Equipment upgrade
6533 Views 19 Replies 7 Participants Last post by  pottz
2
Mackissic Mighty Mac upgrade
Wheel Tire Plant Riding mower Vehicle
Upgrade to my Mighty Mac chipper/shredder from wheelbarrow style to garden tractor trailer.
1 - 20 of 20 Posts
4
Window Grass Plant Wheel Groundcover
Closer view
Hey,Can you give me more information about this upgrade and what benefit I can get through this upgradation.
bumper cover
Building The Very Super Cool Tools table saw fence
VSCTools fence upgrade to my old DeWalt
Wood Floor Flooring Engineering Gas
Wood Floor Flooring Gas Composite material
Wood Floor Automotive design Flooring Gas
Table Furniture Office chair Desk Computer desk
Wood Automotive exterior Bumper Gas Automotive tire
Part 2
Link to VSC Tools
https://vsctools.com/shop/product-category/table-saw-fence/
Automotive design Wood Gas Engineering Automotive exterior
Nice upgrade. I hear very good things about them. I built my own that is very similar, but I put the fence rail on the flat instead of the edge. I love the lower profile that way, and how often do you need a taller fence anyway? The rare times I do I bolt on a piece to the fence. Can these fences be installed on the flat too?
Yes, all six channels are the same it would be easy to rotate it.
I added the VSCT fence to replace my problematic Biesmeyer a year ago, great upgrade!
The expensive part is the actual fence extrusion. VSCTs remachines their extrusions to be dead flat, but you can order the same extrusions on eBay for a lot less, alas they rarely are truly straight. I have seen two examples of 4 foot lengths, one has a "bend" of about 0.060" over the length, the other was about 0.010" off.
You can get the hold down hardware on Amazon for less then from VSTCs.
You'll love it!
- splintergroup
What might be the search terms for the hardware and extrusion? I can have one milled flat easily enough at the machine shop.
The hold-downs they suggest are from JessEm, they show a lower price at VSC Tools now than on Amazon.
https://jessem.com/collections/table-saw-accessories/products/clear-cut-ts-stock-guides
I used these
Currently out of stock, but there were many other vendors at the time. I had to file off a few burrs on some of them to make them slide better but overall they did the trick.
There are two choices of bolt size (I went with the M6), but I feel the smaller size would be plenty adequate and easier to fit with accessories.
The extrusion can be found "everywhere" online, A quick eBay search shows this 1 meter long section (look for a longer piece, the VSCT part is 48" for their long option).
The parts are called out by their dimension (metric) such as 4080 (40mm W x 80mm height). The "series 40" dictates the thickness.
Laguna 12 16
Upgraded my pitiful Steel City Lathe today with a Laguna 12 16, I don't do much turning but this is a huge upgrade.
Electronic instrument Gas Audio equipment Auto part Machine
Laguna 12 16
congrats, ive been checking those out.make sure and do a review when you get some time on it.
Laguna 12 16
I have the same 1216 lathe, and it's a great tool.
Mine has the optional leg set with mobility kit, and that is solid too.
Have fun with it!
Laguna 12 16
Building Toolroom Engineering Machine Retail
Passive circuit component Circuit component Hardware programmer Engineering Building
Updated my work area
Laguna 12 16
hey since youve got that fancy new lathe why dont you check out the bowl turning swap thats starting after the first of the year.lots of fun with a great bunch of guys.you dont have to be a expert turner and you dont have to turn a bowl,it can be anything on a lathe,or hell doesn't even need to be done on a lathe,you can carve it by hand if ya want.check it out.
Laguna 12 16
I have not tried much with it yet, mostly practice but I will keep an eye out for the swap info.
Laguna 12 16
My Christmas gift to myself showed up in the mail today. double ended gouge 1/2" spindle with bowl on the other end.
Automotive design Wood Motor vehicle Automotive tire Engineering
Hood Wood Bumper Automotive exterior Gas
Laguna 12 16
nice gift gary,enjoy.
1 - 20 of 20 Posts
