1 - 4 of 4 Posts
I got a HF 8" bench grinder. When I flip the switch, it takes about 7 seconds to come up to speed and it vibrates some. My old 6" bench grinder comes up to speed in about 2 seconds with little vibration. What could be the problem? I bought it because it had good reviews and I had a 25% off coupon.
Mr Ron,
I can't be of much help on the start up time, but as far as the vibration, my first test would be to swap out the grinding stone(s) to see if an out-of-round or out-of-balance wheel is causing the vibration. If possible, use one of the wheels from your other grinder.
If you know that they do not cause vibration on your other grinder, but there is vibration on the HF grinder, then the HF grinder is out of balance. It could be the motor, the bearings, or perhaps a bent shaft. In the event that it is one of those, I'd take it back and swap it out for a new one.
The HF grinders are not bad. However, I have heard all kinds of comments on the wheels provided with them. I've heard that some are poorly made and have exploded during grinding.
Good luck.
Cheers!
The problem is that it's from Harbor Freight. I think their quality control is 'if it doesn't get returned then it was good enough.' It takes forever to come up to speed because the motor is undersized for the load. I'd return it and get a Craftsman at the very least.
Up to speed isnt really important maintaining speed under the load you wish to apply is. you can substitute a larger capacitor to a point if it bothers you. check the stones both for run out on the circumference as well as side to side. the retaining washers could be bent or sometimes the label interferes with a good set. try dressing them.
1 - 4 of 4 Posts
