1 - 2 of 2 Posts
Discussion Starter · #1 ·
Green and yellow tractor rear axle wheel nuts
Wood Table Plastic bottle Water bottle Road surface
Gas Lego Toy Electric blue Plastic
Wood Natural material Composite material Plywood
Wood Art Font House numbering Sculpture
Wood Tool String instrument Shadow Broadaxe
My axel is a 7/8th in allthread bolt that I took out of an electrical high line structure(Tear down) when I was a lot younger.. My wheel nuts i hand made(a lot of hand work) from the square nuts used on the pole structures. On the 4th photo you will see the roll of masking tape. It was what I used for the radiuses for the cut outs. The wood was clamped into the threads of the bolt plus a little epoxy.
Table Wood Gas Circle Tire
Automotive tire Road surface Wood Asphalt Gas
I put a couple of coats of clear coat on the made nuts and use lock tite(blue) to hold them in place.
Art paint Paint Art Rectangle Wood
This is my paint station. The green tint is covering up the yellow tint from my Cat models.
Wood Rectangle Motor vehicle Machine Plywood
The 1/4×20 seen on the ends of the axle are for attaching fenders and different tool attachments . I used self locking nuts so they will not be lost. The long all thread is to attach the axle to the main body later.
Green Wood Gas Machine Motor vehicle
Automotive tire Tire Gas Automotive wheel system Machine
These photos show the axle attached to the main body. Enjoy.
Premium Member
amazing detailed work !!!
1 - 2 of 2 Posts
