1 - 20 of 38 Posts
Discussion Starter · #1 ·
My First Commission
Well the Garden Gate business has picked up. Actually it had nowhere to go but up as this is my first commission. I won't have to go very far to deliver it either as it is going in right next door to my Garden Gate II. I thought I'd use part of the long weekend to get a good start on the project. I've found that now that I've done a couple of them I can really crank one out. And since I just finished the patina panel for the bed last weekend along with twenty or so practice tiles, I should be all set with a full tank of propane and all the chemicals mixed, staged, and ready to go. Still it is a good idea to start with Sketchup. It doesn't take much time to design and helps visualize the build. You can check out both the Gate I Blog the Gate II Blog Series at these links.
My neighbor's gate will be to the left of this one.
At 40" it will be about 3" wider than mine but a little shorter. They should balance out okay since her side is a little higher. It will also be 2" thick like the first gate on the other side of my house. I made the second gate 1 1/2" and didn't like it as much. The 2" takes a little more work on the front end laminating and milling but it is no harder after that.
Premium Member
My First Commission
Great job on the patina, it sets off the rest of the woodwork.
My First Commission
Nice work!
Discussion Starter · #4 ·
Here's a nod to David Marks
In his great series of woodworking shows there was one thing David did over and over that got some gentle teasing around the web. Can you tell which photo depicts this?
Before I cut the mortises for the stiles and top/bottom rails I have to first make up the arch assembly. Through Sketchup I calculated that two boards cut on 12 degree angles would work. I'm still looking for a calculator, table, or formula that allows some what-if-ing of various dimensions to calculate various sized arched segments. Until then I'll have to stick with Sketchup and experimenting with best fits (see Blog 1 in this series).
First I had to laminate some 2x stock which is really 1 1/2" with some 1x stock which is about 3/4" to make up some 2" thick boards. I cut the two pieces that make the arch segment a little oversize and clamped them together to mark the mortises. I used a 3/8" bit and set the distance from the guide fence using a 7/16" drill bit. I've learned the fastest and most accurate method is to cut the mortises then rip or resaw some stock then round the edges on the routher table to fit the mortise. I also use some chisels to clean out and smooth the walls of each mortise. Next will be the plumb cuts.
Premium Member
I guess it would be making all the x marks. also your doing a great job on those joints.
Ah, X-ing out the waste left-handed with his tattoo poking out from under his sleeve? Aren't the angles for the facets just divisors of 90 degrees (i.e. 45, 22.5, 11.25, etc.)? If I'm ever a homeowner, gates are awesome projects. Same with front doors.
Discussion Starter · #7 ·
You got it… yeah the little x's in the mortises. I started putting an X in the mortise and just kept going, then thought about David Marks.
Cap Sully… the angles can be any degree between 0 and 90. The boards are glued together in the shape of a chevron. The question is how steep an angle is required so an arch of a given width can be cut using stock of a certain width. A tight radius, for example, requires wider boards on a steeper angle. A flatter curve would require thinner boards on a broader angle. There has to be a mathematical relationship that can be used to calculate these tradeoffs. I think once I'm able to articulate the problem the answer will appear.
Discussion Starter · #8 ·
Plumbers
So now that I'm on my third gate, and, including my arched bed my fourth or fifth or sixth plumb cut, I've found that the quickest and most accurate way to make the sides of the arch parallel to the sides of the bottom is to use the bottom rail as a guide. First I cut the bottom rail to width, in this case 28" (the stiles are 6" each for a total width of 40", I hope). I then place the bottom rail on the cutoff sled and bump it up against the blade. Then I line up the middle of the arch with the middle of the bottom rail making sure the two lines are, well, plumb. I clamp the bottom rail to the sled then clamp the arch rail to the bottom rail. Now, assuming the blade is 90 degrees to the table and square to the sled everything should work out just fine.
After making the first cut I leave the bottom rail in place and clamped to the sled, then I flip the arch rail and line up the right sides so they are flush. I then reset the clamp of the arch to the bottom rail and cut the other side.
Viola! I works just fine and is very safe. Next step is to cut the curves in the arch.
Plumbers
I'll be looking to see how you join the arch to the stiles. I have two of these to make this year.
Plumbers
Nice story, this is interesting, I want to see more please.
Plumbers
Thanks for such good pictures and instructions.
Plumbers
interesting Blog Tim
Discussion Starter · #13 ·
Use a part to cut a part
Just like with the plumb cut it is easier and more accurate to use the bottom rail as a guide to cut the arch rail. Here I use the bottom rail as a support for the swing arm to cut the curve in the arch rail. I start by lining up the two stiles with the rails so they are parallel. I have already marked a centerpoint on the bottom rail and positioned it 30" or so from the top of the top rail. Since I'm using the Milescraft circle guide it is very easy to reposition the swing arm so that the bottom or inside of the router bit cuts the maximum arch on the outside of the top rail and stiles.
I have found that even a shallow cut with the router puts significant pressure on the bit and the whole setup which raises the possibility of a slip which would then have to be fixed. Since I'm using 2" thick stock I decided not to get greedy with the router and settled on cutting a channel that I can then use to guide a flush trim bit on the router table to finish the cut (see below).
I usually cut the outside arch first then while the top and bottom are securely clamped, I reposition the swing arm to cut the inside or bottom arch with the outside or top of the router bit and move the stiles aside (actually I use one of them for support) and cut the inside arch. Remember you want to use the same pivot point for both arches so the inside radius will be a little steeper than the outside radius. See the blogs on Gate I or II or search 'segmented arches' to get whole enchilada.
I use a jigsaw to cut along the inside of the channel then trim the pieces up using a large flush trim bit. Works great and you get a smooth and accurate result. It is a little extra work than trying to cut through with the swing arm setup, but I think it is worth it.
Looks good Tim, some super clear photos too. good work
I begin to see the picture.
I like your planning.
Still looking forward to the next episode.
this is a well done method ,
sneak up on it !
nice and clear ,
thanks .
Discussion Starter · #17 ·
One good mortise deserves a tenon
The stiles and rails are connected with pairs of tenons. Or is it mortises? Or morties? Yuk yuk… yeah well you use the same set up for the side mortises as you use to make the arch. Call it the lazy man's way to woodworking. Actually I went ahead and cut the mortises in the stiles and bottom rail while the glue was drying on the arch. Then all I had to do was four quick mortises on the sides of the arch and the gate frame was ready for glue up.
There are 20 mortises in all (5 joints, 4 mortises/joint, 10 tenons). It didn't seem like that many until I counted them all up. Mortises sure add up fast. They are all about 1 1/2" deep so I cut the tenons a little shy of 3", cleaned up the mortises with some chisels and used Tightbond III glue to put the frame together.
It's taking its shape now. Keep up good work Tim.
Discussion Starter · #19 ·
The Outer Laminates
Always experimenting, so this time around I thought I'd try to laminate some strips across the top of the arch. Three reasons, not necessarily good reasons, but reasons alll the same. One Is to cover the exposed endgrain at the top of the stiles. Another is to try to match the inner laminate that is used to hold the panel in place, the third is to… I forgot what the third reason is.
I ripped some strips on the tablesaw and ran them through the drum sander keeping the grain match with chalk triangles. Then I glued them up just like a cutting board and clamped the stack atop the arch. I clamped some scrap ply on the sides so I could clamp down the ends on an angle. I found that by positioning the clamp on the outside edge I was able to get really good pressure down on the corner.
I used a router to trim the laminate flush with the arch. The result was pretty good, and it looks even better with some sanding and a nice rounded edge.
Oh yeah, the third reason, I remember now, is to add width to the arch to better match the rest of the frame. Next up, The Inner Laminates.
Discussion Starter · #20 ·
The inner laminates
On my first gate the panel was held in place with stays based on the David Marks project. The second gate used rabbet like a picture frame. For this project I decided to go back to the stays. They are not hard to make as you can use the gate itself as a form. While I was prepping the stock for the outer laminates I made an extra set for the inner laminates. The only trick is the measure the length of the inner arch. I used a flex tape, but could have used a string or other flexible item and used that to measure. Since the inner laminate sits between two 3/4" stiles, you've got 1 1/2" to work with. I cut these about 1/2" short to have some play on both ends. Again the glue up is pretty straighforward, just like cutting boards or any other lamination. Just be sure not to glue the top of the lamination so it doesn't accidentally get glued to the arch.
1 - 20 of 38 Posts
