1 - 20 of 59 Posts
Discussion Starter · #1 ·
Making tracks preperations
Below you can see how I started with making tracks for my excavator tracks are made out of wooden strips. I'm sure there are orther ways for making tracks and I don't say that mine is the best! So feel free to comment this blog and/or make a suggestion for improvements.
Wood Rectangle Wood stain Hardwood Gas
Table Wood Floor Flooring Wood stain
Wood Table Road surface Flooring Floor
Brown Wood Flooring Floor Font
Wood Asphalt Flooring Floor Hardwood
Wood Rectangle Flooring Wood stain Floor
Wood Gas Hardwood Wood stain Trunk
Brown Wood Table Flooring Wood stain
Font Brand Electric blue Logo Graphics
Thank you Dutchy.
My thicknesser with a Byrd Shelix cutterhead gives a hand smooth finish, but thanks for the like.
What's the timber please??
Dutchy, Noticed your "preference" for the bandsaw over the tablesaw. Is there any reason (other than smaller kerf) as my bandsaw straight cuts suck… when I repeat it a few times it just simply sucks, sucks, sucks.
.... My thicknesser with a Byrd Shelix cutterhead gives a hand smooth finish….
- crowie
Sorry to deviate from the topic (again)... crowie, do you use a sled or will your thicky handle narrow pieces (what thickness?)?
very interested in how you make tracks
Discussion Starter · #6 ·
Thank you Dutchy.
- crowie
Thanks Crowie, see also next contribution.
Discussion Starter · #7 ·
- LittleBlackDuck
My shop is small and my saw machine is part of the heavy 5 in 1. To use this machine I have to make him ready and after sawing I have to store him again. Therefor I prefere the bandsaw above the circle saw, but for a lot of work the circle saw would be better.
I had wondered why the band saw, but hey it got it done and that's all that counts.
The spacing for the treads worked out just right for my table saw stock saw blade.
So I had figures you had planed it that way, but may be not, but it sure worked out great for me and the table saw.
Discussion Starter · #9 ·
Tracks themself
Below the process of making the tracks themself. The used wood is pacific teak (Intsia bijuga).
This tracks are made out of wooden strips. I'm sure there are orther ways for making tracks and I don't say that mine is the best! So feel free to comment this blog and/or make a suggestion for improvements.
Font Gas Circle Space Machine
Motor vehicle Yellow Wood Bumper Asphalt
Wood Natural material Bumper Hardwood Wood stain
Wood Gas Font Metal Rectangle
Brown Furniture Rectangle Wood Wood stain
Wood Scale Drill Gas Wood stain
Rectangle Wood Road surface Composite material Hardwood
Wood Rectangle Automotive exterior Floor Flooring
Brown Wood Road surface Slope Flooring
Brown Hood Automotive tire Wood Rectangle
11
Brown Table Wood Rectangle Textile
Brown Wood Rectangle Flooring Floor
Automotive tire Gauge Measuring instrument Temperature Home appliance
Wood Rectangle Flooring Floor Wood stain
Kitchen appliance Liquid Wood Gas Machine
16
Wood Rectangle Font Hardwood Flooring
Brown Wood Rectangle Font Hardwood
Gas Electrical wiring Electricity Machine Nozzle
Tracks themself
11
16
Thank you , thank you. Dutchy. I will be trying very soon.
Premium Member
Tracks themself
11
16
uummmm….. no jig for sanding bevels :<))
Tracks themself
11
16
Very interesting we've now seen 3 completely different ways to get the treads made.
I wonder how Gr8hunter will do his, and as I've been known to say there's a hundred ways to get it done it all depends on the builder and the tools at hand.
Premium Member
Tracks themself
11
16
Very interesting we ve now seen 3 completely different ways to get the treads made.
I wonder how Gr8hunter will do his, and as I ve been known to say there s a hundred ways to get it done it all depends on the builder and the tools at hand.
- htl
I think I am going to run mine on table saw …. but I will run 3 foot or so long then cut shorter …. this is my first plan A anyways …. we will see :<))
Tracks themself
11
16
Not having done the build, so I may be talking with forked tongue, however, rather than
any thoughts on making a similar jig to this,
with 45° triangles on each end to hold a number of tracks for bevel edge sanding.
As mentioned, I am only brainstorming and I could see an issue with the application of too much pressure on the triangles could pop/slide the tracks ou. However, with a little more thought and the right pressure (you would need to choose the type of clamp carefully), bulk sanding may shorten the production cycle time.
Just to get other readers thinking juices flowing….
Rectangle Line Slope Screenshot Font
That would not be a good choice of clamps… it was the only one I had in SketchUp… carpet tape would probably serve better or at least supplement soft clamping.
I'm assuming that's a flap sander to remove the splinters… or you have a bad case of mosquitos. What grade is it?
Discussion Starter · #15 ·
Tracks themself
11
16
- Orvile Baker
"if you real like doing something you will always find a way no matter what."
Discussion Starter · #16 ·
Tracks themself
11
16
- GR8HUNTER
any thoughts on making a similar jig to this,with 45° triangles on each end to hold a number of tracks for bevel edge sanding.
- LittleBlackDuck
In the time you have made a jig or even stick the tracks to the carpet tape I'm ready with sanding. For a bevel of 2×2 I need to move the track about 10 cm. on my sanding disk, for a 1×1 bevel 4 cm is enough.
Discussion Starter · #17 ·
Tracks themself
11
16
I m assuming that s a flap sander to remove the splinters… or you have a bad case of mosquitos. What grade is it?
- LittleBlackDuck
It is a steel brush, maybe a brush with a synthetic material would be better, but I didn't have one and after a try with the steel brush there where no mosquito isssues. However it depends of the wood of course.
Tracks themself
11
16
..... For a bevel of 2×2 I need to move the track about 10 cm. on my sanding disk, for a 1×1 bevel 4 cm is enough…..
Sorry Dutchy, but your sanding skills leave mine in the dirt… my sanding skills suck a tad more than my bandsawing skills.
Furthermore your maths have me a big "slightly confused"... is that 2×2 quote for, big or small values of 2?
It was just a thought thrown up in the air to see where it might land…
It is a steel brush,....
- Dutchy
As someone once said there are 100 ways… I would never have thought of a steel brush… or even a synthetic hybrid… I'm far from a master of sanding but my "expertise" is limited to sand paper.
Handy bit of info nevertheless.
Premium Member
Tracks themself
11
16
ok here we go :
FIRST I CUT TO SIZE
THEN RUN THRU ONE WAY TURNED AND RUN AGAIN THIS GAVE ME 2 CENTER SLOTS
Furniture Table Wood Rectangle Bumper
THEN I PUT ON SACRIFICIAL FENCE TO RUN OUT SIDES
Table saws Wood Bumper Automotive exterior Machine tool
THEN DONE
Wood Bumper Floor Flooring Wood stain
Wood Bumper Automotive exterior Rim Metal
Discussion Starter · #20 ·
Tracks themself
11
16
Human body Finger Gesture Thumb Comfort
1 - 20 of 59 Posts
