Welcome to LumberJocks, AESamuel.
First, wax offers absolutely no protection. Wax gives a nice silky feel to a piece and can make future cleanings a bit easier, but does not protect at all.
As to something that adds more protection - how much do you need? Danish oil has a small varnish component, so it does build a thin film. But a straight varnish, shellac, lacquer or polyurethane will build a thicker film and offer more protection.
It would be better to forego the Danish oil if you are planning on topcoating it with varnish, lacquer or poly. Shellac is OK on top.
If you are using a tinted Danish oil to achieve a certain color, you can replace that with a wood stain, followed by a topcoat. On the other hand, if you are using the clear (natural) Danish oil to achieve that oiled look, you could substitute with a pure oil like tung oil, boiled linseed oil or even walnut oil. (Avoid anything labelled "teak" oil) After it is completely dry, you can topcoat.
