1 - 6 of 6 Posts
Discussion Starter · #1 ·
Cutlist 4.1 SketchUp Plugin by Steve Racz: My Notes
Rectangle Font Screenshot Parallel Software
If you can run SketchUp on your system, you can run this plugin, too. I run on Windows 7, therefore my notes were created accordingly. If you have trouble located the file folders on your computer, just run a search and find the path, usually starts with C:...
For all you new and used SketchUp users, there is an awesome plugin created by a member, Steve Racz, a.k.a. daltxguy. Steve created this Cutlist 4.0 (currently upgraded to 4.1) http://lumberjocks.com/topics/9435.
I downloaded, installed and learned the program, and compiled my own notes for getting up and running. Just thought I would share and hope it helps. http://wp.me/pOGgI-4s
Thanks Steve. Love the plugin. Great work!
In Loving Memory
Thanks for the plug-in to the plugin, Ryan. Greatly appreciated. The plugin truly has been a group effort and it's enthusiastic support for it like this which makes it better and better.
Is this plugin for Windows 7 only? I'm running Windows Vista does this make a difference?
In Loving Memory
If you can run sketchup, then you can run this plugin. That means all Windows operating systems as well as Macs
I concur, is one of my 3 most favorable plugins.
The other two are weld and engineering toll box
Discussion Starter · #6 ·
Hey Steliart, what are the other two favorites you use (SketchUp plugins)?
1 - 6 of 6 Posts
