1 - 20 of 78 Posts
I have been reading about how to install my dust collector and the piping/duct work.
I read several place that "plastic" piping should not be used because of the static electricity concern.
I was planing on using ABS or PVC.
Is this a real concern?
What is your experience?
What do you think about this?
Addtion:
I am reading Bill Pentz's blog.
He writes that 4.00" duct is really not large enough to move enough air to get the small wood particle (the most dangerous for our lungs) out. He recommends to run at least 6.00" duct.
Is this overkill?
What do you think?
Thank you.
Bert
for small shops and the smaller DCs (and cyclones) this really does NOT warrant any issues, worst case you'll get some light static charge on the outside of the pipes. the real concern is when you use the high load industrial machines in large shops that have a lot of fine dust in the air.
that aside - I think PVC are OK to use in the shop, but since you are planning to install those concealed and permanently under the floor - might as well go the extra step and use metal plumbing for the efficiency of it as the metal plumbing interferes less with the air flow and is has smoother walls.
mind you - depending on the DC that you use, and the runs that you intend to install, 4" pipes may or (more likely) may NOT be the best size. 6" may also NOT be the best size if your DC cannot support the airflow.
planning a proper DC system takes time and preparations to make sure you do it right.
Any system will do provided you have the screen filter on every suction point.. 4 inches is quicker than 6 inches. The voilume that you have to pump matters with the time. It is just like the compressor. Shavings for example can clog your system if it forms like a ball of 6 inches. NOTE: BENDs specially sharp bends reduces pressure.
For a few bucks, an HVAC engineer can size your ducting according to the cfm of each machine and capability of your collector.
Use the search function, I found when I asked a few questions about DC systems, a lot of it has been covered here over the years and there have been really good threads earlier.
I agree with the plastic pipe, should not be an issue in your situation.
My DC is running under the shop floor as well, fittings should be ready this week and installed on the weekend… (keeping my fingers crossed).
I have been designing/working around hydraulic and pneumatic systems for many years.
I can see that there is a limit on how big a duct I would want to install because as I increase the diameter I reduce the air velocity and I believe that the velocity is what carries the chips away.
As much as possible, without reducing the diameter so much that my ducts will clog all time, a smaller diameter should be better as the air velocity is higher.
Now I also have to dial in the pressure drop and other restrictions due to the fittings.
I use the HF 2HP dust collector. It has a 6.00" port.
I think that I am going to install a 6.00" main duct with 4.00" branches and that everything should work fine.
Now the next issue is that to install a 6.00' duct on the concrete slab and to build a floor on the top of it will require using at least 2.00"x8.00" lumber.
Does nay one know about rectangular plastic ducting?
May be 4.00×6.00 which would allow me to use 2..0"x6.0 instead?
Thank you.
Bert
I would personally go for metal ducts and get away from plastic at any means possible also if you insist placing it in the floor please plan for cleanouts and do not go under 6" dia. pipe. running it overhead you don't loose much height, cleanout is a snap literally, and your D/C can pull in chips not lift them out of the floor. By pulling chips out of the floor EX. the 6' run to D/C plus a straight 90 degree elbow adds approx 15-20 feet of pipe cfm to a system.
Discussion Starter · #7 ·
Thinking about what I wrote , I realized that to have a 6.00 main duct with 4.00"branches would be a mistake, counterproductive and a cause for problems as the flow coming from one machine would enter the main duct the velocity would drastically drop causing the debris to fall and to lay on the bottom of the main duct.
I believe the keeping the duct diameter constant would be better.
Bert, almost every system I have seen begins with a larger main run, with smaller ducts running off of it.
Mine has a 7" main, with 5" and 4" runs under the joists.
My DC sits on the main floor (shop is in the loft) so it pulls the dust / chips as if it was installed with overhead ducting, but installing 30 degree elbows in your case should help.
Bert - Technical question. I also have a HF 2hp DC and some tools that are sized for shop vac 2 1/2" hose. I use the full 6" with hose for table saw, planer and v-drum sander. For the others (router, miter saw, band saw) should I reduce to 2 1/2" at the input to impeller?
My shop doesn't allow me to have fixed piping, so moving the DC and tools is how my life goes.
Steve.
Alot depends on what tools you are using and the cfm required by them. You didn't say which DC you have, that will also effect the size of your pipe. b2rtc is right with a 6" main and 4" branches, there's alot of people that have the HF DC and will probably jump in here. Go back to Pentz site again and use his calculations to figure it out. Never heard of anyone using square vent??? Plastic is the way to go. Easy to change and add on when necessary.
FYI… check Bill Pentz requirements for the motor spec and blower size in order to utilize 6" ducts… quite a bit higher than the HF 2hp DC…
and no - you should NOT use rectangular ducts for DC. those are good for PUSHING conditioned air and air alone - but not designed for PULLING dust. you'll need circular ducts that have minimum drag on the air flow.
Bert. the benefit of metal is not the grounding although that is a nice small benefit that comes along the way.
metal ducts have a much lower air resistance than PVC and bottom line - provide with a higher CFM to your machines.
here's the thing. in my book - one should use metal ducting as those are dedicated for that purpose. now - ask yourself, for what reason would you NOT use metal ducting?
the only reason that comes to my mind is $$$ - PVC is by far more affordable. so the question remains - are metal ducts out of budget?
if they are - use PVC, it'll work, as many people use it. I wouldn't even worry about grounding as for small shops it really isn't that major.
But - if you are building something for the long run, and plan on efficiency - I'd go with metal ducts.
Why would a metal pipe be more efficient than a plastic pipe of same ID?
In fact, since I have been working with both, I believe that PVC or ABS is probably smoother than metal and so creates less turbulence and a better flow ( I could be wrong).
Three reasons to go plastic: price, availability and ease of installation and modification later on (OK that make four reasons).
plastic pipe has thick walls and take up CFM area making it less efficient Static electricity is a bad concern also metal ducting is the way to go, avoiding connector issues from under/ oversized PVC pipe I was a plastic process tech for years and die swell from an extruder can vary .10 up to .50 and be a real pain with plastic D/C fittings. the cost you save per ft of plastic pipe you will spend on connector to make it up at blast gates etc. BTW the cost of grounding PVC pipe depending on how long it runs can add to the cost also.
to answer your other question on square ducts simply put is NO sawdust can and will lie in square duct as it needs to be moved like water in a pipe not like a conveyor the roundness also helps keep build up down and minimizes high impact jamming of large chips and keeps things easy to clear
Keep us posted:)
SAwblade1, did you read this:
http://home.comcast.net/~rodec/woodworking/articles/DC_myths.html
If I use PVC or ABS I shall not ground it.
If I ground it it would only because I got tired of getting shocked.
By the way this article also answer those who told me that I should not install my dust collector outside, the code seems to say that a dust collector has to be installed outside.
Bert, the only issue I can see with putting the cyclone outside would be that if you don't run the filter back into your shop, it will pull a lot of warm air out of your shop in the winter, thus cooling your shop temp.
I am leaving my system outside as well, until I can tell for sure how much heat it will draw out.
Our winters can be brutal, and if it is too much, will pipe the filter back into the shop, still leaving the cyclone outside.
The mechanical engineer that designed and installed my ducting (to be completed tomorrow) used as large a pipe as possible to my jointer and thickness planer (5"), as he said it would clear the big chips better than 4", and provide more velocity. I made new a new plate for my jointer so it has a 5" connection, and we had a reducer made for the thickness planer, taking the 5" pipe down to 4" at the machine.
We had special low radius elbows made and used mostly 6" and 5" spiral metal pipe, reducing to 4" for miter saws, drill presses, bandsaws, router tables, and sanders.
Mine is not grounded either.
Will let you know how it will work as soon as I can!
All the best with yours!
Those codes really only apply to large commercial installations. Those same codes call for explosion vents to the outside and I don't think any of us have those, either :)
The actual danger of a fire due to static electricity in PVC pipe is very low, and that is only if you are running your DC non stop for an extended period of time. Also running a cable inside your PVC pipe has no more advantage than a copper wire running on the outside of the tube, it would be much easier to just tape one along the side if you are concered about static electricity.
In my reading of Bill's blog, I thought he recommended 5" and larger, but recommends 6" as it is more common. I do agree that for a main trunk, the larger lines are needed if you can run them at all, and if your DC will support 6" then go with it. Mine will do 5", and I am planning on running 5" to a 4" branch line to each machine. 4" to the machine should support the dust collection I need for everything, including the table saw / blade guard. (going with a 5×4x4 Wye for that particular application…)
As far as metal VS. plastic goes. Plastic is safe in small shop environments. You "can" ground plastic, and there are companies more than willing to sell you grounding kits, but it seems rather pointless. If you are that worried about it, go with metal all the way…
1 - 20 of 78 Posts
