Finger Joints, my way
2535 Views 7 Replies 3 Participants Last post by  MerylL
30
Making finger joints....
Also known as Box Joints. Not saying this is the "perfect" way to do these, but, this is how I do them.
First off, I get the four sides all milled to size. Nice when they are the same width and thickness
Wood Automotive tire Hardwood Gas Automotive wheel system
So, for this little "How to", I have these Pine boards. I made them about 3/8" thick, and all are about 3-1/2" wide.
Boards can be about any size, but they need to be close to the same size no matter how thick or wide they are.
I start with the "long" sides. I clamp them up inside to inside faces. I then first mark roughly the thick ness of the shorter board on one end of the stack. Then square a line across…
Wood Gas Composite material Building material Hardwood
AsI have a bit of trouble holding the two square to each other. Next, I get out a chisel, and use it to mark the fingers out..
Guitar accessory Wood Flooring Floor Brick
For this project, I used a 1/4" mortise chisel, but, about any width chisel can work. I start on one end, and work my way across. You can also start at each end and work towards the middle, adjusting the middle to fit. The chisel will also be the one to chop out the waste. I then use a square, and layout the cut lines down to the Base line. I keep the sides pieces together for this, as I want them to match. Then I lower the two sides a bit in the vise, and get a saw out..
Building Wood Composite material Urban design Roof
I have this little back saw for the job, but about any saw can work as long as it can cut straight. You can even do this with a bandsaw, just try to split the lines is all. Next I take the sawn boards, and open them up like a book,
Wood Rectangle Flooring Plank Hardwood
These are the "insides" of the box. I also mark which is the top and bottom edges.
Wood Hardwood Wood stain Plank Lumber
helps later with the fitting. I can then set aside one of the sides, for now. I grab the square and a knife..
Automotive tire Wood Bumper Gas Machine
About 3-5 passes with the knife along the base line. Makes a "knife wall". I do this to both faces. On some of these joints, I can saw the corners off..
Wood Gas Rectangle Composite material Brick
Since the saw is handy. Next, a bit of chopping is done. Nothing real fancy, but..keep the bevel of the chisel pointing away from the knife wall. I start by peeling a layer off towards the wall, starting about halfway back…then a chop in the wall area. The peeled off part gives a place for the bevel to go. Keep this up until..
Rectangle Wood Mechanical puzzle Tints and shades Puzzle
You get about halfway down. You can either leave the end on, or off..
Food Rectangle Cuisine Ingredient Dish
As long as you give the knife wall one more chop…do not get greedy, all you want here is for the waste to snap off..LATER. If it does at this point, you will get "blow out" on the other face. Ok, do the entire side, then flip the board over, and repeat…
Wood Burin Gas Stonemason's hammer Mallet
If you remove the end piece of the waste, it will tip down like this, a second hit will remove the little block. If you do leave the end in place, that little block will fly back at you. I then can pare the finger until they look spiffy..
Wood Gas Flooring Composite material Hardwood
Happy with the look? Ok, remove this board from the clamp, replace it with a short side board ( marked for "Inside" Top and Bottom and a corner number). Tricky part next. I hold the completed fingers where they will be going, I take a sharp pencil, and trace on the short board where the fingers will go…
Rectangle Wood Font Beige Pattern
Supposed to look like this after squaring the lines. I also include the base line. Then, this time around, you want to saw on the waste side of the lines, LEAVING the lines. Much easier to pare a bit to fit. Then, just chisel away the waste, like before. One face 1/2 way, flip over, and complete the chop. test for fit..
Wood Machine tool Gas Machine Hardwood
IF it is a bit too tight, a pass with the sharp chisel to pare to fit. One corner done, three to go. Takes about the same amount of time as it did to read this blog.
Remember, use a sharp chisel, with the bevel away from the base line, knife wall. First time through, you can split the lines, but the matching fingers need to be sawn on the waste side, leaving the lines.
Best thing? I can use this shop tool..
Idiophone Drum Wood Gas Cookware and bakeware
And work sitting down on the job. Any questions?
1 - 8 of 8 Posts
46
Ok…I kept working on this little Pine box project..
Wood Wood stain Hardwood Plank Lumber
Inside of the corners looked decent enough…
Wood Wood stain Hardwood Gas Plank
Outside, the fingers were a tad long. Which is ok, as I can trim these down after the glue up. Better than having them too short? Laid all four sides out, just un-folded it..
Wood Plank Gas Hardwood Wood stain
Here you can see why it is important to have a SHARP pencil….the joint closest to the camera, the pencil was a bit dull. Sharpened up the pencil, joints became tighter. I then made a jig, first a backer board.
Wood Plank Hardwood Wood stain Composite material
Just a 1×1 attached to the benchtop…a bench dog was going to be a "stop"..
Wood Automotive tire Motor vehicle Automotive wheel system Gas
But the Stanley 45 was rocking a bit too much. I trimmed the rear hold-down into two pieces, and tried again..
Wood Gas Plank Lumber Composite material
Worked well enough that I could cut the groove right through a knot…
Wood Gas Hardwood Wood stain Lumber
Then, just to see how the grooves for the box's bottom panel line up..
Wood Rectangle Composite material Tints and shades Gas
I would do a Blog about building this project, but…it would just be yet another "Box Project Blog" ....
May show a few other details, as I build this box. Lid will be split off from the box, using grooves made by the Stanley 45….so, I will need to mill a few more grooves, and then one after the glue up has cured. You can stay tuned IF you like….
Interesting read. And I learned more! I looked at some of your pics in your profile. Nice work! Following.
Thanks for sharing, Bandit!
Well, had two more lines of grooves to mill. Same jig. I rotated the parts to mill from the top edge, instead of from the bottom edge.. One for the top's panel to sit in..
Wood Wood stain Hardwood Plank Gas
And the third one maybe an inch lower. It will be to help split the top off, after I glue the box together…
Wood Motor vehicle Automotive tire Gas Engineering
had to reset the fence for the third groove. Test fits..
Wood Gas Machine tool Machine Lumber
Mainly to make sure the plywood panels were the correct size. I had to plane a bit off the long edges, was a hair too wide. Was keeping the fingers from closing up tight. I also made a mark, showing where a groove around the outside will go..
Wood Gas Hardwood Metal Wood stain
Offset from the inside groove. When the lid is split off, it will leave a lip all the way around. Like a dust seal. Need to set the Stanley 45's fence to make this groove, just in case I sand the marks off after the glue up ( normal luck)
Wood Natural material Wooden block Hardwood Lumber
Will have some long fingers to trim back. Now then..
Wood Gas Hardwood Wood stain Plywood
Once this comes out of the clamps, will this be the "Top", or..
Wood Gas Hardwood Plywood Wood stain
Or will this one be the top…...stay tuned…
Ok, a picture of my "work area", before the mayhem began..
Wood Cabinetry Workbench Machine Tool
Nice and clean and orderly…....for a few moments, anyway…then the fight began…
Wood Tool Saw Metalworking hand tool Gas
Used a bunch of clamps, a bit of carpenter's glue, and a lot of cussing….
Wood Gas Building material Lumber Metal
Details….details. Will let this sit for a day…..stay tuned.
Ok, after a repair of a broken end piece..
Finally got to where I could run the Stanley 45 around the outside..
The inside and outside grooves were not a perfect match, I wanted them to "miss" each other. otherwise, the box would break apart while I was cutting the last groove. Once the groove was run all the way around, I could finish the "split" with a knife, Then the fun can begin. Needed to thin the lip a bit, to fit inside the lid..used an old shoulder plane for that..
Ran it along the side of the lip, testing the fit of the lid as I went..
Once it did fit, I could clamp the box and lid together, sand away all marks, add the latch and hinges…hinges needed a pilot hole, for them tiny screws..
Used a push drill, with the smallest bit it had..
Spokeshave and plane for detail work, getting rid of high spots. Time for a PIP?
This is the lid's top panel. I choose for the way the grain looks. Just plywood
Front view, showing the latch…
This is the end that was repaired, repair is along the bottom edge…
And this is the non-repaired end. Needs a rub out, and a second coat….should be about ready to post as a Project?
I love how you did this! Great job. Glad to see it finished. I especially appreciate the hand-work that went into this. Glad you got if finished!
Just re-read it again (4th time?). Really a great post. Totally by hand. Simple box, simple joints, but it all requires skills with the hand tools AND sharp hand-tools.
1 - 8 of 8 Posts
