381 - 400 of 460 Posts
· Registered
Discussion Starter · #381 ·
Shop Made 2'x4' Down Draft Table
DOWNDRAFT TABLE BUILD - 2016
This is a project I needed to do to work on my boxes. I'm sharing details for LJ's who might want to build their own if they haven't already.
Minnesota winter means enclosed shop. Dust! I needed a table that would fill a number of functions for me. I wanted a large enough space to sand furniture parts as well as making boxes. I'm providing this blog for those of you who want to make a slightly larger down draft table/box. I have a 1 1/2 hp delta dust collector with 4 inch flex tubing running from my Garden shed into my shop. The 4 inch tubing and corrugated flex hose reduces the air flow. I also built a 50 gallon Thein chip collector and that all reduces the suction. I found a way around it for now while making boxes. I use plywood to cover half of the top increasing the suction.
I added 3/4 holes to the pegboard to increase the air flow. A Stympy Nubbs idea when he wasn't using Rockler parts. He built both types and you can check him out. Otherwise I have laid out my steps using my "some day I'm gonna use this" materials.
Kiefer posted a hood to go over his down draft table which I will aapt later when I have to close the shop again to Minnesota winter and kick up the heat and dust! LOL!
Wood Textile Sleeve Rectangle Flooring
I drilled 140 three-quarter inch holes into a 2' x 4' pegboard. These were drilled with a three-quarter inch hole saw. Due to its coarseness in cutting and the softness of the pegboard there was some tear out on the backside.
Table Wood Flooring Floor Indoor games and sports
After I treated the pegboard with a coat of Seal Coat. I proceeded to use my oscillating sander I proceeded to sand down the tear out on the back of the pegboard.
Table Wood Hardwood Flooring Curtain
Wood Audio equipment Gas Office equipment Engineering
Assembled the frame from materials that I culled from the construction materials in my shop that were not cupped, warped, twisted. I used a lap joint with glue and pin nailer. I haven't made any corner braces so I used square 2×4 blocking for clamping and holding the frame square.
Wood Floor Gas Engineering Flooring
I had cut dado slots to the width/thickness of the pegboard. And I had to trim the pegboard that the slots.
Wood Floor Hardwood Wood stain Boats and boating--Equipment and supplies
The bottom of the 2×4' box has a half inch rabbit joint to accommodate a half-inch thick 2×4' piece of MDF. The rubber mallet that's a persuader.
Window Wood Rectangle Table saws Wood stain
Wood Wood stain Grass Hardwood Plank
Again, I used available materials from my shop to make a V-shaped vortex. This table is designed by available materials versus a materials list to the design of table. The rails are glued and screwed. But tacked first with a pin nailer.
Wood Automotive exterior Composite material Gas Hardwood
This is is a set of rails notched into the frame to support the thin pegboard as the dado grooves were not sufficient.
Wood Table Gas Auto part Box
I was able to purchase an inexpensive 4 inch exhaust port for about four bucks on Amazon. The holes were cut with a hole saw slightly smaller in the center approximately 3 1/2 inches high and two side holes with another hole saw approximately three-quarter inches in diameter. This provided enough air volume to meet the dimensions of the exhaust port.
Wood Textile Rectangle Flooring Font
I painted the pegboard with an exterior grade tinted primer which I had in my shop and added some resistance from the top. The pictures show the pegboard slide in over the rails noted above.
Wood Automotive exterior Hardwood Gas Flooring
mixing my own wood filler from yellow, glue and the sawdust from the wood to fix the punky holes in the front of the table before painting.
Wood Rectangle Tool Gas Flooring
Painted the complete frame/box with exterior grade white ceiling primer.
: Assembled/painted components of the downdraft table.
Table Wood Gas Flooring House
Attached the exhaust port and sealed with caulking.
Table Wood Recreation room Sports equipment Baize
Purchased some three-quarter inch rubber square feet at a good price from Amazon.com that I attached with three-quarter inch wood screws.
Wood Table Audio receiver Gas Hardwood
Did a test run with a porous rubber sanding mat purchased from Amazon which sits perfectly on top of my woodworkers bench. It works! LOL!
As always comments and suggestions are welcome and thanks for checking it out!
Maybe a hook or a nail? LOL! I would build a smaller box if i had time or extra space. It's simpler.
· Registered
I don't have room for it ;) but great idea and workout.
· Registered
Discussion Starter · #383 ·
Dutchy,
Thanks! You do have limitations but a smaller version that's portable might work?
· Premium Member
I really like your downdraft table and I am looking at building a new one as mine is too small.
Do you have any idea of the square inches of opening in all the holes on the top. Also, how much cfm is your system pulling?
I am wondering if you need a certain amount of flow rate through the holes to be effective at capturing small dust. Bill Pentz suggests for a 2' x 4' table needing around 600-700 cfm. In addition, they need short walls around three sides.
Given that sanding produces fine dust and is the most hazardous, getting the adequate cfm is critical.
· Registered
Discussion Starter · #385 ·
Thanks,
In the blog I note size and number of holes. 3/4 inch. I also note the 1 /5 hp Delta dust collector I believe is at 1200 cfm. Still really inadequate for really good down draft. Their are fans that can be added to increase the out flow. They are for increasing air flow in heating systems.
As I mentioned I will also be using Kiefer's idea of a collapsible hood when sanding. I also have a grizzly air purifier. and I have an idea for using a 20 inch box fan as I got about ten mico filters from the Habitat for Humanity Re Use store.
Also have set up a dust suction from my shop vac, but it will zap me do to high air movement.
The top is a half inch below the top edge and the bottom is a 1/2 inch inset.
Also straigh pipe will produce less resistance and it's in the futer when money allows. LOL!
Hope this answered your questions.
· Premium Member
Given your system and piping, the cfm at entry to the table is likely much less than the 1200 cfm. Typically, mfg exaggerate their dust collector performance.
I guess the question I was asking is more generic. What are the guidelines for making an effective downdraft table.? What size holes for example and how many real cfm for a given table size. Pentz suggests 600-700 cfm using 3 hp motor and 13" impeller. Are these realisric or does anyone have better suggestions?
· Registered
Discussion Starter · #387 ·
A 3 hp dust collector is beyond my means. The table is determined by what materials were on hand and not designed first. with a materials list generated.
You might post your question on the forum?
Best of luck!
· Registered
Discussion Starter · #388 ·
Maple, Murphy, and Me,
Murphy always has a treat in store for me.
Wood Floor Flooring Gas Hardwood
My friend CharlieK (on LJ's) lives in MN/St.Paul area. A town called Fridley. He had purchased a trailer load of rough milled hard maple and he had a lot left over which he was wanting to sell to get it out of his garage Took my 1990 3/4 ton truck and traveled 124 miles to have lunch and pick up some maple. Had a full truck bed up to the top of the sides of maple and I was returning home in the dark. About 11 miles from home my front passenger side tire wall gave out (used seldom but 18 years old?) And I had to call for assistance. Turns out we couldn't tow the truck due to all the hard maple in the back would put to much stress against the tailgate. The guy's station is a block or so from my house. Had him bring my old tire that had been sitting on the ground under a tree and we changed the tire which has rot for the blown tire.
He lifted the truck and put the spare on which shows weakness in the structure. Got it home late. (situation normal afu) Called our local salvage yard, for used tire. NA Called local tire replacement and my mech. No used available,and the truck needs new tires. Even though it's not a commuter it handles my plowing needs. And it needs good tires for occasional use.
Property Wood Building Floor Wall
Also didn't want to store the wood outside this winter as I'd done that a few years ago and when I uncovered the pile in spring had ants throughout the wood pile.
Thought I'd build a lumber rack in my sandstone walls basement but couldn't find an empty 8 ft. long space. To shorten this up….I moved and cleaned and constructed a wood rack that sits on bricks as I get water in the basement ( no sump pump)
Actually just finished unloading and stacking the wood in 10 degree temps.
Thanks for checking it out!
Wood Hardwood Wood stain Lumber Shelving
All comments and suggestions appreciated!
· Registered
Looks good Tom, lots of work but once it's dry enough you will have some great wood to build some great projects.
Sorry to hear about you tough trip home.
· Registered
Discussion Starter · #390 ·
Thanks Jim! Now that the truck is unloaded I found a reasonable deal on some 50 k tires but I have to drive 44 miles. But it's worth 150 bucks????
· Registered
Tom…that is a lot of frustration to go through…and thqat sorta stuff never happens at a convenient time…but you got some great lumber and when all is done you will have some good tires on your truck. When something annoying happens I just visualize the fact that before long it will be over and I will be sitting back and relaxicating at home.
Best therapy…plan a new project for that maple…
· Registered
Hi Tom,
I'm really sorry that you had such a tough time getting home that night. On the other hand, your lumber rack looks great! I am looking forward to seeing what you make with that maple.
BTW, I heard that Murphy can't touch you if you wear garlic and wood chips around your neck
· Registered
Discussion Starter · #393 ·
Greg,
Hoping in June to stop and be able to start with woodworking and I now have walnut, ash, spalted maple and the hard maple now drying in the basement. The tires were old like me. LOL! And they had good tread, but life happens???? I'm safe and I have a story to share with you all. Thanks for checking it out.
· Registered
Discussion Starter · #394 ·
Charlie,
The best laid plans???? But Murphy is my mentor. As Greg said I will have new tires on my old truck pretty soon.
Thanks for seeing where your wood ended up!
· Registered
Tom, someone once told me there is no such thing as a great deal. In one hand you get a good deal and in the other hand something gets taken away. At least you made it home and can start thinking of what to make with it.
Murphy just likes teasing you.
· Registered
Discussion Starter · #396 ·
Hey Dave,
Could have been better and it could have been much worse. At least the plow wasn't on the truck yet. :<D Thanks for checking it out.
· Registered
It's all matter of perspective… The pile of wood would cost a fortune where I live, (4 new tires would cost less, even the special ones on my van)....
· Registered
The things we all do because of being wood hoarders. Way to get it done sir.
· Registered
Discussion Starter · #399 ·
Hey Gerrit,
An unexpected surprise. Thanks for checking it out. My biggest positive in all of this is The tire didn't do anything but give out. I'm unharmed and Murphy is my mentor. Just have to realize the lessons that he teaches.
The Maple is more than I need right now but I will stop working at my profession in June and I will be living life your way. Only here in boring farm country. But like you I will adjust and survive.. LOL!
Take care!
· Registered
Discussion Starter · #400 ·
Monte,
Maybe that's it but maybe it's cause were connected to the wood? Thanks for checking it out,
