161 - 176 of 176 Posts
· Registered
First Hand-Cut Dovetails
I finally got a chance to practice hand-cutting dovetails. This is the first time I've made a cut with my new Japanese dovetail saw and use my new bench too.
I started out with a couple scrap pieces of pine:
DSC_6591
I drew the tails:
DSC_6592
First cut… didn't follow the line so well. It will take some getting used to.
DSC_6596
Here are all the cuts. Some are pretty good and some are pretty far off the line.
DSC_6600
This photo is AWESOME. Because as you can see, I did a beautiful job at chopping away my tails (instead of the waste). Notice the X's that should not be intact…
DSC_6604
Ok, take TWO…
Not even close:
DSC_6607
A lot better:
DSC_6608
Chop, Chop, Chop:
DSC_6609
Not bad for 2nd try:
DSC_6611
Cutting the pins went well. It is easier to saw straight down vertically then at an angle like the tails. Here are the pins being chopped:
DSC_6614
It did take a little chisel work to get them to fit but not too much.
And here it is (first completed hand-cut dovetails)
DSC_6617
Lots better than my first.
· Registered
DSC_6591
I drew the tails:
DSC_6592
DSC_6596
DSC_6600
DSC_6604
Ok, take TWO…
Not even close:
DSC_6607
A lot better:
DSC_6608
Chop, Chop, Chop:
DSC_6609
DSC_6611
DSC_6614
DSC_6617
I have been learning how to do this in my class.
My tips so far:
When cutting tails the most critical factor is staying square across the top. If you miss the angled line, it is not important as that will just be the template for your pins. Square up these cuts by paring before moving on to tracing your pins.
When cutting the pins, split the line on the waste side concentrating on a square vertical line this time. Then the two pieces will mate.
When chopping out the waste. Start on the inside of the joint. and finish coming in from the outside to avoid chipout.
Yours look pretty good.
One suggestion: make your tails wider than your pins for visual impact.
· Registered
Discussion Starter · #163 ·
DSC_6591
I drew the tails:
DSC_6592
DSC_6596
DSC_6600
DSC_6604
Ok, take TWO…
Not even close:
DSC_6607
A lot better:
DSC_6608
Chop, Chop, Chop:
DSC_6609
DSC_6611
DSC_6614
DSC_6617
thanks!
· In Loving Memory
DSC_6591
I drew the tails:
DSC_6592
DSC_6596
DSC_6600
DSC_6604
Ok, take TWO…
Not even close:
DSC_6607
A lot better:
DSC_6608
Chop, Chop, Chop:
DSC_6609
DSC_6611
DSC_6614
DSC_6617
about half way down the letter
http://charlesneilwoodworking.com/newsletters/09-08.pdf
· Registered
Discussion Starter · #165 ·
DSC_6591
I drew the tails:
DSC_6592
DSC_6596
DSC_6600
DSC_6604
Ok, take TWO…
Not even close:
DSC_6607
A lot better:
DSC_6608
Chop, Chop, Chop:
DSC_6609
DSC_6611
DSC_6614
DSC_6617
Thanks CharlesNeil! Great newsletter. I like the block you clamped around your stock for horizontal chopping. I've never seen that before.
· Registered
Discussion Starter · #166 ·
100+ year old Disston Backsaw ...RESTORED
After some help from fellow Lumberjocks and a little research (here), I determined that this beautiful old backsaw is about a hundred years old (give or take).
"Before" photos:
After:
I carefully took apart old saw and put the blade through the electrolysis process. Then I stripped the handle (which was covered in layers of paint and dripped varnish)... and applied Shellac. I also polished the brass. This is the result:
DSC_6665
DSC_6656
DSC_6658
On a side note… Here's a little shop humor for you:
DSC_6671
DSC_6675
I also just finished a chest of drawers for my workbench. So all of my favorite hand tools have a really nice home now:
Happy woodworking everyone!
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Blake, You did a great job on the saw! ...the chair got a chuckle and the drawers show a craftsman's tools well!
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Nice looking saw. I have that same exact model. I know that mine was made between 1917-1918, so your estimate is really close.
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Great job on the saw looks new!
Your tools are well organized too.
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Very nice restoration. The little dings and knicks on the handle add a lot of character. The brass looks like new, what did you use to clean and polish it with?
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Nice sticker :)
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
I love old tools . You did a super job on the restoration
Thanks
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Very nice
· In Loving Memory
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Nice restoration and good save of a valuable tool.
· Registered
"Before" photos:
After:
DSC_6665
DSC_6656
DSC_6658
DSC_6671
DSC_6675
Nice work with the saw Blake.
