DIY teak oil
1213 Views 4 Replies 3 Participants Last post by  Finn
Morning all. I've read several articles about making your own teak oil. I tried the equal parts BLO, varnish and thinner. I seemed quite watery. I would think if I add more varnish, or blo or less thinner ,it should thicken up.
Any one know of possible issues. I will defiantly try it on a piece of scrap first, but fore warned….....
Thanks
1 - 5 of 5 Posts
Where do you get "Varnish" ? I have never seen in in the big box stores.
Pardon me all to hell….Varathane.
a varnish is simply an oil with a resin hardener, most common varnish is polyurethane. The "teak oil" that you're describing Mark is also known as Maloof finish; typical recipe is 1/3 BLO, 1/3 polyurethane and 1/3 turpentine. I've used it; it is a nice warm finish but basically the same as any "Danish oil" product on the market.
"............. varnish is simply an oil with a resin hardener, most common varnish is polyurethane. ..." Thank you for this information. I will stop looking for varnish now.
1 - 5 of 5 Posts
