1 - 20 of 204 Posts
Discussion Starter · #1 ·
Perfect Splined Mitre Joints in Five Minutes Without Clamps
When I posted "Arnie's Tea Box" http://lumberjocks.com/projects/50187 one of the comments (Roger) was that these boxes make a great venue for displaying my marquetry. I totally agree but that meant streamlining the process of making the box. First was to come up with a jig to make the corners perfect every time quickly.
Here is what I came up with.
Disclaimer: I'm not a jig person so my jigs are usually utilitarian and often "throw away".
This photo shows the parts disassembled. Dimensions are irrelevant and I didn't take any so even I don't know them.
Wood Rectangle Hardwood Flooring Beige
Here the base piece has been turned right side up. The groove is for the pin in the top part. The cutouts at the apex are to insure that no glue contacts the jig.
Wood Triangle Rectangle Table Clock
Assemble the top part onto the bolt and adjust so that the spaces on the sides fit your stock width. Then slide the pieces of your box together until they match perfectly.
Wood Rectangle Gadget Beige Hardwood
Now remove one piece without moving the other. Coat the end with hot hide glue….Oh yes, this is a commercial for hide glue, sorry. But please bear with me.
Wood Textile Drinkware Dishware Serveware
Slide the piece back in and as the jig does most of the work, simply squeeze the top of the joint for about 15 seconds or so.
Wood Nail Thumb Finger Material property
This is the joint removed from the jig about 30 to 45 seconds after the glue was applied. It's already strong enough to hold together.
Furniture Wood Table Outdoor furniture Chair
A minute later it is strong enough to have it's spline grooves cut.
Wood Rectangle Triangle Flooring Hardwood
Wood Triangle Flooring Hardwood Plywood
Rectangle Wood Triangle Shipping box Packing materials
A little more hide glue on the splines and slip them into place.
Wood Flooring Hardwood Composite material Rectangle
In the time it takes to walk over to the band saw the splines are glued well enough to trim off.
Wood Rectangle Hardwood Beige Flooring
The glue is easy to rub off with your finger. It will ball up like rubber cement. You can throw it back in the pot if it's not too contaminated with sawdust. Then you can sand the joint and you're done. The elapsed time between this photo and the one where the pieces were dry fitted is under five minutes and with the splines now in place the piece is strong enough to continue to handle and work with.
Automotive lighting Rectangle Wood Flooring Bumper
Of course in real life it is not necessary to get things done this quickly. Pieces can sit while others are fitted and glued, but this is how fast it can be done.
This joint is perfectly square, both vertically and horizontally, despite the fact that if you look closely, my "hot off the miter saw" cut was not.
That's it
I made a jig. Who would have thought.
Thanks
Comments, questions, critiques are always welcome.
Paul
That's it
Thanks
Paul
Very simple … cool idea….
That's it
Thanks
Paul
It's so good i'm planning to use it. Hope you don't mind.
In Loving Memory
That's it
Thanks
Paul
This I can understand! Nice jig Paul.
That's it
Thanks
Paul
Sweet.
But you have to include the time to heat up the glue. Which I have no idea how long it takes. So, how long does it take?
Nice jig,
Steve
That's it
Thanks
Paul
Great idea Paul, keep'em comin'.
Banned
That's it
Thanks
Paul
Great jig…simple and effective. Thanks.
That's it
Thanks
Paul
I think this jig would be valuable for anyone building mitered boxes. A little sanding jig for touching up miters on a sanding disk is also a good idea if anyone is having trouble with perfect miters. I think the idea of boxes as a venue for you marquetry is excellent. There have been some fine examples of marquetry boxes here at LJ, and I'm sure you could make some wonderful additions to that collection. I couldln't agree more about the use of hot Hide Glue, it has the strength and many more convienences the modern glues don't.
That's it
Thanks
Paul
It looks like it does a great job Paul. You may just become a jig-man. :) I'm puzzled in how you insert the bottom or the top though. Rabbet I assume? If so, how do you account for expansion? Hey, thanks for sharing.
Discussion Starter · #10 ·
That's it
Thanks
Paul
Thanks all.
Steve you plug it in in the morning or before 15 minutes before a gluing session and unplug it when you leave the shop. If you're using it much, it's always hot.
Rance I used a floating PW bottom in Arnie's Tea Box and the top is my favorite substrate, MDF, dimensionally pretty stable. I don't anticipate any problems. I won't use that top style again though - too hard to glue in nicely.
LittlePaw Fill yer boots. Glad to help.
Thanks again.
That's it
Thanks
Paul
Paul,
Your blogs are great!! Keep'em a comin!!!
Thanks for sharing!!
That's it
Thanks
Paul
Paul,
Thanks for sharing your brilliance with us. This is such a great learning place.
L/W
That's it
Thanks
Paul
Very interesting jig.
Thanks for all your blogs thay are quite informatyive.
That's it
Thanks
Paul
Hide Glue.
Time to bring the pot back out. I haven't fussed with it in a while. The time feels right.
That's it
Thanks
Paul
Good to know there is someone else out there who uses hide glue!! I started about 2 years ago & wish it had been sooner. Great jig BTW!
That's it
Thanks
Paul
GOLLY! Had no idea that Hide glue dried SO FAST!
I'll have to look into that stuff… a little more…
You have a Pot (electrically heated?)...
Can you leave the glue in the pot at all times?
How long does it take to get the glue liquid?
We know it dries FAST… How strong is it for the long haul?
How about water problems?
COOL little jig! Nice job!
Thank you.
Discussion Starter · #17 ·
That's it
Thanks
Paul
Hi Joe
There are several articles on hide glue available on the internet. Here's one: http://wpatrickedwards.blogspot.com/2011/05/animal-protein-glue.html
Patrick is probably as much of an expert as you will find and he has several other articles about it.
Since I got through the initial learning curve, and there is one, I have almost never gone back to my pva bottle and will only use it occasionally for convenience.
1) I have a "Hold Heet" pot now but successfully used a Rival kettle for some time. They work well but the pot is well worth the initial investment.
2) Yes, as long as you don't let it go bad the pot never needs emptying
3) The granular, flake, or bead form must be soaked for a while before it can be heated and liquefied. The actual heating takes around a half hour. You can keep the hydrated gel that you get when you soak it in the freezer in little blocks to save prep time and once you get the pot hot in the AM you can leave it on all day.
Just remove the pot liner with the glue in it and put it in the fridge over night and it lasts very well.
4) It comes in various strengths for various uses but it is one of the strongest glues there are.
5) If you get it wet and warm at the same time it will re-liquify. Is that a problem or an asset? If you are talking about indoor furniture, that's a huge asset. for veneer work, an even bigger one.
Do some internet research.
You will be impressed.
I think the main reason it has fallen into disuse is that "modern" glue manufacturers have done a great marketing job.
That's it
Thanks
Paul
It was very interesting, Paul. I appreciate it.
That's it
Thanks
Paul
I am very happy I joined Lumber Jocks. This is one of the greatest places to get great information and I just love it. Please keep up the good work and I will be adding some of my expertise in the near future.
Peter Apicella
www.petestradingpost.com
Discussion Starter · #20 ·
That's it
Thanks
Paul
Welcome Peter
This may be the greatest place but it can be very addictive.
I look forward to your posts
1 - 20 of 204 Posts
