Veritas - Detail Palm Plane (Flat) (Rating: 5)
Pro's
Awesome little plane, once adjusted it will do a very good job of planing flush in tight spaces or very detailed work.
Con's
Somewhat tricky to get the blade into the plane after sharpening without nicking the corners.
Blade took a bit of work to get the machining marks out of it, and the base of the plane was slightly cupped, which required some lapping to get it flat.
If these sound minor, they are…once set up you'll find yourself using this thing just to use it.
