Never messed with the epoxy but that's some nice looking plywood for sure
+1. It's got character, so show it off.It looks great the way it is.
- Aj2
The OP asked about filling with epoxy. So, while he doesn't mind the look of the knot hole, I assume he would like to have it flush with the surrounding surface. Once filled with clear epoxy and sanded smooth to the same grit as the rest of the panel and then a finish applied, it will all have the same degree of gloss and the knot hole will not appear any more obvious or different than a bare knot hole. He can try to match the color of the surrounding wood, but then he loses the character of the knot. And, unless the match is near perfect, it looks fake which is what he had to start with the factory filler.It looks great the way it is.
- Aj2
+1. It s got character, so show it off.
The problem with clear fillers is that they do what a pool of water does-refract the light. That makes it look fake.
- Rich
That might be true for raking light, but when you look at it straight on, it will refract the light and be very visible as a fill. This is not speculation, I've done just what you described, and discovered that clear filler isn't the invisible fix I thought it would be.Once filled with clear epoxy and sanded smooth to the same grit as the rest of the panel and then a finish applied, it will all have the same degree of gloss and the knot hole will not appear any more obvious or different than a bare knot hole.
- bilyo
Assuming you are correct, who cares? The object here is to keep it looking like a knot hole with a smooth surface over it. If the OP wants it to be "invisible" he would fill it and finish it in such a way as to make it blend perfectly with the surrounding surface. That is a whole new set of skills.Once filled with clear epoxy and sanded smooth to the same grit as the rest of the panel and then a finish applied, it will all have the same degree of gloss and the knot hole will not appear any more obvious or different than a bare knot hole.
- bilyo
That might be true for raking light, but when you look at it straight on, it will refract the light and be very visible as a fill. This is not speculation, I ve done just what you described, and discovered that clear filler isn t the invisible fix I thought it would be.
- Rich
OK. I understand what the OP was asking. Aj2 suggested it looks good as-is, and I agreed. I also offered my experience-which is extensive-concerning clear fills.Assuming you are correct, who cares? The object here is to keep it looking like a knot hole with a smooth surface over it. If the OP wants it to be "invisible" he would fill it and finish it in such a way as to make it blend perfectly with the surrounding surface. That is a whole new set of skills.
- bilyo
i gotta agree with rich here,ive done clear epoxy and well, i wasn't happy.for filling knots i go with dark brown or black tinted epoxy.Assuming you are correct, who cares? The object here is to keep it looking like a knot hole with a smooth surface over it. If the OP wants it to be "invisible" he would fill it and finish it in such a way as to make it blend perfectly with the surrounding surface. That is a whole new set of skills.
- bilyo
It won t blend perfectly, but if you would like to believe it will, go for it. Maybe someday you ll actually try it and see what I m trying to explain.
BTW, all of this nonsense is probably moot since the OP seems to have left the thread.
- Rich
It takes time for our awesomeness to rub in, NathanJeez. Some people do have lives outside of Lumberjocks. I guess he hasn t learned that we are so entertaining that he should have glued himself to the computer.
- Lazyman
