Green and Greene Style Clock
21096 Views 11 Replies 9 Participants Last post by  WoodArtbyJR
Opertation Mill Stock a Success! Well, Sorta
So I decided to build a Greene and Greene Style Clock after visiting the Gamble house in Pasadena earlier this month. To do this though, I was going to have to locate material for the project and the plans called for a lot of varying thicknesses of material like 1/4", 1/2", 5/8" 3/4" and so on. I could purchase the pre milled wood that any Rockler or Woodcraft carries but this would mean using material from different trees most likely and trying to get the grain and color to match up closely would be a problem. I decided to bite the bullet and get a planer and mill my own lumber for once. I scoured Craigslist till I was lucky enough to locate a DeWalt Planer in great shape and for a steal to boot. Now hopefully it wasn't a steal (literally) for them as well. I ventured up to Edensaw up in Port Townsend my last day off and picked up some 4/4 and 6/4 Mahogany and almost left with far more than my wallet would allow. thankfully I just drooled a lot and left with just the Mahogany and next months rent intact. Today, I attacked the material, preparing it for the actual clock build. Immediate I encountered a neat little trick the planer does. I immediately jumped on the web and searched out ways to mill the stock flat with my fancy schmancy new planer and realized right quick a mantra I need to keep in mind. Warped in, warped out. My new planer, though amazing at making material the desired thickness is no way capable of making said material straight. I can get the material close enough for government work but if I plan to make superb quality clocks I am going to be forced to purchase a jointer or I will have to be extremely careful in my selection of raw material in the future. It would seem that a Jointer/Planer combo is a must to get good quality Flat material for my projects. So now it is back to Craigslist I go, in search for a jointer I can afford that will undoubtedly not fit in my shop just so I can get material worthy enough to be a part of my project. It's a never ending cycle isn't it? Does one ever come to a point where one has enough tools to do the job?
1 - 12 of 12 Posts
Enjoy the challenges while you are still young enough to work 24-hours a day when you want. Remember you can always use a hand plane to flatten stock like they did before joiners were commonly available. And, to answer your question about ever getting enough tools: no, because you always discover something you don't have (note I didn't say need); and, yes in the sense you have everything you once dreamed of owning but your health and stamina have been robbed by the years. Enjoy every project!
An alternative to buying a jointer is making yourself a planer sled to flatten wide faces. My uncle is a pro woodworker and he uses this technique exclusively. He doesn't even own a dedicated jointer!
I have a 6" jointer that you can come over and use anytime. I also have a small benchtop 6" jointer I am selling.
We talked a while back I live in Belfair, give me a call and we can work something out to use my jointer and it will only cost you a Dr. Pepper.
8
DIY Router table out of necessity... aka Skil bash!
Necessity is the mother of invention. I have this saying above the doorway into my shop because just about every day I am having to create something new to be able to complete what work I have set out for that day. Yesterday it was a portable router table to replace the piece of $#!* Skil router table I bought from HD some time back. The router table has always been a pain in my arse and was never truly good for routing anything well. When I milled all the pieces for my Greene and Greene style clock and it became time to route out the rabbits for the stiles I just about cringed when thinking about using that crappy Skil router table. I remembered all the curse words I used when making my planter boxes using the table and did not want to even touch this gorgeous Mahogany with that horrible waste of money and material that didn't deserve the title "router table". So, I scoured the internet and came across a video by a gentleman name Trip on Youtube. His channel SailingandSuch can be found here: http://www.youtube.com/user/SailingandSuch. the video on his portable router table peaked my interest and looked to be exactly what I was looking for. Armed with my new video knowledge, I headed to Home Depot to buy a quarter sheet of half inch plywood for my new table. I wanted to build this table from a quarter sheet of plywood for two reasons. One being that I had to get it into my car because the trailer has a seized bearing and two, I figured that there would be other people such as myself who do not and or can not lug around full sheets of plywood to and from. This will be the every mans router table!
So on to the build…
This is the start of all this. I bought this router a couple years ago from HD to do a bunch or round over work I was doing at the time. The table itself is not all that bad. As long as you do not need the fence and you do not mind that the router shifts with even the slightest pressure and moves all around making accurate cuts impossible… IMPOSSIBLE!!! I can't remember what I paid for it but I will never buy another Skil product again and will never buy something I can make myself.
photo(12)
I started out by cutting off a section 16 1/8" with the 1/8" to be cut off later when I glue up the stiffeners. I added strips to the underside to both stiffen up the top as well as give it a recess in which the table base would fit into and lock the top. I used a 1 1/4" forstner bit for the bit opening and used the base of my PC router to align center and mark the holes for mounting. I picked up some 3/4 inch 10-24 machine screws when I bought the plywood to attach the router base firmly.
photo(13)
The pieces were also cut and attached in this manor to maximise the quarter sheet of plywood. I wanted to get the entire project out of a single sheet and not have to use any more.
photo(14)
While the top was drying, I ripped all the base material and cross cut all the sections to final dimension
photo(15)
The legs of the base are glued at a 90 degree angle to greatly stiffen the table and make it more stable. in my original design before coming across Trips video I was going to use 2×4 material but I'm glad I went this route as it gives me more space to work with under the table and is rock solid.
photo(16)
I glued on the stretchers making sure everything was square and pin nailing it in place before adding clamps for good measure. The base sits perfectly flat and has no wobble at all when sitting on my table saw.
photo(17)
With the base complete, I was able to route out the grooves perfectly and have uniform depth throughout all the grooves, something I was NEVER able to do with the POS Skil router table. The fence in the picture was one I built for the Skil table because the plastic crappy one that came with it was not straight and would always cause the material to hang up on the back side of the bit and would shift all the time. You can use a piece of hardwood or even a 2×4 thats been trued up on a jointer clamped directly to the table as a fence.
photo(18)
With my new DIY router table, I was able to get perfect grooves and Rabbets making for a perfectly aligned and true clock case. This table it going to get a lot of use in the future, something I never would have said for the Skil table.
photo(19)
I'd like to thank Trip and anyone interested in building a DIY router table like this one should definitely check out his Youtube channel at http://www.youtube.com/user/SailingandSuch.
So on to the build…
photo(12)
photo(13)
photo(14)
photo(15)
photo(16)
photo(17)
photo(18)
photo(19)
Awsome job! That clock case looks very very nice. I don't think I have built anything as fancy as a clock case before. I'm interested to see how it turns out. Thanks for the mention!
So on to the build…
photo(12)
photo(13)
photo(14)
photo(15)
photo(16)
photo(17)
photo(18)
photo(19)
And you didn't buy a router plate and router lift for a fortune! Good on you. I know how rewarding it is using something that you built yourself. My 4' long router table is also BB ply and NO sag after 3 years of use.
So on to the build…
photo(12)
photo(13)
photo(14)
photo(15)
photo(16)
photo(17)
photo(18)
photo(19)
Bravo, great job
6
Ebony plugs? Well, sorta.
The Greene brothers used ebony extensively in their furniture and architectural pieces and that use has become a trademark of their woodworking designs. I wanted to try to stay true to their designs and use actual ebony plugs in the Greene and Greene style clocks I am building. I was not impressed with the shouldered plug design the plans called for and wanted true pillowed ebony plugs in my clocks. Pricing Ebony, I decided that I would have to come up with some other method of getting my plugs made. The plans called for using Mahogany for the accents and using a sharpie marker to dye the wood and make it resemble ebony. I was skeptical to say the least, but I decided to give it a try anyway and see how it actually came out. I used a method similar to William Ng's for making the ebony plugs. Since the plugs where to be a full 3/8" plus a 1/64", the plug stock would not chuck up in my hand drill so I had to resort to doing each plug by hand. I set out four sheets of sand paper sitting on top of 3M Scotch Brite pads for cushion. holding the stock like a pencil, I made small circles on the sand paper while also rotating the stock around to give a nice pillowed end. William's video along with Mark Spagnuolo's video on the subject, helped me greatly, and made all 16 plugs a breeze to make. Surprisingly, the plugs turned out great and from a couple feet, you'd never know they are not ebony and are in fact, mahogany colored with a sharpie. Maybe the next clock I will use actual ebony, but for now, I'm happy with the results.
I laid out the sheets in a row so I could go through the grits and pillow both ends of the stick.. There is actually 3 grits of sandpaper there, the 600 is currently on top of the 400 grit paper in the picture.
IMG_6035
After going through the grits, I would make sure I had a uniform pillow across the end
IMG_6037
Once the end is pillowed nicely, a sharpie marker was used to make it dark
IMG_6038
Once pillowed and colored, I cut all the plugs to just a 1/6" short of the depth of the mortises and chamfered the bottom edge to make inserting them easier.
IMG_6039
All the plugs cut and ready to be placed in the clock frame.
IMG_6040
Now that is what I'm talkin about!!! Perfection. :eek:)
IMG_6028
Now that I have done the plugs the way I have, I can't ever see making the shouldered plugs the way the plans showed ever. Making the plugs was an enjoyable experience and I am super glad I went through the extra effort to do them right.
IMG_6035
IMG_6037
IMG_6038
IMG_6039
IMG_6040
IMG_6028
Sa-weeet!!
IMG_6035
IMG_6037
IMG_6038
IMG_6039
IMG_6040
IMG_6028
Sharpies and mahogany, wow. That's brilliant. I'd never be able to tell the difference.
IMG_6035
IMG_6037
IMG_6038
IMG_6039
IMG_6040
IMG_6028
Since I've seen this up close I can couch that it is VERY SWEEEEEET. Nice job Jeffery
1 - 12 of 12 Posts
