Shop Fox - w1706 14 inch bandsaw (Rating: 4)
Ive only Had the saw since the end of February but what use I have gotten out of it was wonderful. This saw came with roller bearing guides and a 1hp motor both features I was looking at. Only reason I didn't give it 5 stars was I felt like some of the guards from the blade near where the lower guides are needs a redesign because they tend to bend and get in the way after I change the blade. Also not sure what the easiest way is to change the blade because the fence guides get in the way of changing the blade making it difficult to get out. As often as I plan on changing the blade though Its not that big of a deal. I might wind up taking that lower guard off below the bearing guides and fitting something that doesn't get in the way or bend so easily.
