1 - 3 of 3 Posts
I havent dont any fancy joinery yet. I have a double kreg pocket hole and an Incra LS router table and positioner.
Looking to get into joinery to make pieces without screws BUT I cant decide on what would be best and cost effective.
Of course if $$ was no object I'd have a Festool Domino ordered. I was looking at the Porter Cable 557 biscuit joiner BUT then I came across these below.
Dowelmax
Jessem Dowel Jig - Either 8350 or the 8300 Paralign. Not sure the real differences.
MLCS Horizontal Router Sliding Table LINK
I can't decide on what would be best to buy and use. The MLSC is only $220 shipped with the sliding XY platform. I have some bits already and just need to add a Bosch fixed plate. This would be the cheapest.
I like the portability of both the Dowelmax and Jessem setup. Cant decide if the 8350 or Paralign 8300 is better/what different.
I like to use real mortise and tenon joints. The minimum equipment needed is a benchtop mortiser and basic dado blade for your tablesaw. You will use the dado blade for rabbets, dados, and grooves anyways so it is a good starting point.
Otherwise you could get a plunge router with edge guide, and make loose tenons to fit. Every shop need a router, so I don't see how you could go wrong.
Use traditional joinery. Mortise & Tenon, Dovetails, etc. You don't need any of that fancy stuff. All you need for a mortise & tenon is a hand saw, a chisel, and a mallet. Anything more just makes stuff easier.
I use a router and a homemade tablesaw tenon jig for M&T joints. I doubt any of the above would be any easier than that. It would certainly cost more money.
EDIT: A benchtop mortiser isn't needed like Pinto says. It just makes it quicker. You don't even need a dado blade for the tablesaw.
1 - 3 of 3 Posts
