are there any good third-party replacements that are cheaper?What I like about the Rikon is the bearings vs the ceramic guides on the Laguna. As was pointed out of YouTube they aren t solid ceramic they are only a coating which wears out and the replacement cost is $100 dollars!
- mgmine
thanks, i think i'm def leaning rikon cuz of warranty and price of bearingsSorry I don t know if there are any good 3rd party suppliers. I went with the Rikon and couldn t be happier. This my 2nd one and I only got the new one because I liked the newer bearing system better. I sold my older one for a hundred less than I paid for it and ended up with a brand new saw for not much extra money.
- mgmine
I am pretty sure there are no third party suppliers of the ceramic inserts. Space Age Ceramics makes them and they don't even have the Laguna versions on their site. However, the cost of replacing the guides should not be a deciding factor. You will replace the bearings on the Rikon many times before you wear out a set of the ceramic guides. The ceramic guides have no moving parts and are so much harder than the blade backer it would be rare if a hobbyist ever wore a set out. I have seen a couple that have been well used in hobby shops from the early days of Laguna supplying them that have no visually perceptible wear.Sorry I don t know if there are any good 3rd party suppliers.
interesting, i might still lean rikon cuz of warranty but now you have me thinking….Sorry I don t know if there are any good 3rd party suppliers.
I am pretty sure there are no third party suppliers of the ceramic inserts. Space Age Ceramics makes them and they don t even have the Laguna versions on their site. However, the cost of replacing the guides should not be a deciding factor. You will replace the bearings on the Rikon many times before you wear out a set of the ceramic guides. The ceramic guides have no moving parts and are so much harder than the blade backer it would be rare if a hobbyist ever wore a set out. I have seen a couple that have been well used in hobby shops from the early days of Laguna supplying them that have no visually perceptible wear.
- AHuxley
Guide bearings are considered a wear item and not covered under warranty unless they are DOA. With heavy use, one will go through maybe a set a year possibly two sets of bottom bearings. With light use, say once or twice a month, it is possible to get several years before having any issues.With the 5 year warranty from Rikon they would replace them for free if they did wear out.
Don't worry about the bearings, you can get after market sealed bearings for under $1 dollar each. I'm not sure what others use their saw for but I consider myself a typical home user and have never had to replace a bearing on any brand of band saw that I have owned. I have had to replace bearings on the table saw and got aftermarket ones for a fraction of the cost that Delta was selling them for. Go for the saw that you want just don't get something like a Grizzly.do you think using graphite spray on the bearings might help? the graphite dries so im guessing the bearings shouldn't gunk up, haven't tested it though
- phillywoodshop
