After my 5 year old 6" Delta jointer began to taper boards I decided it was time to take the time to tune it and bring it up to spec. Here's the problem I've encountered in attempting to achieve co-planar tables. The leading edge of the outfeed table (next to the cutter head) is .004-.005" lower than it's outer end. This is the opposite of a drooping table which is what I expected to find. Downward pressure on the outboard end will not lower it to or below the level of the inboard side. I cannot figure how to shim up the leading edge side of the outfeed table. If anyone can point me in the right direction I would really appreciate it.
Thanks,
Jerry
Thanks,
Jerry
