Introduction
When we moved to Santa Fe last year, I had planned to build new bookcases for the house. In my old house in Minneapolis, I had built-in bookcases, and the house here in the Southwest needs a different look.
So I looked around a little, and decided to build the Jefferson Bookcases that Chris Schwarz wrote about for Pop Wood.
Given that I'm in Santa Fe, and getting nice hardwood is tougher here than I'm used to from Minnesota, I decided to build them in pine. I can get nice clear pine from Alpine Builders Supply here in town, and while it's not cheap, it's not going to break the bank.
So that's the back-story. I'm planning to write up the build process as I go, though likely I'll be behind on writing it up (I have four plinths and one case built as I write this), in part because I'm not great at taking all the photos I need as I'm building. But luckily there are enough repeated parts that I've been able to go back and get photos of every step of the way. That means this will be a lot longer than the Pop Wood article I linked above, but will also include a lot of the wrong turns I took along the way, and tricks I figured out to make the build go smoother.
As for parts, there are going to be at least six plinths, holding a stack of cases a minimum of five cases high on each stack. And that won't even get the paperbacks - I think I'm going to put those in cases that'll hang on a cleat on the wall above the stacks of cases.
Did I mention that I have a lot of books?
