JET - 40" Speed Clamp ( Bar clamp ) 4" throat (Rating: 4)
These clamps were needed to reach over my pipe clamps during complicated glueups. The long 4" throat can accomplish this easily. The handle is large enough in diameter for good clamping pressure, and they easily closed all of my mortise and tenon joints with no gap.
Cons: The clamp pads fall off easily. This is easily solved with a dab of silicone caulking.
The slip clutch occasionally slips when you don't want it to. I usually prefer clamps with a trigger for just this reason. All in all not bad clamps to add to the arsenal, and for $12 each at Woodcraft I couldn't turn them down.
