1 - 2 of 2 Posts
· Registered
Discussion Starter · #2 ·
I thought I had it. But still need to learn some more. Second and third pics are of the fan layout and cutting. Forth pic is the condencer that can be seen on the side of the motor. Fifth is the distributor, air breather canister, generator and voltage regulator. Sixth is the clutch assembly(This model has both foot and hand clutch.) The hand clutch is #4 solid copper. Seventh is clutch assby. mounted. Eight is motor block and assorted parts. Ninth is three point hitch handles and spacer. The attachements, first two are the way I add strength to butt 90 degree glue joints. I do not like for things to come apart. Those little gremlins do funny things at times. Enjoy
1 - 2 of 2 Posts
