Oneida - Dust Deputy (Rating: 5)
My intention for this review is to share my opinions contrasting two Dust Deputy (DD) dust collecting setups that I've built. The first is a Festool CT MINI + DD and the second is a Fein Turbo I + DD. If you have examined the many other reviews here and elsewhere for the Oneida Dust Deputy you will already know that this little wonder performs above most people's expectations and that it is one of those devices that has a simple design and great performance. I really would have preferred to add a dedicated dust control system with duct work distributed throughout my shop however I am limited to a 20 amp 120 V service to my remotely located shop. Upgrading the service would require an investment that I am not prepared to make.
My first unit is married to the Festool CT Mini; I use this setup primarily with my Festool RO90 and Bosch 6" ROS as well as to clean around the shop and to detail our cars. I have been completely satisfied with the performance of this combination for all of these tasks. I decided to add dust collection to a pair of miter saws that I have in another part of the shop where I wanted to have a dedicated collector for this use as well as regular shop cleaning. I already had an older Fein vacuum that I have been using in my basement shop for years and have been completely happy with its performance but the shape of the unit does not lend itself to an easy or efficient conversion to accommodate the DD.
Gas Machine Window Sports equipment Audio equipment
Vacuum cleaner Gas Flooring Machine Electrical wiring
That's the background info. Now I will describe each of the two builds followed by a short pro / con assessment of the components. My goal is always to use the smallest number of components, to move air the shortest distance, maximizing efficiency and do so in the most economical way. My view on selecting a vacuum is that the storage capacity of the vacuum is irrelevant because virtually no material ever makes it to the vac.
When I started my first collector, the Fesstool build, I purchased Oneidas' 10 Gal. Dust Deputy Deluxe kit. This kit includes the DD, a Metal 10 gal can with a spring clip sealed lid, a 4 wheel caster set for the can and a 2.5" sturdy flexible hose with slip fittings on both ends. After some experimentation I decided that I wanted to minimize the footprint of the collector setup and make the setup easy to navigate through my cramped shop so I ditched the wheel kit for the collection can and mounted the can on top of the Mini. This was easily done by fabricating a plywood platform that I mounted on top of the Mini. I used 1.5" sch 40 pipe and fittings to make a riser from the Minis inlet to the top of the DD. After a couple of wraps of electrical tape was applied the hose provided with the Mini fit over the inlet to the DD.
Photograph White Automotive tire Light Tire
Gas Cylinder Machine Composite material Liquid
Material property Cylinder Gas Cake Engineering
WARNING Short Rant Ahead: I did wind up playing musical chairs with too many fittings to mate the DD to the PVC because we all know what a wild west it is out there when it comes to dust collection fittings; ID vs OD, tapered vs straight etc. etc. It boggles my mind that there is no standardization for fittings, hose and tool attachments, definitely a pet peeve of mine. You wind up kissing a bunch of toads and spending too much $$$ before you find your Princess. Eventually I wound up where I am and have been happy with the setup for the 3 or so years I have been using it. The DD is so efficient that I am still on the first bag and HEPA filter!! I do blow the HEPA out a couple of times a year and almost never observe any dust being released from it. This past winter while Covid housebound I stripped 2 rooms of their wallpaper resulting in more than a little spackle work. I used both sanders and I was amazed at how little dust wound up in the rooms and in either of the Minis filters. FYI - Mirka Abranet on medium to low speeds worked great for this task.
When I started the new build I decided to go with a Fein partly because it was less expensive ($290 for the basic Turbo I w/o attachments vs $590 for a Mini) and as I have said I have been very happy with the performance and durability of my first Fein vacuum. I did give up some options like variable speeds but I'll address that in my summery. I made a plywood platform for the top of the Fein starting by making a pair of spacers from two pieces of scrap wood planned to a thickness that filled the void between the top of the vacuum and the rim on the periphery of the top. The plastic top of the Turbo I has a number of screws set into deep recesses, a 3/8" dowel fits nicely into these holes so I installed 3 dowels into the wood spacers then attached the plywood to the pair of spacers.
Automotive lighting Luggage and bags Bag Bumper Automotive design
Automotive lighting Motor vehicle Bumper Automotive tire Automotive exterior
Automotive design Bumper Wood Audio equipment Gas
OK , now I have a decent collection of orphaned and unused fittings which I have amassed over the years while trying to get the parts I wanted for any particular tool attachment setup.
Automotive tire Automotive design Alloy wheel Automotive lighting Rim
I found that a 90 degree elbow that I purchased from Oneida (they actually have a nice selection of fittings for sale and at very competitive pricing) fit nicely into the Fein hose inlet port, the same elbow would fit the top input to the DD. I also had the 2.5" hose that came with my original DD 10 gal kit set which I never wound up using ( which you can purchase separately for $17.00). With 3 of these elbows and the hose cut to length (unscrew end slip fitting from hose, measure - measure again and cut hose, reattach end to hose) I had the vac to DD plumbing completed. At the input port on the DD I again used another one of the Oneida elbows, I added a couple of wraps of electrical tape to help secure the fitting to the DD at the inlet as that joint would see some tugging and stress as the hose gets moved around from one machine to another and while cleaning the floor etc. I had a whip of hose (1.275" ID) with ends attached that I have no idea where or when I got it but it does look like one of the hose setups that Oneida offers. This slip fit securely into the elbow at the DD and terminates with a tapered fitting having two different ODs, one at 1.475" and the other 1.15" tapering to 1.18", the ID here is ~1".
Household hardware Audio equipment Auto part Metal Nickel
Gas Automotive design Plumbing Auto part Machine
While trying to build this setup I called Oneida and spoke to a sales rep (always helpful, I recommend using their experience when you run into a system design wall), I complained about the industries lack of standardization and the frustrating process of finding the right fittings. He commiserated with me over this issue and explained that is why they try to give complete specs on their fittings (ID, OD). He also gave me some valuable advice, that you can often solve a connection puzzle with automotive fittings, i.e. coolant hoses. Bingo. I had been trying to solve the riddle of how to get my hose to attach to each of my miter saws. I was attempting to solve this issue by using 2,3,or 4 fittings for each machine and none of the solutions had a 90 degree component which was something I really wanted. The fitting on the end of my hose, as I said, has a section with an OD of 1.475", close enough to 1.5" that I was confident it could work in a fitting with an ID of 1.5". My Delta saw had an OD on its dust port of 1.733" (close enough to 1.75" for me) while the Makita's port OD was 1.456" so 1.5" was the goal. I searched on line and found one silicone rubber elbow with both ends sized to a 1.5" ID (fits the Makita) then found another elbow with one end at 1.5" and the other at 1.75" - Delta problem solved. Both fittings are thick yet compliant silicone and the hose end fitting fits into them very well, I did install a pipe clamp on the end of the Delta fitting to constrict the opening ever so slightly but still maintaining a slip fit.
Engineering Gas Motor vehicle Machine Electrical wiring
Bicycle handlebar Bicycle part Bicycle fork Automotive tire Rim
Wheel Tire Crankset Bicycle tire Automotive tire
Here are my Pros and Cons of the two vacuums in the systems. I will say that I like both of them so I will only point out variations that may be important to your particular need. For instance both vacuums are quiet, have auto on options, long cords etc. so no pro or con with regards to these and other shared features:
Festool Mini Pros:
• Variable suction: the unit has a knob where you can adjust the units CFMs
• The hose feels more rugged and has held up very well to abrasion and missteps over the years. The Fein feels perfectly functional, it is flexible but softer if stepped on, time will tell.
• There is a brake, in the form of a retractable foot that helps to keep the vacuum from moving if you want it to stay put - think vacuuming a car on a sloped driveway.
Fein Turbo I Pros:
• Less expensive
• The switch height is not as low to the ground; 9" on the Festool and 15" on the Fein. If you have issues with your back the 6" difference is a big deal. It was one of the main features that weighed in my decision.
• The Fein definitely moves more air. This is obvious while cleaning the floor, or bench top. I use the same cleaning attachments with both units so this is a fair assessment. For sanding I think both are probably equally competent.
• Caster system, this is a personal preference. The Festool Mini has a pair of fixed wheels and a pair of swivel casters while the Fein has 4 swivel casters, which makes the Fein much more maneuverable. If you plan on setting your collector in a location and rarely moving it around no advantage however if you plan to drag it around the shop it does have its advantages.
Tire Automotive tire Automotive lighting Gas Automotive exterior
Wood Rim Gas Wood stain Auto part
Tire Wheel Automotive tire Rim Tread
Dust Deputy Options:
My first DD purchase was the 10 gal. Deluxe kit ($200.00), while the second was the "DIY" bare bones version ($50.00) because I preferred to go with a metal collection can for my second build vs a plastic can and lid. The 10 gal kit option was almost 4x the cost of the DIY, I thought I could locate a metal can elsewhere and didn't plan to use the hose and caster system so why pay for them. I found a metal can and lid on Amazon ($30.00). The Oneida can is much heavier gauge metal and will stand up to a lot of use. My econocan is much thinner metal so I reinforced the lid with thin plywood before installing the cyclone. Also, because of reviews stating that these cans tend to rust easily I spray painted the outer weld seam as well as the entire inside of the can. Additionally I made a ring from stiff 3/4" hose with a dowel joiner to fashion a doughnut that fit tightly half way down the tapered walls inside of the can to help resist collapsing. I tested the can without the ring and didn't see or feel the sides of the can trying to collapse but better safe than sorry? In retrospect I think that had I gone with the Oneida plastic bucket with their reinforced lid I might be just as happy with less work on my part.
As that crazy rabbit said, "well that's all folks". I hope this helps someone navigate their way through designing a collection system for their shop.
