Herringbone & Wood Expansion, Is It An Issue?
552 Views 2 Replies 3 Participants Last post by  xedos
2
I'm considering a herringbone wood accent on our kitchen peninsula, kind of like the picture below, but I think a herringbone pattern would look neat, instead of the typical horizontal or vertical board arrangement. The build would be 11' x ~3' and only one species of wood, hickory. Ideally I'd just pin nail each board in place on the existing cabinet and not have any amateur-hour gaps.
I have yet to find a herringbone install of anything (table, wall, cutting board) that explicitly addresses wood expansion. It feels like it should be a problem to design around. Thoughts?
Countertop Cabinetry Wood Kitchen Floor
1 - 3 of 3 Posts
I cannot answer your question exactly but I would look at how herring bone floors patterns are laid down. Those usually have a tongue and groove and I think that they only attach the tongue side to the subfloor with nails and no glue. They often have bevels along the edges so that any gap that form from shrinkage won't be as obvious and the tongue also helps to hide the gap. Note that you need the tongues and grooves and also bevels if you go that route on the ends too. In a way, it probably works a little like a ship lap backing on the back of a cabinet.
Wood expands and contracts with seasonal and moisture changes. There's no designing "around" it - you design and build "for it" . It's gonna happen.
Minimizing the amount it moves to an acceptable level is the name of the game and those strategies are common knowledge.
1 - 3 of 3 Posts
