1 - 4 of 4 Posts
Discussion Starter · #1 ·
Hope Chest
Hello everyone,
I am a beginner in woodworking. I have made a couple of mantle clocks courtesy of a Wood Craft class. I am now attempting to make a Hope Chest for my daughter's 16th birthday. The exterior is cedar and the base is Paduak(sp?). I made plugs of Paduak to cover the screws. To gain some weight and solidity I placed a piece of 3/4" plywood at the bottom. The interior is covered in aromatic cedar. I am now trying to find a good finish for it. I have experimented with Tung and Danish oils but did not like the results. I live in FL and was told by the people of Wood Craft that the Tung oil does not hold up well in FL anyway. I believe this chest will take a beating during it's lifetime so whatever finish I use I plan on covering it with an epoxy. Does anyone have any ideas as to what base finish to use? I have been working on this chest for over a year. I am a disabled veteran and sometimes cannot make it out of bed for days at a time so I can't afford to make too many mistakes as her birthday is next month. I do have several pieces of cedar leftover to practice on. Any suggestions would be greatly appreciated.
Respectfully,
Thomas Stone
Hope Chest
Hello everyone,
Respectfully,
Thomas Stone
Most people usually leave the inside of cedar unfinished…
but as for the outside, I would recommend a few coats of Poly. I used that on some pieces in the deep south, that get used quite often, and they are still holding up well.
Discussion Starter · #3 ·
Hope Chest
Hello everyone,
Respectfully,
Thomas Stone
Thanks. I plan on leaving the aromatic cedar as is, it is the exterior I am worried about. I am leaning towards the Poly. Do you think the epoxy will adhere to it?
Hope Chest
Hello everyone,
Respectfully,
Thomas Stone
Going with epoxy is not necessary.
If you do not have any finishing equipment or experience, stick with a wipe-on poly and apply several coats. The coats go on thin so you can't hardly mess up and clean up is a snap.
The thin coats also will dry faster than if you brush or spray. But the down side is that you will have to more coats. But that is not a big deal, you are shooting for a successful finish that will look good and be durable. You should be able to achieve both.
1 - 4 of 4 Posts
