Furnishing a Sauna Suite
18880 Views 24 Replies 4 Participants Last post by  DustyMark
4
Overall Plan
"Finnish" the Basement with a Sauna
We designed and had our home built in 2014. We anticipated finishing about 500 square feet of the basement eventually, so we had the basement plumbing roughed in during the initial build. I began finishing the basement, as a DIY project, about a year ago. In our part of the county, we only needed an electrical permit.
Font Auto part Engineering Parallel Rectangle
The focal area is the sauna. It's a very useful 5' x 7' size with heat-efficient 7' ceilings, a heavy glass entry door, electric stove with digital controls, and western red cedar used throughout.
Excellent Sauna Resource
Publication Font Wood Art Poster
I found "The Art of Sauna Building" to be an excellent book that was extremely helpful in designing and building a custom sauna. The author emphasized the importance of creating a very relaxing atmosphere. I planned the project with the overarching theme of a "sauna suite."
This blog will focus on building the cedar benches and accessories for the sauna, changing room benches, changing room table, and a vanity base for the toilet room. Everything in the sauna hot room is built from western red cedar. Everything else in the sauna suite will be built from ash. (I obtained a lot of ash free from my Dad's friend in Wisconsin!)
Next
Building the cedar sauna benches.
21 - 25 of 25 Posts
16
Capturing a Shelf Inside Tapered Legs
Lots of Other Projects
I set the sauna furniture aside to work on other projects. I built a similar table to this with a drawer for my step daughter as a wedding present, configured my wife's new fishing kayak, and made some modifications to the fishing configuration for my Wood Duck Double kayak I built last year. With those projects completed, I'm in the home stretch of completing the sauna suite furniture.
Cutting Shelf Mortises
I've made four of these tables and placing a shelf within the tapered legs provides both strength and utility.
Table Cabinetry Wood Automotive tire Home appliance
This shelf holds the fan that cools us off in the changing/shower room after a sauna. This photo shows me experimenting with a height that looks good and is functional. I settled on 10" from the floor to the top of the shelf.
Table Wood Rectangle Wood stain Plank
Notice the relationship between the taper on the leg and the mortise that receives the shelf.
Saw Milling Wood Table Machine tool
I used a mortising machine to cut the mortises.
Brown Wood Rectangle Flooring Wood stain
The mortises are cut from both sides. The material between the mortise and the inside edge is removed by the taper cut.
Building a Tapering Jig
It's worth building a simple jig to make the 8 tapered cuts required for a set of 4 legs.
Table Wood Desk Tool Workbench
Draw out the taper on a piece of 1/4" plywood and screw 3/4" wood cleats to hold the leg in position for the rip cut on the table saw. This is an incredibly accurate way to cut a tapered leg.
NOTE: Be sure to visualize which face of the leg to taper first. I lay it out so that when the first face is tapered, the subsequent face is towards the bottom. This allows me to rotate that face clockwise for the next taper cut and I've always got a flat surface against the bottom of the jig and the positioning cleat. This one is worth pondering before you make each cut…
Cleaning Up the Mortises
Hand tool Burin Wood Tool Metalworking hand tool
I used a sharp chisel to clean up the mortises. The mortising machine leaves some material to remove since it's a round drill bit operating within a sharp, square housing. This doesn't take much work to clean up if your chisel is sharp.
Table Cabinetry Writing desk Wood Floor
The legs look a lot better with a taper. There was too much bulk for the size of the table prior to the taper.
Property Wood Table Flooring Wood stain
This photo shows the final location for the table. My Dad turned the bowl from spalted maple. All that remains is to produce top cleats, sand to 120, glue it together, , peg the tenons, clean the glue squeeze-out, sand to 220, and varnish.
Next
Build a simple vanity base with inset panel sides and doors.
Vanity Base - Post and Frame Construction
Approach
This is the last piece of furniture to complete furnishing the sauna suite.
Wood Bathroom Rectangle Sink Interior design
The vanity base starts out quite similar to the changing room benches or the table from previous blog entries. It features rails fastened to legs via mortise and tenon joints.
Wood Rectangle Automotive exterior Hardwood Composite material
To make it a cabinet, panels are added between the frame pieces. This is a lower rail and shows a 3/8" deep groove for the side panel on the top and a 1/4" deep groove for the bottom of the cabinet in the side of the rail. I routed the top groove with the same 5/16" spiral upcut bit that I used for the mortises.
Wood Rectangle Wood stain Hardwood Flooring
This is the top rail. The groove on the face is for a cleat to provide more glue surface area for the silicone to hold the marble vanity to the base. The other groove is for the top of the side panel.
Wood Flooring Musical instrument Hardwood Wood stain
This is a front leg, with mortises on the side, that holds the cabinet doors. The grooved portion is to hold the side panel. NOTE: I routed the hinge mortises before assembly.
Wood Rectangle Wood stain Hardwood Plank
This is a back leg with grooves to hold the side and the back panel.
Table Wood Rectangle Tableware Composite material
Close-up of a mortise and groove in a leg.
Assembly Sequence
I assemble the side panels first.
Table Wood Floor Wood stain Hardwood
Start with the front leg and a pair of rails.
Wood Rectangle Flooring Gas Hardwood
Add the plywood side panel. NOTE: I used 1/2" plywood and dadoed it to fit the 5/16" groove. I placed the dadoed side into the cabinet for the side panels.
Wood Rectangle Wood stain Gas Flooring
Add the back leg.
Wood Gas Flooring Machine Hardwood
Add the 3/4" plywood floor, the back rails, and back plywood panel.
Wood Floor Gas Engineering Flooring
Add the other side assembly. Clamp the entire cabinet at the same time to ensure everything lines up before the glue sets. I used polyurethane construction adhesive because of its longer set time. (I don't like foaming Gorilla glue.)
Wood Composite material Gas Machine Bumper
I'm glad that I've invested in a bunch of Bessey K-Body clamps over the years!
Wood Engineering Gas Machine Composite material
Close-up of the glue cleats.
Next
Build the cabinet doors.
Vanity Doors
Similar Construction to Frame
The door construction is quite similar to the frame. I routed mortise and tenon joints and added a groove for the plywood panel.
Wood Rectangle Floor Flooring Hardwood
This is a view of the front of the door. The panel is flat.
Wood Rectangle Flooring Floor Wood stain
The back of the panel is rabbeted.
Brown Wood Rectangle Flooring Grey
Close-up of the rabbet. Yes, you can see a crossgrain plywood layer when you look closely in the 1/8" gap…it's a bathroom vanity.
Hardware
Wood Rectangle Flooring Hardwood Wood stain
I used flush hinges and set them in shallow mortises.
Wood Wood stain Hardwood Plywood Varnish
Close-up of installed hinge.
Wood Communication Device Hardwood Wood stain Fixture
Mary insisted on magnetic closures.
Surveillance camera Wood Hardwood Gas Wood stain
Ugly, but effective.
Done
I installed the top and finished the plumbing this weekend.
Cabinetry Plumbing fixture Tap Countertop Wood
Cabinetry Table Drawer Wood Chest of drawers
Cabinetry Furniture Wood Rectangle Desk
It's hard to take good pictures once a vanity is installed in a small room. You get the idea though. I'm happy with how it turned out.
Conclusion
Building our own furniture for the sauna suite was a good decision. I like the look of the ash in the areas outside the hot room. The furnishings are custom and reflect our style preferences. The basement finishing project is done!
Vanity Doors
Hardware
Done
Conclusion
Looks good Mark,
Nice job!
Vanity Doors
Hardware
Done
Conclusion
Thanks! It's a big day since this was the last step of my DIY finishing of 500 sq. ft. of our basement.
21 - 25 of 25 Posts
