My only concern with this is the 12'-plus run (width) with what appears to be 3/4" (1" nominal) stock for the top with just a small apron at the front supporting the 6'-ish span in the middle. If that has a ledger (rear apron) that is attached to the rear wall, it should be fine. If you're making it free-standing and without a rear apron, you could get some sagging. Just my $0.02.
The rest looks good but, as always, the devil is in the details. Will the sides, backs and shelves be plywood or solid lumber? If solid, will that be softwood or hardwood? Will the shelves be let into dadoes or will you be using some form of track or adjustable pegs to make them adjustable? What sort of hinges will you be using and how will they work with the face frame overlaps that you plan on using? So many questions and so many details...
Many of the finicky details in century-old solid wood cabinets are techniques that have been learned and adapted over time to account for the seasonal movement of solid lumber. Plywood, for all intents and purposes, doesn't do that so the joinery and the resulting fabrication are much simpler but additional steps need to be taken to conceal (or celebrate) the plywood edges.
Keep asking questions; they're free.
