever come near the blade with your fingers when the saw is turned on. This means using a push stick or a crosscut sled.
Always use a push stick and never force something through the blade… if there is some resistance when cutting, determine why before proceeding.
... oh and always wear eye protection.
After completing a cut on the table saw, never pull your pieces back toward you. Push both pieces pass the blade, turn off the saw and wait for the blade to stop before removing both pieces.
Be sure to use all the safety guards, i.e safety glasses, push sticks or blocks, blade guards, etc
Never stand directly behind the piece of wood that you're cutting. Stand off to the side
If it kicks back, you don't want to be in the flight path.
Don't be afraid of the saw, but use every safety precaution at your disposal with great respect for the power of the tool.
Always remember where your hands are.
Keep the fence between you and the blade. Reach over it with a push stick. Any kickback will not hit your body.
Spend some time with a trusted table saw user. It could be a friend, relative or professional instructor.
There is nothing like that immediate feedback.
I unplug mine when changing blades, and always have the blade height no higher the 1/8" above the thickness of the board I am cutting. I also periodically clean and wax the table surface so the piece slides more smoothly. Oh, and not touching that spinning thingie helps too.
Never, EVER, turn on a saw (or other equipment) when you are tired or distracted.
If you can't do the cut in a safe way don't do it at all
Be sure to read, understand & follow all safety precautions in the manual. Remember to always wear these, safety glasses. (said in my best Norm voice!!!)
Read the manual…
Properly adjust (& maintain) the saw…
Use a sharp blade…
If it feels wrong/unsafe, it IS wrong/unsafe…
read, understand & follow the wisdom, contained within, Hendrik's second DVD course called "Revelations on Table Saw Set-up & Safety".
Keep your fingers away from the blade and never leave your workshop without them!!
Even though it has already been said, always turn off the saw at the first sign of fatigue! Sometimes it is hard to tell when fatigue or tiredness starts to set in. Usually when I start to get tired I start making mistakes, like having to make the same cut several times to get it right. No matter what your deadline is or how close to finishing the project, it simply is not worth it. My neighbor nearly lost a hand trying to finish the last two pieces of one his projects. Stay safe.
Safety is always 1st priority, safety glasses, hearing protection, dust collection, etc. Learn the how's and how-to's of your saw/equipment is operated. Keep it tuned. Keep the surface clean and slick. This is more than one, but, I feel you need to do all of these before plugging it in/giving it life.
Respect the power of your TS, it is an inanimate object that does not know the difference between a finger and a piece of oak.
I think the biggest safety rule would be never work in a hurry.
