Dining Chair Build
5939 Views 10 Replies 6 Participants Last post by  PPK
Dining Chair Build
Furniture Chair Wood Rectangle Outdoor furniture
Here's what I decided to make, more or less.
Rectangle Schematic Font Line Parallel
I drew up some plans. I followed them pretty closely, but did change a few thicknesses of some of the stretchers. I red-lined them and will save them fro later.
Rectangle Font Parallel Slope Pattern
Plan of the chair back.
Rectangle Font Parallel Pattern Drawing
Plan of the chair seat/legs, from the top.
Saw Table Wood Handheld power drill Pneumatic tool
I glued up some blanks for the chair seats. Some people don't like the "mismatch" of hickory, but I absolutely love it. The more contrast, the better, I think.
Handwriting Wood Rectangle Table Floor
I cut out two templates (the second one is for a smaller set of chairs to go around the dining room table - future project) from baltic birch plywood, 1/4".
Wood Flooring Wood stain Table Hardwood
I used the templates to trace the back chair legs onto a piece of 8/4.
Wood Floor Flooring Composite material Hardwood
Then cut them out with my jigsaw. This was pre-band saw ownership.
Table Wood Flooring Workbench Hardwood
Part way cut out now.
Wood Machine tool Engineering Workbench Hardwood
I screwed the templates onto the chair legs in places that the mortises would be, so the screw holes would not be visible. This was a good plan, but I ended up changing the location of the mortises a little, so I did have to putty 2 holes in each chair. Oops.
Wood Table Wood stain Hardwood Tool
I took the chair leg to the router table with a big top bearing flush trim bit. This is tricky, and I ended up getting a few divots. I got good with the spoke shave and hand planes to clean up the legs after routing them. Since then I've bought two more hand planes! Its really fun when you get them sharpened and working right.
Wood Table Floor Flooring Gas
Ok, now on to the steam bending. Here's my steam box assembly. Nothing fancy here. But, after a few tweaks, it works great.
Wood Wood stain Hardwood Varnish Gas
I did end up wrapping the whole thing in 1/2" rigid styrofoam insulation, to get the temperature up. It now runs just over 200 degrees. I let the kettle run for about 20 mins or half hour to get it hot first. Then I leave the wood in about 1 hr. per inch of thickness, so about a 50 mins in this case.
Wood Wood stain Hardwood Plywood Lumber
Here's the simple form I made to bend the chair backs over. Sitting on top of the form is a compression strap I put over the wood. This forces the wood to compress, not stretch. Wood fibers don't stretch well. I had zero blow outs doing it this way.
Wood Flooring Floor Wood stain Hardwood
Here's the wood in the form, clamped and cooling. It does require VERY quick work before the wood cools. we're talking seconds. And it also requires a lot of force. More than my beefy vise can deliver. Hence the pipe clamp. Kinda like a turbo charged vise now.
Tire Wheel Land vehicle Car Vehicle
Once cooled, I clamp the pieces on the bench for about a week until they dry out to prevent too much spring back. I did end of with some spring back but it was just right, I guess I guesstimated the "over curve" just right!
I'm no pro at this, this was my first try. I'll be honest.
Table Wood Desk Rectangle Composite material
Back the the seats now. I traced the shape of the "butt impression on using a simple template.
Table Wood Composite material Hardwood Rectangle
Then drilled several holes with a stop collar on the drill bit to gauge my grinding depth. Once the hole is gone, stop grinding. Worked perfectly.
Table Wood Composite material Hardwood Desk
Now I've got a super rough seat . you can kind of see the cheap Harbor Freight grinding wheel with carbide bits embedded in it. After I used that, I used a "flapper disk" one of this disks with the little flaps of sand paper on the angle grinder to get some of the scratch marks out. Right about now I'm wishing hickory wasn't my favorite wood. It is HARD.
Wood Table Wood stain Hardwood Flooring
Then I spent lots of time with the Random orbital and progressive grits.
Wood Rectangle Wood stain Wooden block Table
Finally cut the seats to size and applied the finish.
Wood Composite material Auto part Automotive exterior Metal
Then I started cutting lots of mortises and tennons. There are a lot of them.
Wood Floor Flooring Wood stain Hardwood
I assembled the backs. There was a lot of dry-fitting that occurred.
Wood Hardwood Plank Composite material Wood stain
Here are the legs after getting mortised. Nothing fancy. Just 3/8" mortises. Not at all concerned about strength. Hickory is tough stuff.
Wood Publication Hardwood Tool Wood stain
I cut most all the tennons on the table saw. Used a shoulder plane to trim them if they fit too tightly.
Hand tool Wood Tool Burin Metalworking hand tool
I did end up cutting some of the shoulders by hand. It was easier than trying to set up the saw.
Wood Flooring Hardwood Wood stain Plank
All the parts laid out for sanding and assembly.
Wood Hardwood Flooring Electrical tape Rectangle
This was one of the tricky parts to make.
Wood Musical instrument Office supplies Writing implement Hardwood
I call it a "compound tenon." Its angled in both directions.
Wood Bumper Flooring Gas Hardwood
I used an adjustable-angle tennoning jig that I made to make these compound tenons.
Wood Composite material Flooring Gas Hardwood
I can adjust the angle in one plane by loosening the big eye bolts. The other angle I achieve by cutting a wedge of the appropriate angle. I actually used the SAS triangle math stuff I leaned in high school and it work out for me… lol Another shot of the jig with a peice in place to be cut.
Wood Floor Flooring Gas Hardwood
Ok, I assembled the fronts and the back separately so that I wouldn't be too overwhelmed with time constraints of glue setting up too fast.
Wood Workbench Floor Flooring Tool
Then I glued the fronts and backs together. Checked diagonals and adjusted when necessary to ensure squareness. I used TiteBond bottled hide glue for everything.
Product Chair Wood Natural material Hardwood
I installed some beefy corner blocks
Wood Gas Composite material Automotive exterior Hardwood
They have oversize holes to allow for the chair seat to expand and contract with seasonal changes and not split.
Wood Flooring Chair Floor Wood stain
I sanded scraped glue squeeze-out and sanded forever and day (yuck) and then applied a coat of danish oil and wiped on 3 coats of Arm R Seal.
Wood Natural material Hardwood Wood stain Flooring
There are some flaws than I notice, but overall, I'm happy.
Table Furniture Wood Natural material Wood stain
Wood Natural material Wood stain Floor Hardwood
I just don't point out the flaws to others, and they think they are great!
Thanks for looking, let me know if you have any questions.
1 - 11 of 11 Posts
Dining Chair Build
Thanks for sharing. I'm wanting to build my son a bar height table and chairs out of a couple of ash trees we cut down in his yard. I've been looking for a nice chair design for a year, and this is exactly what I'm looking for. Beautiful looking chairs and the blog will help immensely.
Dining Chair Build
I must say, these are great looking.
I am planning a very similar looking chair set to replace our kitchen set.
Have you considered bending the back legs instead of cutting them? Also do you think shorter chairs will survive without the lower set of braces in the legs?
Thanks for sharing your process and congrats on the results!
Dining Chair Build
Thanks Dotson and tool49.
I am planning to build table-height (18" seat height) chairs, and I do intend to have just one stretcher in the bottom, centered, or more toward the back. I have no doubts that they would be strong enough with no stretchers, but that's just not the style I'm going for. Also, I did briefly consider bending the back, but the wood is so thick (1-5/8") that I just don't think it would go. Also, there really was very little waste - I just situated them like a jigsaw puzzle on the board, and i was only left with a few skinny triangles of scrap.
Dining Chair Build
That must have taken forever
Dining Chair Build
I really appreciate you posting this; I was looking for a project like this and hope to make some chairs.
Question though, not clear on the compression strap you mention in bending the backs and it's not very clear in the photo. Can you elaborate a little more on what it is and how it works?
Thanks again
Jack
Dining Chair Build
Jack,
The compression strap keeps the wood from stretching. Supposedly, wood is not good at stretching, even when the wood fibers are "plastic" from being heated via steam bending (or dry bending). However, wood can be compressed to a certain extent, before it starts to buckle on its self. Image the folds of an accordian… you don't want that look when steam bending ;-). So, the concept is to use a steel strap that does NOT stretch to keep the wood from stetching on the outside radius. Then the only way for the wood to move is to compress. Here's a shot of my bending strap. I just make it so the wood fits snugly in between the two cleats. I actually did start out with some thinner "plumbers' tape" that they use to hang pipes with, but it literally stretched about 1/2"... Not good. so, I made another one out of thicker steel strap I bought at the big green home improvement store.
Wood Hardwood Flooring Wood stain Art
This strap is the one i made with plumbers tape. I don't think I ever took a pic of the new one.
This shot shows the strap in place. See the two little pieces on either end of the piece being bent? That's the strap in place, bent along with the wood.
Hope this helps!
Dining Chair Build
Super Blog thanks for sharing.
Dining Chair Build
One more thing - for slight bends like this (large radius) I doubt the compression strap is really necessary. I think when you start doing 90 degree bends and things where you are really putting a lot of forces on the wood is when the compression strap really becomes necessary for successful bending.
Dining Chair Build
Pete, that was exactly what I was looking for. Now I understand and it makes a ton of sense!
Thanks for the very quick reply and the extra photos. I haven't tried any steam bending but a co-worker has and he's been having some troubles - this might be the answer he needs.
Today is my first day signed up to LumberJocks and so far I'm 'way smarter than I was before…
Jack
Dining Chair Build
