1 - 7 of 7 Posts
Getting interested in a hanging tool cabinet. Tired of my tools getting rusty, even after oiling. I don't mind having to oil, but having thousands in hand tools, it's worth it to store them properly.
Those of you with hanging tool cabinets, what would you add to yours looking back? Or anything you'd do differently?
I found one image of the center section containing the planes, on an incline, with the doors having saws and the like with drawers below the planes.
There are a lot of hand tools i don't yet have but will likely aquire and I'd like to leave room for them in the future.
Any suggestions? Also feel free to post yours.
Tool Hand tool Household hardware Metalworking hand tool Shelf
Shelf Door Wood Shelving Rectangle
Hey lateralus819
My cabinet is a work in progress. Here's a couple of pics to see what I have achieved so far. i plan on adding a second panel in front of the chisels that will hold my squares and various measuring tools. This panel will swing out to allow access to the chisels behind. My woodworking skills are at the begginer level so I've opted for the KISS theorum (Keep It Simple, Stupid) for this project.
Scott
The main case is 40" x 40" - each door is 1/2 that - so it opens up to 80" x 40". I think the main case is shy of 12 inches deep and the doors are shy of 4 inches deep. So closed up it is 15" deep or so. Made from birds eye and other figured maple. I wanted to be able to reach the miter box on top and tuck a bench below, and I didn't want to cover the windows flanking it on left and right - so that drove the dimensions.
I started by marking the case out on the wall using blue tape and making sure I could reach stuff easily. I also wanted it to be a shallow as possible (to not block windows) but still have enough depth for the leaning plane till. So that drove the depth.
The miter box saw and my long straight edges are too big to fit inside - they ride outboard (behind the doors).
I've only been using it for 8 months or so - so far I am satisfied with the design. I still have a little room for growth, and if I needed to, I can reconfigure the inside (nothing is glued - it is all fitted / screwed).
Andrew
I've changed mine around a couple of times, but the basics have remained the same… Planes in middle, chisels and layout on the left, and saws on the right. Now there is a small saw till in the middle and I added a small bank of drawers. I found that there were alot of small parts and tools that were floating around the bottom of the case and needed a home!
Wood Gas Hardwood Machine Electrical wiring
Wood Electrical wiring Gas Engineering Wood stain
Wood Window Door Wood stain Hardwood
1 - 7 of 7 Posts
