1 - 7 of 7 Posts
I am trying to figure out dimensions for an 18W x 24L x 30-33H kitchen cart.
In an effort to make efficient use of wood and $, I thought I would laminate 3/4 oak for 1 1/2" legs rather than three of them for a thicker leg.
i am looking for feedback with regard to the scale of the leg size vs. top size and appropriate support of the structure. Do these seem right or should I go with heavier legs. I have seen a few carts in stores and they all seem to have 2" legs.
seems a tad "tippy" but maybe not?
Cabinets, carts etc., are kinda like chains, as strong as their weakest link.
pending how the cart is joined, a 1" x 3/4" leg will probably suffice so 1 1/2×1 1/2 is more then enough beef to hold even my sister in law who weighs in at over 400 pounds
Discussion Starter · #5 ·
I have not sketched it out yet. I often design in my head first. I am considering enclosing on side of the cart with a door to conceal a stand mixer which is very heavy. I am really less concerned with stability than I am of how it looks, I don't want it to appear spindly.
Will you be adding the swing up shelf for the stand mixer? If so, you'll need to consider tipping. It really helps to draw these things out to scale. I usually laminate 3/4" boards together for my projects, unless it's absolutely critical to not see the seam (like on my dining table). I will be laminating the legs for my side chairs. If you have a choice, I usually put the seam side on the sides. Also, if you use lock-miter joints, you can get rid of the seams entirely by hiding them in the corners of the square legs. I'll be using that method on the 4" x 4" dining table legs and my Morris chair (if I ever get around to it).
Discussion Starter · #7 ·
No swing up shelf. The mixer will either be used on the cart or a kitchen counter. I can live with side seams, I have used that practice in the past and with proper grain matching they preety much disappear.
I have never heard of a lock-miter joint before, sounds intriguing.
1 - 7 of 7 Posts
