Hey all!
I've just put together a Grizzly G0490W - 8" Jointer with Parallelogram Beds and started to check/ set up the beds before using it. How accurate do you guys set this up before it's acceptable to use?
I'm using "this 50 straight edge and started by checking the individual beds with some feeler gauges.
The outfeed table has a dip in the center about .0015".
The infeed table has dip at end furthest from the cutter head (far right) by about .003".
The outfeed table is also .0015" higher on front vs. the back towards the fence.
Are all of these things "close enough" to deal with and start aligning the infeed table to be coplanar with the outfeed?
When it's off like this do you just lose more material after planing & ripping? or will joints actually be off.
Thanks for the help!
