1 - 9 of 9 Posts
Hi,
I've seen some posts about TS injuries, and had a close call with my tablesaw recently. My TS I bought used (its a craftsman 113 series) and when I bought it, the blade guard and kerf splitter were removed (or never installed), I can order one for about $80 on ebay . . or I can pickup a GR-100 or GR-200 2 pack.
Is there any major advantage of the GR-200 over the GR-100? There's about a $50 difference between the two packs available at Amazon. . I really have not yet shopped around, but will.
http://www.amazon.com/Micro-Jig-Gripper-Deluxe-Package/dp/B000H50B9S/ref=sr_1_4?s=hi&ie=UTF8&qid=1410486665&sr=1-4&keywords=GR-100
http://www.amazon.com/dp/B000H50BAM/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=BS6O7S878OSC&coliid=II586S29F07WK
I've read the few Amazon reviews, and the reviews here and the quality/usefulness is not in question, just which model makes more sense.
Thanks for the tips!
They are the same basic model. The 200 just has more pieces added. You can get the extra pieces and upgrade the 100 to a 200, so it's not really an either or decision. I would also recommend adding their MJ splitter, or some aftermarket splitter, to your saw. I love my 200 and I think it's much safer then a push stick but you really need a splitter also.
They are the same basic model. The 200 just has more pieces added. You can get the extra pieces and upgrade the 100 to a 200, so it s not really an either or decision. I would also recommend adding their MJ splitter, or some aftermarket splitter, to your saw. I love my 200 and I think it s much safer then a push stick but you really need a splitter also.
- retfr8flyr
YEP!!
I have gr-100s and never use them. I don't
see much advantage in the expanded
models for general work… the basic ones
are simple enough to balance.
I like magnetic featherboards. Narrow rips
I do on the band saw.
Grippers so work. It depends on the type
of cuts you make. I use a guard so pushing
a Gripper over the blade is not something
I would normally do. I do recommend a guard.
Discussion Starter · #5 ·
Well it looks like I'm getting one as I accidentally one click ordered one while researching on Amazon this morning. It'll be in tomorrow.
I also intentionally ordered the blade guard assembly off of ebay.
Well see how this works out. I may go the mj splitter route if it does not work out. How easy is the mj to install?
Thanks
I want to add that all pricing I've seen for the upgrade components for the GR-100 to the GR-200 is the same as the price difference.
FWIW, I have two Grr-Rippers (GR-100s) and find that 60% of the time, I only use 1 of the for a given operation.
It seems to me that everytime we talk about Grr-ripper push block, the subject of cutting narrow strips comes up.
I don't have a gripper and but can't help wondering if this tool is mostly used by those who cut thin strips often and that's the only time a gripper will really shine,for other types of cuts,could a good push block do just as well?Also ,for longer pieces of wood ,1.1/2" or thicker,wouldn't you need two?$120 or more for 2 push blocks.
I see their prices are coming down,would like to order a couple but since I use a bandsaw to cut narrow strips,I am not sure if it's money well spent .
This is what I have been using:
Gesture Baseball glove Wrist Personal protective equipment Brick
I don t have a gripper and but can't help wondering if this tool is mostly used by those who cut thin strips often and that s the only time a gripper will really shine …
I have thought the same thing. Several years ago, I bought a device similar to the Gripper … it is still in pristine condition (never been used). My saw is equipped with over-arm dust collection and a riving knife. When I cut thin strips, I use a thin strip jig …
Font Rectangle Electronic device Electric blue Electronic component
1 - 9 of 9 Posts
