1 - 15 of 15 Posts
· Administrator
Discussion Starter · #1 ·
From the Navigation Bar at the top of the community, click on Journals.
From the Journals page, click on Add item in the right-hand corner.
A popup will appear at the top. Click on Journals.
A form will open for you to fill in the blanks, such as title, tags, and Journal Content.
Add content and images like you would for writing a post within Journal content. The first image added will be the cover photo.
Click Preview or Save at the bottom.
If you want to make any changes, (after posting) including choosing a different cover photo from the images you added, you can do so by editing your showcase.
Above Comments, click on the Kebab (3 vertical dots).
From the drop-down menu that opens, select Edit item.
From here, you will be brought to the editor used to create the Journal, and you will be able to make changes or add content as needed. Before clicking Save at the bottom, you can add a checkmark to post as an update if you are working on an ongoing Showcase. This will alert any followers to any updates you make to your Showcase projects.
- Cricket
· Administrator
Awesome Cricket - and thank you for all the hours that you have put into this.
Is there a time limit on editing the text or photos after the journal is started ?
· Administrator
Discussion Starter · #4 ·
I will dive deeper into this, but it may be the same as the rest of the community.
Members have unlimited editing of new posts for the first 24 hours after posting. After that, up to 10 existing posts (older than 24 hours) may be edited per week. Additional editing will be allowed as each of those 10 edits expires every 7 days
And, is there a photo limit on each entry?
The default is no more than 20 images uploaded per post. However, you can also add images from your gallery. You can see an example here.
· Premium Member
So..IF I need to add the next chapter in the series....all about the same Project...do I just add to the Comments or start another entry? Episode #2 and #3 are sitting and waiting to post..somewhere...
· Administrator
Discussion Starter · #6 ·
You can edit to add to the same journal if you want. It's really your choice.
· Premium Member
Just added a LONG comment, with a few pictures...when I posted it..LONG delays, they the error banner...then the double post again....I went and deleted the second one....
#3 will be in a little bit....resaw work...will see how that posts...
· Registered
The Series Name field is where the individual section subtitle should go, correct? For example, "#1 Getting Started". If that is correct, it would be nice if the Series Name field was reflected on the Journals page to be able to differentiate the posts for each part of the series. The Journals page currently only shows the main title of the journal and its description. Could the Series Name be added underneath the description on that page?
· Administrator
Discussion Starter · #10 ·
I am not sure I fully understand what you are saying yet. You are referring to Journals is that correct?
If you are doing part 2, you would start a new journal using the old title but add the series name as well.
You would use the full title and episode number where it says Series Name.
As an example, if the Journal you started was titled Bench Build Progress and you wanted to do a part 2, the title of the Part 2 Journal would be Bench Build Progress Part 2
Make sure to add that title at the top and where it says Series Name.
· Administrator
Discussion Starter · #11 ·
Also, even though I have the following account preferences:
Journal entries that I create aren't automatically followed. When I Follow manually, I don't receive any email notifications of posts.
I am still testing this. The Content options setting you are referencing is for community discussions.
Please see the following tips.
· Banned
My question would be, before starting a Journal what is the purpose of same? It appears that the new site has changed the names and in some cases the purpose of various parts of the site?
I know I know go to FAQ.
Or is there a single help page that describes the offers an overview of the entire site? You know one of those dictionary type pages.
· Administrator
Discussion Starter · #14 ·
The FAQs also include a glossary.
Please see the following sticky announcement.
· Banned
Clear as mud.
Nothing at all personal Cricket, I know you're doing the best you can BUT I hate this new site!! It is NOT intuitive at all!!! And I am very good with a computer.
1 - 15 of 15 Posts
