"Fold up" ironing board (reverse engineering)
30977 Views 10 Replies 6 Participants Last post by  ADDmom
measuring the model and planning any modifications
So as part of a Murphy bed build, I wanted to incorporate a fold up (or hide away) ironing board. I have seen these at Lowes and Home Deport starting off about $168. They don't look that hard to build and I sure think I could save some money AND incorporate some better materials.
Step 1: Take my tape measure to Lowes and jot down some critical measurements. Ok, I forgot paper. Let's see, what can I find in my glove box? Perfect, my State Farm insurance cards, I can use the back of that! Ugh, bad start…
These units are designed to fit between standard 16" stud space in a wall. Since my use will be a completely custom Murphy bed complex (yes, I'm calling it a "complex", because it HAS become pretty complex) , I can make mine any size.
Coincidentally, my wife is learning how to sew. Her online class has a iron board cover as an upcoming project. How perfect, huh?
OK, I think I have the critical dimensions. Now I need to head home to build a mock up. The biggest challenge I see right now is the sliding mechanism is lined with plastic. I assume this is to lower the friction. I'm going to have to think about this one…
1 - 11 of 11 Posts
Looks like you are using the same version of "Sketchup" that I do!
Great project coming up!
Hieee Jeff
Man I cant see the pictures of your Iron Board Project, Please check
Thank man
Building a functional mock up
So I know I need to work out the sliding mechanism. 3 goals here:
1. Make sure the components fit into the space I'm allocating for it.
2. Ensure all the pieces work and it is easy to slide up and down.
3. Make sure the ironing board is level in the down position.
Here are all the components (minus the door which I will build as part of the Murphy bed complex).
I built a wall (16" stud mockup) and starting assembling the pieces I had cut from my measurements in post #1. The hinges are 3 1/2" door hinges. The pipe is 1/2" galvanized pipe which has an outside dimension of 3/4" strong.
Goal #1 is accomplished, it all fits! Now I need to make sure it works (goes up and down) and it slides easy enough so my wife doesn't get frustrated. I decided I would use 3/4" maple and route the groove that the pipe slides in. This was the most intimidating part for me. How to make a snug enough groove that wasn't too sloppy? Well, they say imitation is the best form of flattery, so I decided I would imitate the pipe thickness by using a pattern router bit. I grabbed some 3/4" scrap material and would use that to create the outline of my desired groove. I then used a plastic circle template as my shim to increase the width of the groove so the pipe had a little wiggle room to slide. I then brad nailed the pattern to the maple and began routing. Note, I intentionally made the groove longer than what I knew I would need so I could trim the maple top length in order to achieve goal #3 (ironing board is level in the down position). This step, which I was the most intimidated with became a rather easy task using the MDF strip templates and the pattern router bit.
Now that I have the grooves for the pipe, I need to incrementally trim it so the ironing board is level when in the down position. If the board is pointed down towards the floor, then the board needs to be shorter. I just took my time and snuck up on this by using my Wixey angle box.
Note, I decided to use maple to route the groove in. However, I intend to attach ¾" plywood with biscuits & pocket holes to the rest of the side to get my height of approximately 47". This is what it eventually looked like.
Parts list
After building the mock up, here is the parts list:
Case:
(2) sides - ¾" maple/plywood combo (46 ½ x 7 ½")
(1) top - ¾" plywood (13×7 ½")
(1) bottom - ¾" plywood (13×7 ½")
(1) shelf - ¾ plywood (13×5 ¼")
(1) back - ¼" plywood (46 ½ x 14 ½")
Ironing Board:
(1) ironing board - ¾" MDF (42 ¼ x 12") the last 13" are tapered down to a 4 1/2" circle (see pic below with cottage cheese container)
(1) board support - ¾" MDF (12×11 ½") rounded - see pic below
(1) sliding support - ¾" MDF (9 ½ x 4 ¼") has a 1 1/4" hole for bolt clearance when folded up
(1) washer - 1/8" hardboard (9×9") this space allows the ironing board cover to wrap around the edges
Hardware & misc:
(1) aluminum sheet 6×24" (thinnest I could find at Lowes)
(1) pipe - ½" diameter x 14" (I had some galvanized laying around that worked great)
misc screws
(1) bolt - 2" 5/16×18
(1) nut - 5/16" x 18
(1) locking nut - 5/16" x 18
(2) washers - 5/16"
(2) 24" piano hinges (1 will be cut to size during door installation)
(2) 3 ½"exterior door hinges
(1) hanger hook for inside of door (optional)
(1) knob or drawer pull for opening door
white epoxy appliance paint for the galvanized pipe (optional)
other finishing paint (or your preference)
Nylo-Tape for smooth sliding action (I had ¾" width on hand, but ½" would work, too) ht
(1) Hide-Away electrical unit (optional) and misc electrical wiring
Other important details
So some important details I have not mentioned yet.
The routed groove:
  • There is 2 ½" inches from the front of the case to the groove.
  • The top of the groove bends in ½"
Heat Shields:
Use aluminum for protection. I purchased a 24×6" piece and cut it in half. I sprayed it with white epoxy appliance spray paint then mounted it with 3M's Super 77 spray adhesive.
Shelf:
Install in coordination with your heat shields. This put my shelf 12" down from the top.
Electrical Unit:
If you decide to use this, install it as far right as possible. I left about an inch space to the right, but now our iron is a tight fit on the left when in storage. Also, the electrical line comes in from the top. this unit cost around $35. I am glad I got it, but it is also an easy upgrade at a later time assuming getting power to the top of your unit is somewhat easy.
Ironing Board Cover:
Lowes sells a cover that should fit the board dimensions I gave in a previous post. If not, use batting and fabric with elastic to make a padded cover. I rounded over the edges of the board using a 1/8" roundover bit.
Board Height:
Our previous ironing board height was 36" off of the ground. This is a comfortable height for my wife, so when I mounted the completed unit, I made sure the board height was around 36".
Ok, that is all the info I can think of to share. Please let me know if I can answer any questions. Good luck!
-Jeff
The routed groove:
Heat Shields:
Shelf:
Electrical Unit:
Board Height:
-Jeff
Great series, Jeff. I like the timer idea. It surely adds to the safety factor.
Lew
The routed groove:
Heat Shields:
Shelf:
Electrical Unit:
Board Height:
-Jeff
Fantastic! I've been looking for a "how to" on building a hide away ironing board for some time. Until now the folding and swiveling part had me scratching my head. Now, I have no reason not to cross this project off my to do list. Thanks for posting Jeff.
Adam
The routed groove:
Heat Shields:
Shelf:
Electrical Unit:
Board Height:
-Jeff
What is the depth required from face of the frame to the back of the cabinet to get the ironing board in so the door will close? Could it have been flush with the drywall if it were installed in a wall?
I want to do something similar, but I don't want the face frame sitting on the drywall because my wife actually wants to use an antique shutter as the door or mounted to the door to hide the unit, so the shutter needs to basically end up flush or close to it to the drywall. I guess that leaves me with @4" to work with in a 2×4 wall with drywall.
I think my other challenge will be hinges as the hinge will need to move "out" as we'll as hinge with the shutter sitting flush
The routed groove:
Heat Shields:
Shelf:
Electrical Unit:
Board Height:
-Jeff
mjzraz,
Good questions. The minimum distance is 3.5" (which should work perfect for a 2×4 stud wall). But you would still have a door of some type sticking out from the wall). I think a shutter would be great. It would look like the shutter was hanging on the wall, but it could be hinged to the drywall. A large picture frame or canvas (in the appropriate dimensions) would also work good.
A piano hinge would be a good choice. Also, certain European style hinge models actually lift the door away from the wall when opened (that would be fully concealed).
In my particular case, I opted to install the automatic outlet timer hardware, so my depth is 7.5"
The routed groove:
Heat Shields:
Shelf:
Electrical Unit:
Board Height:
-Jeff
Hi Jeff, I found your blog in my search for an ironing board setup like this - thank you, this is just what I need. I was also very interested in this community so I joined.
You may not know it, but people may be looking for your article. We're very sad that the pictures are missing - maybe you could repost them?
Here's how I found your project. There is a DIYer who was featured on Houzz (a big-deal home decor blog) and she used your instructions as inspiration to build her fold-up and swivel board.
Here's the article and her video about her laundry room where she shows her board. Not as well done as yours, but it works for her -
http://www.houzz.com/ideabooks/40336773/video/
And here's her blog where she mentions your instructions and the hacks she had to do for her project.
http://www.batchelorsway.com/2014/06/diy-built-in-ironing-board-part-one.html
Best to you,
Lynn, CA
1 - 11 of 11 Posts
