1 - 19 of 19 Posts
Does anyone have a trick or technique for assembling dust collection hose to fittings that are a very tight fit? It seems like everything I get from Rockler is the same diameter. The hose to blast gates are too tight of a fit, the hose to coupling (to splice two hose lengths together) is too tight of a fit, etc. It seems like the hose should be a touch bigger and these thing should go together easier. I struggle to get the hose pushed over the blast gates, dust ports on my DC, and over the coupling. Then it's a struggle to keep them on while fastening the clamps. I thought about heating the hose slightly with a hair dryer or using baby power to slip the pieces together, but I thought I'd tap you guys as a resource first. Any ideas?
I'm using 4" hose, 4" couplings and 4" metal blast gates from Rockler. I have a Delta 50-850 DC and I also have the quick release fittings from Rockler on all of my machines and they all fit together very well.
Thanks
Fittings only connect to couplers or hose. Both hose & fittings are measured by ID, not OD! I had to X cut the couples and use SS band clamps. Some fittings I was unable to figure out and are connected by metal tape. It is not you, it is very confusing, and I wound up with an assortment of 'extra' bits. It took me 9 mo to get it finalized and drawing right.
Cylinder Engineering Gas Motor vehicle Plumbing
Engineering Gas Machine Industry Factory
Black plastic Rocker duct work, Penn State metal duct work & PVC do NOT easily interconnect as they all have different wall thicknesses for the same nominal ID.
M
Discussion Starter · #3 ·
Thanks, Mark for your input. The sad thing is that I listen to the guys at Rockler, buy what they suggest, do what they say to do, and it is still so difficult to put it together. I have noticed that my older black hose fits together with all the other parts very easily. It's the new clear hose that seems so much smaller in diameter. Yet, both claim to be 4". Also, this new clear hose is packed in 3' lengths but says it'll stretch to 10', well currently it's more like 6-8'. Maybe over time it will get to 10'. I have noticed the thicker walls and the ID being a difference, and that adds to the problem with the couplers and blast gates.
I have this problem with my SawStop and the Rockler Dust Right system. My SS has the overarm dust collection hose, and they supply a Wye adapter that goes on the port on the saw. Then I have the DustRight adapter on that, and then the quick connect handle on that. The joint between the Wye and the saw's port is too loose, and it often comes off when I remove the hose with the handle. I've considered drilling into it to fasten it to the SS port, but I could put a couple cuts and use a hose clamp. The rest of the ports seem to work okay for me.
It would be great if all manufactures of dust collection related equipment had a universal standard…but unfortunately they all seem to design their products to work primarily with just their own products with hopes you will buy everything from them. 4" should always be 4" regardless of who makes the fittings.
I also have used liquid soap to help struggling fittings on to other fittings that all claim to be the same size.
I had the same problem a couple of years ago while installing my DC system. I used a heat gun to loosen the flex hose, and it worked like a charm.
Discussion Starter · #9 ·
Thanks, guys. I'm going to give the dish soap a try. Heat gun if that doesn't do the trick. It's good to know I'm not the only one that has had issues with this.
I learned a trick back in my first job assembling bikes at a hardware store years ago. We used a squirt of Simple Green to install the hand grips on the bikes. They would slide right on the handlebars, and once dry they would hold tight.
Try Simple Green.
Discussion Starter · #11 ·
Willie, thanks for the tip, I'll remember that for down the road. The dish soap worked great. I got everything put together in about 20 minutes.
Buy your hose from Penn State Ind. It is inside diameter. I have a shop full of DC fittings that I bought through Rockler and Woodcraft that does not fit anything. I learned the hard way about trying to build a DC system using stuff from Rockler and Woodcraft.
JK0702,
Another option is a Quick Connect fitting that slips into the dust collection hose and the opposite slightly bell shaped end fits onto the machine port. However the bell shaped end can slip off a machine port. I suspect a couple of sheet metal screws could keep this from happening. There is also a splice fitting designed to fit inside two ends of flex hose. Perhaps this fitting would slip inside a dust collecting fitting. Grizzly also offers a wide assortment of dust collection fittings, a few of which might help out - if the dish soap fails.
Quick Connect fitting…
http://www.grizzly.com/products/4-Quick-Disconnect-Fitting/W1038?utmcampaign=zPage
Hose splice fitting…
http://www.grizzly.com/products/4-Splice/W1019?utmcampaign=zPage
I have not applied heat to a flex hose. I am not sure how much expansion one could achieve if the hose is reinforced with metal wire. I have used heat to soften and re-shape PVC pipe for my dust collection system. I ended up making an inside and outside set of MDF dies to get even shrinkage of the PVC. I have not tired this method with ABS fittings, which I think is the material used to make typical black ABS fittings.
Discussion Starter · #14 ·
JBrow,
I have both the Quick Connect system and the splice fittings. Both were a huge problem until I used the dish soap. I currently have my problem solved, but I'm already considering a couple of modification. I expect more problems as I proceed, but the dish soap has been a huge help.
John
I, essentially, have tubs full of fitting because you don't know what you'll need. Today, I decided I didn't want to get covered in shaving from my biscuit machine, so cut up a multi-fit end to tie into my little Dust Deputy.
Over on my three horse, I use black tubing as couplers for my upper and lower on the table saw, or to join two pipes. For that reason, I keep pieces of green, black and while four inch pipe for projects.
Discussion Starter · #16 ·
Kelly,
I tried fitting HD black 4" tubing and white 4" tubing, but both were much too big in diameter. I need to make a 90* turn at the back of my T/S and run it tight to the back wall of the saw. I'm having a hard time making it happen. If I use Rockler's 90, I have to use a coupler also. Now it protrudes too far out from the saw and hits my out feed table. I just have to keep trying different things, I guess.
Discussion Starter · #18 ·
ideally, you're right. However, I have to fit it between my T/S and my out feed table. I suppose I could try a 45 first, though.
John, as someone who works for one of those companies, selling the dc products is a pain too. Because, even though all 4" stuff should fit together, it doesn't. Also I have seen several of the black plastic fittings like the, 90 degree elbow, the 1 into 2 wye and a couple others and they look identical, including mold marks, which leads me to believe that both companies source many of the generic dc fittings from the same manufacturer.
And the 2 1/2" stuff is not immune either.
It is unfortunate that there are not standards in which manufactures followed.
The hardest thing is trying to adapt to shop vac fittings or various dust ports on portable tools. That is much much worse.
But the dish soap and simple green hints will be something to pass on in the future.
1 - 19 of 19 Posts
