Euro32 Corner Clamp - Plans for shop made corner clamp (Rating: 5)
Price $6.50
11 page detailed plans showing how to build and use this corner clamp
web page - www.Euro32products.com
Cost of a single clamp - approx. $8.00 (if you use a hex nut instead of the cam lever cost is approx. $3.00)
I found the plans to be very well written / drawn. Simple construction with no complicated joinery. The result is a clamp that is very well made and does what it claims. As designed it will work with 3/4" stock. It can work with different width stock with the use of spacers but this is not suggested in the plans.
This was an inexpensive, easy to build project using common material and hardware. The results are a well designed and functional corner clamp that was well worth the time and effort to make.
Bill
