Gluing solid wood panels
1484 Views 5 Replies 5 Participants Last post by  DavidIN
I am currently working on a Jewlery Box and had some questions. I will be making the box out of Sapele with a bookmatched Birdseye Mapel panel for the top which will be held in a dado/groove. The bottom panel will be Sapele and secured the same way. The corners will be mitered with Wenge keys to help strengthen the joints. My question is should I glue in the bottom and top panels? The top and bottom panels for the box will be about 1/4 inch. I know that when making cabinet doors in the past I was advised to avoid gluing in solid wood panels to allow for movement but wasn't sure if this would be an issue on a smaller panel. I have made plenty of solid poplar boxes out of 1/4 stock that I have glued the panel in and haven't had any problem with wood movement but worried that I will with such a nicely finished project.
I appreciate any thoughts or help on this.
Rafe
1 - 6 of 6 Posts
If they are fully enclosed, no need to glue. Just let 'em float.
While there is not a lot of movement in a small box, it can't hurt to allow for it.
my .02
I would probably let them float, like Terry said.
Appreciate the help. I figured as much but thought I would check before I assembled my project.
I would also let them float.
helluvawreck aka Charles
probably doesn't need much room for a small project, i do a 1/16th and never had a problem for boxes.
1 - 6 of 6 Posts
