1 - 9 of 9 Posts
Discussion Starter · #1 ·
My first table
This is table i'm working on, I know its a little "grand" for a first timers table, but I figured if I can do this table, it will make doing future tables much easier. I'm a child of the 80s and i grew up around 70s and early 80s furniture and if you remember, it was all massive and looked like wood. I love huge furniture still and can never just let a good floor model tv go to waste (i made a router table out of one and a fish tank out of another). So without regard i started on this "table" and it turned out huge and i had no idea why until i looked around my house. Everything i own is from the 70s or early 80s and big as all get out. In hindsight, that must have been why it was SOOOOO much fun moving into this house a year ago.
It is made out of a cabinet grade pine top from lowes, pine 2×2s and plywood. It is 23.5×48 and 27 inches tall. I know, pretty big considering my original idea was for a coffee table, ahaha.
CLICK HERE FOR THE REST OF THE PICTURES
I need to add stretchers for more stability since it wobbles a little. (i'm actually considering making it a cabinet instead of just adding support)
My dad used a rotozip with a jigsaw mount to cut out the diamond in the center, then i thought it needed it to be a little bigger and made a bad cut and thus the idea of a frame around it was born. I bought some small molding from lowes and we cut the miters, glued it together and i tried regular titebond2 on it, but the pressure was too much i guess and i had to use epoxy to get it to stay in place. maybe its a humidity thing. (i do live in west TN, very similar weather to Mississippi).
The finish is 2 coats of cherry oak i got at lowes discounted, 11 bucks for a gallon of something smooth like cherry oak? i'm buyin every time. anyway I dont know anything about staining and this is the first real attempt at staining well, i can see some flaws i made but oh well, life goes on. I sprayed 2 coats of poly from a can, some parts are smoother than others, i think i'll get into the brush on poly before i give this piece away.
I got the idea from a generic coffee table pic on the web, and thought it would look better if it were bigger and had a porcelain tile in the middle of it.
including the rotozip bits i had to buy the table has only been about 50 dollars worth of materials.
My first table
Tables are a good place to start, there are more techniques involved than one would think. As a first it's a good start and put on the path to even more neat stuff.
My first table
I like it! Being a child of that same era, something about this table just seems cool to me ;)
My first table
Good first project. Looks like it's useful, too.
My first table
Nice looking table. I like the addition of the center piece. I don't blame you for posting this. It is a wonderful first project.
Now, flush with your success, I assume that other projects are in the works.
My first table
Looks good.
If it feels tacky try sanding lightly (Like barely) with some worn 320 or 400 grit sand paper. You can prepare the paper by folding it in half and rubbing it on itself to knock off anything that feels sharp. Rub that lightly on any parts where you feel nibs. The goal is to sand the finish and knock down any dust nibs that accumulated as it was drying. Don't be tempted to sand any bubbles. And go light. (almost zero pressure).
My first table
Nice table Boon.
Discussion Starter · #8 ·
Come together, right now!
I started assembling all the pieces I cut last week. Work has been hectic since I've been "training" to be a manager. I improved upon the original plan a bit, instead of using a poplar or cedar insert like I had planned, I decided to not use wood at all and go with… concrete! Or something similar I can pour or fill the 1.5 inch gap in the center. I will cover the bottom with some scrap wood and pour some concrete in the middle. I've never dyed concrete but I would imagine it is a fairly simple process. I was thinking of a red or blue metallic style. If that is even possible. I'll ask around at work tomorrow but in the meantime I want suggestions from you guys.
Also I haven't sanded much of the table yet, I really like doing that by hand near the end.
thats sweet boon
1 - 9 of 9 Posts
