DragonFly Harp
64753 Views 122 Replies 37 Participants Last post by  DonnaMenke
22
Planning, planning, planning
Hi, I'm Donna Menke and I enjoy making things out of wood. You can see more of my projects and links to other woodworking and carving blogs on my web site: www.woodworks-by-donna.com
I have some nice cherry wood on hand- so I'm going to make another harp similar to the last one, but with a few variations. Stocks above, and view of grain below.
Wood House Floor Flooring Building
Wood Flooring Wood stain Rectangle Hardwood
This is the harp I made from plans from MusicMakers back in 2007, out of walnut boards. http://harpmaking.blogspot.com/
Musical instrument Wood Plucked string instruments Grass Plant
Here is the rough stock being analyzed for the best sections to use.
Sewing machine Loom Wood Workbench Art
Cutting the big woods into littler woods makes them easier to handle. Here I'm checking the blade for square.
Wood Engineering Machine Hardwood Metal
Sometimes it seems like the planning can take longer than the creation, but it is a necessary phase in any project.
Why am I designing my own harp? I wanted to see if I could modify the Limerick plans I used for the walnut Rainbow harp I made in 2007. I wanted the soundbox smaller, and I wanted it to be self-supporting and as tall as the Heartland DreamWeaver that I have and like. I took aspects of lots of different harps and put them all together and this is what I came up with. I also wanted a harp that could be easily transported- like the lap harps, but also be able to stand alone like the floor harps, but even more, to not need to lean it against myself to play it.
The first step will be to make a model out of foam. The plan is to make it fairly close to reality so that I can get close to correct interfaces for the parts. I also want to sculpt the knuckle out of foam before
committing to wood.
I may be trying to do the impossible- but I have hopes that it will work.
Font Parallel Triangle Handwriting Drawing
Gesture Handwriting Slope Font Art
Plant Gesture Art Rectangle Font
Here I'm checking out possible layouts for the neck and pillar plans. These are not the final plans, but I can get an idea if I will have enough wood for the project.
Wood Flooring Floor Hardwood Wood stain
These are the boards that will be used for the sides.
Rectangle Wood Flooring Floor Hardwood
This is the sort of damage to look out for. The obvious nick at the end is one, but the shallow splitting of the wood further up is even more dangerous.
Table Wood Rectangle Wood stain Floor
I will run the wood through the planer to see if I can get below these 'shakes'. Right now the thickness is 1 7/8" and it should be 1 3/4".
1 - 20 of 123 Posts
22
committing to wood.
Donna,
We don't know much about musical instrument design and construction, but are wondering how the change in the size of the soundbox will alter the tonal quality of the music?
L/W
committing to wood.
All I can say is wow.
committing to wood.
Thanks, Jack.
LWLL- the sound is great. Every change I made seems to have been good. I'm very leased with the results of my experiment.
committing to wood.
what jack1 one said…........wow and double wow wow. just beautiful. I'll bet it sounds explicit! Do you play the harp Donna? If so, could you add a few strums, I'd really luv ta hear this beauty. thnx
committing to wood.
Thanks Roger- nice that you like my harp. I did post a followup including a link to a YouTube played on this harp.
Progress in Design
12-29-2010
Worked most of the afternoon on the harp mock-up in builder's insulation foam board. We have a lot of this material left over from when we built the house over 25 years ago. It is 1" thick so it will work out well. I have made projects with and without mock-ups and those with the model always work out better. I even made one of this house before building it!
Wood Automotive design Engineering Space Composite material
Here the plans have been transferred to the board and I've discovered that some of the stresses on the pillar are at too much of an angle if I angle it to the outside of the soundbox- so I'll have to go back to the original Limerick plans with the pillar ending inside the box.
Wood Automotive design Rectangle Hood Tints and shades
You can see in this photo that there was a lot of fiddling with the curve of the pillar before I feel that I got the best design.
Before quitting for the day I cut out two of each of the main parts and glued the matching pillar and neck pieces together. Tomorrow I should be able to figure out how to make the interfaces. Working with this foam is a lot easier than working with hard wood. Mistakes are easily corrected now- so that maybe later I can do it right in cherry.
Progress in Design
12-29-2010
Donna,
We're looking forward to following your blog. I'd love to make one some day!
L/W
Progress in Design
12-29-2010
I'm already looking forward to the next post!
Making the Pink Harp
Started the new year off right with many hours in the shop working on the harp project. I'll try to keep track of my hours- a good guess would be about 10 hours to date.
I don't kid myself that working with this foam is anything like working with wood, but I need to get a prototype before I can even think about making working drawings.
Wood Rectangle Table Electric blue Engineering
Table Wood Flooring Floor Rectangle
I spent a lot of time trying to get my styrofoam pieces to stay in the right plane before I got the brain storm to make some supportive blocks at the right angles. Note the high-tech fasteners. At least they are easy to reposition, but they are not too stable.
I ended up drawing a lot on the table top- should have laid a big piece of paper down first- but that would not have been as stable. Time to refinish the top anyhow.
Wood Wooden block Rectangle Art Tints and shades
Rectangle Tints and shades Magenta Brick Flooring
Finally got a piece to fit neatly into the top part. I won't show you the rejects- too discouraging. Suffice it to say that working with compound angles is difficult. The second layer isn't quite as pretty, but I have to shape it after I remove the model off the table, and I'm not there yet.
Wood Rectangle Gas Plastic Plywood
Wood Rectangle Flooring Tints and shades Hardwood
I have thought about how much easier it would be to make this harp with parallel sides- then I thought about megaphones and speakers and how they amplify sound- so I'm working the angles. On this base piece, for example, it has to follow the angles of the front and back (different angles, of course), as well as the angle of the bottom of the harp. . . and, fit fully into the bottom of the sides. That is another step that has to wait until I take the pink model off the table- tomorrow.
I'm really enjoying this new easier way to post photos. thanks to the genius who simplified the process.
What a great idea to use the foam as your prototype. Fun to follow along on what you're doing, Donna.
Coming along well Donna and interesting that you chose styrofoam to do a mock-up with. Will you be using the styrofoam to make patterns from for routing, cutting, etc.?
1/4/2011 Completed Model
Here is a good example of just how difficult joinery is with foam. Lots of slop and instant gratification- not at all like wood. Wonder if one can play a foam harp- nah.
Wood Office ruler Rectangle Ruler Material property
The foam model has been assembled for the first time- with toothpicks, tape, and chewing gum (just kidding about the gum). I tried to glue some parts with Titebond, but it never dried and didn't stick well. I've decided to return to the original plan to end the bottom of the pillar outside of the sound box. Hope it works. Everything else looks good to go.
Wood Material property Art Engineering Automotive design
Wood Hardwood Wood stain Composite material Gas
I'm designing and making the base for the harp now. If I say I'll do it later I know it will never happen, so I will do all the building at the same time. I have changed the base profile many times and ended up with this 'walking man' design. I like it. By placing the pieces altogether I can make the base to fit just right (fingers crossed).
Wood Automotive design Line Flooring Engineering
Wood Engineering Naval architecture Automotive exterior Space
I ran out of pink foam so we have a two-toned harp base. I also left these pieces 1" thick though the wood version will use 3/4" cherry. You can see my Heartland DreamWeaver next to the model for size comparison. Everything has so far fit better than I anticipated. Then again, foam is much more forgiving than hard wood.
As you can see in the last photo- this is a perfect fit for me- and I am a happy camper.
Wood Natural material Art Creative arts Magenta
Wood Natural material Art Magenta Automotive design
Hair Joint Shoulder Leg Fashion
Great idea using foam for the mockup Donna. Now you can begin with the real fun of building it. I can't wait to see it completed I'm sure much later on.
Try using hot glue for foam, works real well.
What kind of tension are those strings under? Looks like you have adequate support for it hopefully.
Eric- just vacuumed up the foam bits and pieces and next I'm going to need to dig out some more cherry lumber and hope it is in good enough shape to use for this project. After I get it all planed down to required thicknesses I'll be able to lay out my foam on the wood. I've decided to not make full-sized drawings since: 1. I don't have a drafting machine; 2. I'm anxious to start making sawdust; and 3. Things will change as I go along- so why waste my time. When doing a one-off, I've heard it is good to fit each part to the adjoining part. Hope that works.
What I will do is trace off each piece onto a large piece of paper so that if I want to recreate this project in the future I will have a ready reference.
I believe these nylon strings are only under about 450 pounds of pressure. It is a relatively small harp with 26 strings.
I didn't want a too permanent join for the pieces since I will be taking it apart and using the pieces as a start for the plans. I'll remember hot-glue next time. Thanks
Autumn- thanks- lot of work, but easy work. That foam is so easy- light- bendable- not like wood at all. I have seen harps with all sorts of configurations. The bottom of the pillar can end on the soundboard itself, though backed up with solid wood on the interior to the base; through a hole in the soundboard to the base; or just outside of the soundboard resting on the base. Through the soundboard is most common for harps of this size, but I like the looks of it outside so we will see how that works out.
The 'walking man' refers to the stand, whose legs look to me like a walking man.
Hi Donna.
Nice mock-up. If you used rubber bands as strings, you could "play" it. (grin)
I'd be concerned about the arrangement of the pillar with the strain that area will be under. It could easily twist the base out of alignment and cause a complete failure of the harp if it isn't braced in some way. 450 pounds of tension doesn't sound like much compared to the many times that ammount larger harps are subjected to, but when it is concentrated at one place and is pulling at the fastening of the base to the back, trouble is just waiting to happen. I'd brace that area in some way to avoid problems.
Hubby has already suggested the rubber-band idea. Maybe I'll try it before taking it apart.
About the strain- I'm not sure where you are noticing the need for bracing. Do you mean the base of the pillar or the base of the harp body? This is a good time to think about bracing if I need more. Easy to add now.
Thanks for your comment.
Smart use of a model and full size, too. I like the flow you've put in and how it all moves from top to bottom. The harp just grows right out of the base. I don't know anything about harp making, but this looks cool.
1 - 20 of 123 Posts
